Paint issues - Page 2 - JeepForum.com
post #16 of 23 Old 11-25-2018, 02:22 PM Thread Starter
WJ04JGC
Update...cracking is considerably worse. Looks terrible!not Affectsarea painted.
WJ04JGC is offline
post #17 of 23 Old 11-25-2018, 02:24 PM Thread Starter
WJ04JGC
Meant to say affect every area that was painted
WJ04JGC is offline
post #18 of 23 Old 05-18-2019, 11:02 AM
pat master
Things like this can drive you nuts I have a 55 Chevy that I primed with my permanent rust sealer everywhere but the roof. The roof has now has sand swell marks. It has a basecoat clearcoat so this problem is not confined to just the lacquer. So I will have to tape the whole car off sand the roof with 220 grit put 2 coats of my silver primer and a coat of epoxy surfacer. Then comes the base and the clear. Do not try to wipe it off with lacquer thinner. Because you'll have a big mess and ruin the body filler. I hope this helps,, bodywork is always a pain in the ***.
pat master is offline
post #19 of 23 Old 05-19-2019, 05:09 PM Thread Starter
WJ04JGC
thanks for the reply and info. It definitely is a pain. I actually just sprayed urethane base and clear on two of the affected panels today. Looks pretty good for an ameture.
To remove the paint, I used a 4" spackle knife and a heat gun.
WJ04JGC is offline
post #20 of 23 Old 05-23-2019, 06:20 AM
pat master
Great I'm glad it turned out Great. Before long you'll be a master painter. I've been doing paint bodywork for 40 years and now I'm done.The more I do it the worse I get. Every year I would swear to God I'll never paint another car as long as I live. Every year one would pop up. Is a good skill to have for younger people. A sense of pride for a job well done. Now you can live in fear that someone will plant a car door against it. Good luck
post #21 of 23 Old 05-24-2019, 08:52 AM Thread Starter
WJ04JGC
Thanks
Not sure about the master painter part,lol!
I still have a few panels to do but it's coming out decent so far. My body work needs work I think!
Definitely not easy. I would rather do brakes or a starter.
Yeah, now I'm nervous with people parking close to me when I didn't care before...oh well, still "had" to do it! And it does give a sense of pride even though it's not perfect
WJ04JGC is offline
post #22 of 23 Old 05-25-2019, 05:28 AM
pat master
If you want perfect use 2 different color primers. One over the other and when you sand the top primer off you should see only the bottom primer. This will help you know where the low and high spots are. Then you know your straight Your hand works better than your eyes when it comes to bodywork. In the next few years your bodywork will improve where everything is perfect and shiny when you get older you say screw it good enough.One other thing when you go panel by panel count the number of color coats and the distance of your gun so each panel will match Good luck
post #23 of 23 Old 05-25-2019, 02:58 PM Thread Starter
WJ04JGC
Thanks for the the tips. I'm sure they will end with excellent results👍🏻. I think I will leave the next time to the body shop. Although in generally satisfied with my results, it's just too damn much work!
My hats off to the guys that do this for a living!
WJ04JGC is offline
