TJ full door tear down for Paint. - JeepForum.com
post #1 of 11 Old 02-22-2014, 09:28 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Here you go guys a write up on how to remove all the parts necessary for a proper paint job.
First start by removing the "C" clip that holds the window crank on. There is a proper tool for this, but I could not find mine. So, I used a pick tool.
Then move on to the Torx screws, there are 2 in the pull strap and 3 along the side and bottom of the panel.
Now to pop the panel off the door frame. Slide a clip tool or putty knife or screw driver under the panel and lift with a little pressure to release the plastic clips.
Now with the panel removed you can remove the reinforcement for the door pull.
Pull back the vapor/water barrier being careful to not damage the plastic or the adhesive used to attach it.
Vapor barrier removed you can access the two screws holding the window on the regulator.
Then remove the two screws in the trim holding the run channel in.
Now comes the fun. The outer door handle is attached to the rod that actuates the latch by a cotter pin and a spring washer.
The spring washer is located behind the rod that is held in place by the cotter pin.
Now with a screw driver and a pair of needle nose pliers you can grap the slides that hold the outer door handle in place. Use the flat screw driver to move the retainer clip off the stepped portion on the slides and pull up with the pliers.
Then grab the handle and work back and forth till it comes free from the door.
Now you can see the retainers that hold the slides in the door handle.
Time to remove the belt molding. It has a clip every four inches that can be tricky to remove. If you grab the molding with both hands and push towards the inside of the Jeep you can release and pull up on the belt molding. Just start on one end and move across as the clips become free.
Now the lock cylinder. Its pretty easy. Just grab the slide retainer with a pair of pliers and pull, then remove the colored clip holding the rod on.
Then sand the door with a DA sander and what ever grit paper you need depending on the finish. I sanded this with 500 grit.
You can reverse the steps for reassembly.
Hope this helps someone get the Job done right.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2 of 11 Old 02-22-2014, 11:05 PM
Loadsmasher
Big thumbs up! I'm planning on taking my drivers door apart soon to figure out why the outside latch is so floppy and this will help a ton. Thank you!
"War is an ugly thing, but not the ugliest of things..."
Loadsmasher is offline
post #3 of 11 Old 02-23-2014, 07:33 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Your Welcome, your outside latch is so floppy because the return spring is probably broke. I would order a replacement handle before you start just to save you from having to do it twice.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4 of 11 Old 02-24-2014, 11:59 AM
Loadsmasher
Awesome, thanks for the tip.
post #5 of 11 Old 02-24-2014, 04:31 PM
Ironworker709
Ironworker709's Avatar
Great write up!!..Worthy of being a Sticky
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 11 Old 02-25-2014, 08:56 PM
sardog12
sardog12's Avatar
2019
Wish I had these instructions when I had to take my door panel off when I had the full doors. One thing that I did learn a while back on an old vehicle was that a string small enough to fit behind the crank knob worked back and forth can often get the clip out a bit easier, if you don't have the tool.
GEAUX TIGERS
sardog12 is offline
post #7 of 11 Old 02-26-2014, 05:37 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thank you!
A cloth shop towel will also work to remove the retaining clip on the window crank. Just work it back and forth till the clip releases.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #8 of 11 Old 03-13-2014, 07:00 AM
99dodge
Awesome write up. I need to replace my door panal and this helps ALOT
As for me and my family, we will ride for Christ
99dodge is offline
post #9 of 11 Old 03-16-2014, 11:09 AM
Loadsmasher
The passenger side and driver's side handles are interchangeable with the one caveat it will have the outside latch opposite the correct handle, right?
post #10 of 11 Old 05-18-2014, 07:50 AM
wwch99tj
wwch99tj's Avatar
Thanks for this! I just picked up a set of full doors that I'm going to be painting soon
Sent from my Galaxy Note 2 using JeepForum
wwch99tj is offline
post #11 of 11 Old 01-18-2020, 05:48 AM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
can you do something with the photos?
Every one of them has a big photobucket logo over them so they are not useful
Can this be cleared up?
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
