Wrangler 2007 freedom panel leaks - JeepForum.com
post #1 of 1 Old 11-13-2019, 08:10 AM Thread Starter
1bsot
Just to let you know. Had water leaks from the outside into the pannell over the passenger to the space between the top layer and the frame of the pannell underneath. Could not find the hole for a long time. Eventually i drilled several hole's and sprayed polyurethane foam inside all the frame. This showed me where the hole is and sealed it at the same time.
Hope it will last for a long time.
1bsot is offline
