93 XJ Door Issues- Help! - JeepForum.com
 2Likes
  • 1 Post By Kruzin
  • 1 Post By prerunner1982
post #1 of 5 Old 04-12-2019, 12:34 AM Thread Starter
W5KGP
W5KGP's Avatar
1993 XJ Cherokee
Hi all!!
So I just recently got a project Jeep XJ (1993) and I noticed the doors have some issues.
Front DS practically Permalocked closed. Interior door handle linkage is broken and does not work.. Exterior doesn't want to work regardless of any jostling, coercing, or caressing. I can still get in via Passenger door for now, but may not last long LOL and rear driver side door also doesn't work from either side. I know these issues are due to gunk from yonder but once I open them... anything I can do besides lubing it all up to prevent it?
What about mods to the door handle/ lock system? I'd like to remove the doors sometimes during the summer but still have security.. cause as we say in Albuquerque... "Come for the balloons, stay cause your car is stolen"
Also sorry if this is the wrong thread... kinda new and this is a pressing (feels like it) matter
Bluegrass is the vessel of which the Banjo's sole soul speaks
W5KGP is offline
post #2 of 5 Old 04-12-2019, 02:31 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You need to get inside the door to manipulate the linkage/latch and repair/replace as needed. To get inside the door, you can either pull the driver's seat out to try to get the door's trim panel off, or sacrifice the door trim and cut a big hole in it.
And XJ doors don't come off like a Wrangler. XJ is a unibody vehicle, and the door are an integral part of the structure. Driving with the doors off will heavily damage/twist/bend the unibody.
W5KGP likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 04-12-2019, 05:28 AM Thread Starter
W5KGP
W5KGP's Avatar
1993 XJ Cherokee
That I did not know.. Good to know! I'll see if I can take off the trim panels. Honestly.. Kinda tempted in just leaving them off anyways. most of them already have holes and I don't mind a little rough looking interior.
I also take what you said, as if the hinges are loose (welds are deteriorating) I should get them rewelded?
W5KGP is offline
post #4 of 5 Old 04-24-2019, 02:39 PM
prerunner1982
1993 XJ Cherokee
The doors are not a structural part of the body, they are held on by two poorly welded hinges and a latch. The window frame of the door is weak. You would also have areas along the outside edge of the door and along the door jam without paint where the body was rubbing against the door depending on the door to hold the body together and I see no indication of that on any of my 3 XJs.
73
W5KGP likes this.
Jon
1993 XJ Sport 2 door
prerunner1982 is offline
post #5 of 5 Old 04-24-2019, 04:40 PM Thread Starter
W5KGP
W5KGP's Avatar
1993 XJ Cherokee
I'm not exactly an engineer, but I may try to just un pin the doors and replace them all together. I'm gonna reweld the hinges and go from there
W5KGP is offline
