8,000 lb vs 10,000 lb winch question - JeepForum.com
post #1 of 10 Old 12-07-2007, 10:22 PM Thread Starter
SecondTJ
SecondTJ's Avatar
I'm looking into getting a winch, and i'm on a budget so money is an issue. I've decided to go with the Chicago Electric winch.
Now the 8,000 lb one can be had for $240; and the 10,000 lbs one for $320.
But the 10k one comes with a roller fairlead ($30) and the 8k doesn't, so there is only a $50 price difference if I were to get the 8k plus a roller fairlead
My question is, is the 10k winch worth the extra $50?
8,000 lb winch
Line speed (in feet per minute): 11.0 FPM @ 2000 lbs., 6.0 FPM @ 6000 lbs., 4.5 FPM @ 8000 lbs.
4.1 HP, Gear ratio: 210:1
20-11/16" L x 3-1/8" W x 6-15/16"
10,000 lb winch
Line speed (in feet per minute): 6.56 FPM @ 2000 lbs., 4.92 FPM @ 6000 lbs., 4.26 FPM @ 8000 lbs., 3.28 FPM @ 10,000 lbs.
4.8 HP, Gear ratio: 294 :1
21.9'' L x 6'' W x 6.8'' H
Current: 2017 JK Unlimited Rubicon
Gone - 1998 TJ Sport, 2000 TJ Sport, 1987 YJ, 1997 TJ SE, 1998 XJ Sport
SecondTJ is offline
post #2 of 10 Old 12-08-2007, 07:31 AM
Skeezer
For only $ 50.00 more I'd get the 10,000 LB winch. But if your budget is really tight the 8,000 LB is more than adequate. The nice thing about the Harbor Freight Winches is that they come with the Winchplate & Roller.
2005 Rubicon
Skeezer is offline
post #3 of 10 Old 12-08-2007, 07:49 AM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
The 8,000 pound is enough power for your jeep. Also, you may want the faster line speed.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #4 of 10 Old 12-08-2007, 10:27 AM
CETROV
CETROV's Avatar
I had the Chicago 8k and used it a few times. Worked perfect and never had a glitch.
Then bought the 10k and used it a few times. Works perfect and never had a glitch with it either.
I went to the 10k Just in case.
I paid about 320 for the 10k also.
I'd go with the 10k.
Been driving the same TJ since 2001.
CETROV is offline
post #5 of 10 Old 12-08-2007, 10:43 AM
Skeezer
Agree, for $ 320.00 you can't go wrong.
2005 Rubicon
Skeezer is offline
post #6 of 10 Old 12-09-2007, 01:24 PM Thread Starter
SecondTJ
SecondTJ's Avatar
Awesome, yea the extra $50 isn't a deal breaker. Sounds like i'll go with the 10k, thanks.
SecondTJ is offline
post #7 of 10 Old 02-15-2008, 05:16 PM
officialvin
where did you find the 8000 for 240? i just looked it up and it says 299.. im also going to buy one of these.. im going with the 8000 tho.. but id like to know where you found yours cause ill buy it from there
officialvin is offline
post #8 of 10 Old 02-15-2008, 11:52 PM
20minToRockies
Guest
How much does the 10K weigh?
My thinking is:
1. You're already on spacers so the option of putting a couple spacers up front to level your Jeep out after the winch is out the window. Gotta keep the Jeep level.
2. You'll never need 10K pound force for your Jeep. The only time you'll actually use that extra 2K is if you have to pull out a Suburban or Expedition or something (and you'll need an anchor vehicle too). Why spend the money?
20minToRockies is offline
post #9 of 10 Old 02-17-2008, 01:12 AM
Indy
Indy's Avatar
I wouldn't think there is a significant weight difference between the 2. I set a 10k on the front of my cj5, I don't think it even moved.
For essentially the same price, why not? But I had a 25% coupon when I bought mine, I think I paid 250 for it.
I'm the only gay eskimo.
Indy is offline
post #10 of 10 Old 02-18-2008, 10:47 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One thing more about comparing similar winches with differing winching capacities... generally speaking, a larger capacity winch will usually require significantly fewer amperes from the Jeep's electrical system when winching the same load as a smaller winch. The trade-off is knowing when the larger capacity winch's added weight is enough to make it a little too heavy for a Wrangler.
Jerry Bransford is offline
another winch question Matt_G General Jeep & Off-Road Equipment 29 01-24-2010 10:49 AM
Question about winch buying winch for front bumper jeep53191 General Jeep & Off-Road Equipment 0 10-07-2009 08:30 PM
winch question wranglerkid95 General Jeep & Off-Road Equipment 3 04-21-2009 03:24 PM
Winch question 4x4Mudmonster General Jeep & Off-Road Equipment 4 05-27-2008 06:07 PM
Question on a winch skip97 General Jeep & Off-Road Equipment 20 03-14-2007 01:22 PM
