Rust fact or fiction - JeepForum.com
post #1 of 16 Old 05-29-2019, 01:07 PM Thread Starter
pat master
I've been involved in fighting rust on both classic cars and street rods. I've been in industrial coatings business for 30 years. Most of you are a lot younger than I and you will be fighting the rust for years to come. First lesson metal prep. When you wire wheel away rust put a coat of paint over it your generally pissing in the wind. Unless that paint is airtight it's coming back to bite you. Metal prep solutions I generally phosphoric acid and zinc. It dissolves the rust and leaves a zinc phosphate film to combat rust. Zinc is self-sacrificing, in other words it wears out. Even if you paint a alternator bracket wipe it down metal prep. Your work will last longer.I don't know maybe a Jeep and your age,, you keep these things forever? Anyway if you have any questions I would love to share my experience and knowledge with the younger generation.
pat master is offline
post #2 of 16 Old 05-30-2019, 11:12 AM
PwnCall
I’ve found preventing it in the first place is the best option.
I use fluid film if I plan on keeping a car longer than 5 years here is my comparison for it.
https://m.youtube.com/watch?v=4NCUJoa0lVs
A lot of the younger guys tend to just trade in and get something else instead of fix rust or before it starts.
Fluid film won’t keep it rust free forever but will definitely slow it down.
PwnCall is offline
post #3 of 16 Old 05-30-2019, 02:18 PM Thread Starter
pat master
You are 100% correct. The old saying a ounce of prevention is worth a pound of cure. It certainly holds true as far as rust goes. Fluid film is calcium sulfonate, paraffin wax and petroleum. Calcium sulfonate is an excellent rust preventative but has to be applied under a vehicle periodically. The harsh environment under a vehicle causes the softer coatings to wear. Calcium sulfonate is what most inner panel protector's are formulated with. It is also one of the active ingredients in undercoating. A good combo would be metal prep the seems then apply the fluid film over it. The metal prep will kill any rust in the seam in the calcium sulfonate will prevent its return.Good rust work starts from the inside out I hope this helps
post #4 of 16 Old 08-07-2019, 09:59 PM
WildBillinTN
WildBillinTN's Avatar
1978 CJ5
I'm starting a 1978 CJ5 with some serious rust in the floor panels. I'm looking for something to start spraying the rust and killing it off so I can get an idea of what I have left and what needs replacing. What would you recommend? The Jeep is now in my shop out of the elements. Thanks.
-Wil
1970 CJ-6 Buick 225 (RIP)
!978 CJ-5 304
1990 Jeep Comanche 4.0
1992 Jeep Wrangler 4.0
WildBillinTN is offline
post #5 of 16 Old 08-08-2019, 08:49 AM
V8GCZJ
Bead blast the rust off to bare metal then use a good epoxy primer/paint. There already is a similar post on rust...
https://www.jeepforum.com/forum/f260...iques-4318075/
V8GCZJ is offline
post #6 of 16 Old 08-20-2019, 08:45 AM Thread Starter
pat master
Sorry it took so long to respond. If you do bead blast doing it very gently as not to blowholes to the floor. I would recommend a good wire wheeling followed by a phosphoric acid rust remover that contains zinc. What I do is use a spray bottle soak the metal lay paper towel or rag over it.Then spray it again let it sit for an hour you should be down to clean steel. Wipe it off let it dry and you're ready for paint. Now I know the Jeeps that you guys drive is not a forever thing. So you can use either the moisture cured aluminum flake primer or epoxy one things for certain when you use a good quality metal prep regardless of the paint that you use will last a lot longer by using the prep.
post #7 of 16 Old 08-21-2019, 08:56 PM
WildBillinTN
1978 CJ5
What phosphoric acid with zinc do you recommend? Is there a specific product you have in mind that you prefer to use?
!978 CJ-5 304
post #8 of 16 Old 08-22-2019, 10:27 AM Thread Starter
pat master
Ospho Rust Cure and of course my favorite Master coat rust remover and prep. Now keep in mind I started the master series coating line 30 years ago and I don't want to run a commercial. Your fastest rust remover is phosphoric acid-based rust remover's it's been around for 40 years I know of. The new ones that use chelation take longer to remove the rust. Basic rule always use a metal prep not some sort not a converter when doing your bodywork. This is the 1st step in quality rust repairs.
post #9 of 16 Old 10-08-2019, 08:36 PM
Freeagent27
I picked up some new full doors today as my old ones were rotting real bad. The new doors are in good, solid shape, but some very minor surface rust starting on the very bottom edge of the door. I want to attack this and treat it as best I can. I was going to sand it down, then use acetone after to clean it before priming. Is acetone no longer recommended for this? My other idea is to spray some type of bed liner on the lower 2-4 inches of the door after the rust is cleaned up. I know it will have the rough texture, but I'm just trying to prevent future rotting issues as I am in a heavy salt belt. Thoughts? Tips?
"My thoughts on yoga pants? Depends who I'm walking behind".
Freeagent27 is offline
post #10 of 16 Old 10-09-2019, 09:44 AM
actiondan
actiondan's Avatar
Acetone is fine to clean up what you sanded. Why would it not be?
actiondan is offline
post #11 of 16 Old 10-10-2019, 08:02 PM
PwnCall
If the rust is on the inside of the doors than you might have to replace the metal.
Fluid film the inside either way.
PwnCall is offline
post #12 of 16 Old 10-10-2019, 09:07 PM
Freeagent27
Ive got the panels pulled off. The inner door looks real good. I will definitely treat the inside while everything apart
post #13 of 16 Old 11-30-2019, 04:07 PM
Letzride
can you paint over a zinc phosphate film?
1999 TJ 4" Lift - 33's
Letzride is offline
post #14 of 16 Old 12-01-2019, 11:06 AM Thread Starter
pat master
Metal prep etches the surface to promote paint adhesion. As for the zinc film that is to combat the rust. You want a nice light coating of zinc.If you leave it on too long simply re wet it with the prep. Dampen a Scotch bright pad with water scrub it lightly and dry it off with a paper towel or rag. Take a panel treat one half with metal prep and wipe the other half thinner and paint it. Set it outside and see which side rusts the fastest. This particular metal prep will dissolve heavy surface rust in less than an hour.
post #15 of 16 Old 12-01-2019, 11:54 AM
V8GCZJ
Problem is when Chrysler made the doors it was bare metal and the door skin got folded over the inner section. It then got painted but water can still get between the two. This is where the rust starts. You need to try to get rid of any rust then make sure water doesn't get between the sections. It's not easy but can be done. Also pay attention to the drains at the bottom, Make sure they still can let water out.
V8GCZJ is offline
