Project 'S' Jeep Registry
Previous Jeep M Series Next Jeep
Project 'S'
Email Bookmark Print
PropBlast
Henderson
Jeep Information
Year:1977
Model:Cherokee 'S'
Engine:401
Transmission:Auto
Transfer Case:Stock
Front Axle:D44 Stock
Rear Axle:D44 Stock
Suspension:4"Superlift Springs/Shocks/Pitman Arm
Tires:35 MT Baja
Wheels:35 Black Rock Crawler
Armor:None
Recovery Gear:Warn 9500i
Accessories:Griffon Al Radiator, Upgraded Hydraulic Brake/Steering System/ On Board Stick Weldor, MSD Ig.
Future Modifications:Needs a Tailgate ?/Rebuild 401 (sitting for years now) or replace with Hemi? Needs front and rear O.R. bumpers with Swing Away Tire Carrier/ Upgrade Driveline add disc brakes/ add Roofrack/
This project got off to a good start but then the money dried up. Currently working on my 90 'Heavy Half Ton' Suburban Diesel 4X4
, will return to the Jeep ASAP (I drool over it!). I need some suggestions on the way to go with this project. I think full restoration is not what we want, but an everyday trail Jeep? The tailgate is missing (I have the glass). Should I replace it, or treat the back end like the bed of a P/U? The holes in the front side panels, should I just leave them alone or attempt to fill them in? The front grill exists, but it's been pretty well cut up as you can see. Any suggestions there? Thanks for your help and hope to see you out there someday!
None
Login Or Register To Post Comments
