Metalcloak - Duroflex Control Arms Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $239.00
Average Price: $773.91
Manufacturer: Metalcloak
Recommended?
Yes: 11 / No: 0
Company Website: http://www.metalcloak.com/Duroflex-Control-Arms-TJ-LJ-Upper-Rear-Short-p/7052.htm
The MetalCloak TJ/LJ Upper Rear Duroflex Control Arms are precision engineered for all the flex and the smoothest ride.
Equipped with the all new MetalCloak DuroflexTM (Patent-Pending) self-centering composite bushings at both ends for a combined misalignment of over 68 degrees.
All parts are treated with Gold Zinc Chromate for the ultimate in defense against the elements.
adjustable , control arms , duroflex , metalcloak
RubiRoad
RubiRoad's Reviews
07-29-2015, 01:16 AM
Price: $1,200.00
Pros: Ride is awesome. Haven't flexed it yet.. will update. I got the aluminum double adjustable ones. Amazing! A few twists and I recentered my axels and adjusted my pinion angle in seconds after installing these. Steering is tight. Road noise is absorbed very well. No noise. It's a new Jeep!
Cons: Long wait. But honestly, very very worth it
Recommended? Yes
Comments: Finally got these in the mail. One month to the day after ordering them. Which is normally fine, but i just wanted these too badly
cxjo
cxjo's Reviews
07-01-2015, 10:30 PM
Price: $500.00
Pros: Excellent ride makes my XJ feel more like a real jeep!
Cons: Not sure I have discovered any real "cons" yet
Recommended? Yes
Comments: So far so good ride is smooth and they are tough I just went and beat them up at Moab I would recommend them to anyone with an XJ/ TJ
john02tj
john02tj's Reviews
05-09-2015, 12:05 AM
Price: $1,000.00
Pros: Strong, flexy, ajustable
Cons: none
Recommended? Yes
Comments: These things are awesome, they inproved my droop by quite a bit, people are suprised i do not have a long arm kit.
Dmarkowski
Dmarkowski's Reviews
02-28-2015, 01:48 PM
Price: $260.00
Pros: Auto center, easy to rebuilt
Cons: no cons!
Recommended? Yes
Comments: Expensive but cannot beat the duraflex joints and double adjustable!
sardog12
sardog12's Reviews
05-16-2014, 01:27 PM
Price: $1,000.00
Pros: Driving comfort, stability, control, articulation
Cons: None yet (don't expect any).
Recommended? Yes
Comments: Although it shouldn't be, it is amazing how much better and more stable my Jeep drives with the Duroflex bushings as opposed to my old arms. It handles better in everyday driving and the flex is great. Even with the Antirock, my Jeep has much less lean when I turn on the middle setting. I have only had these on for a few weeks but they are one of the best improvements that I have made to my Jeep so far.
BTW, I replaced all 8 arms, not just the upper rears.
DoughBro
DoughBro's Reviews
04-23-2014, 11:53 AM
Price: $1,000.00
Pros: Good vibration dampening level cornering way more flex than stock
Cons: none yet
Recommended? Yes
Comments: This are probably one of the best routes to take if you want to keep a short arm set up. the Duroflex bushings soak up a ton of vibrations and the arms lets you flex like crazy. One of the coolest things about them is as you turn the jeep stays level instead of leaning to one side. You may not thing that matters but once you ride in a jeep with these arms you will understand what I am talking about. Pretty straight forward install. it says you need a 7/16 bit for the rear uppers but that was too small. Half inch worked fine.
McNasty35
McNasty35's Reviews
03-08-2014, 12:18 AM
Price: $1,000.00
Pros: strong, well built, increased articulation, improved ride
Cons: none
Recommended? Yes
Comments: I love these arms and the duroflex joints are awesome. Better ride on the street, greater flex off road. The Jeep just seems to ride smoother. Install was very straightforward and the best part is the joint are rebuild able.
BadJohnny
BadJohnny's Reviews
09-08-2013, 10:19 AM
Price: $239.00
Pros: Duroflex joints; Adjustable; ride quality; articulation excellent; Single unit almost maintenance. free; Beefy; Lower CA joint is offset to provide greater clearance between the arm and the stock bracket at the axle
Cons: Instructions; wish uppers were Dual adjustable
Recommended? Yes
Comments: Jeep is driven on trails and some beach, but mostly a daily driver. Was going to go with Johnny Joint arms to prep for tummy tuck, but read about these and though I'd give them a try. Daily driving. Uppers come with metric size grade 8 bolts (I read on forums to use a 15/32 drill bit and it worked great). Lowers reuse stock bolts.
The minimum the rear uppers will adjust is 1/4" over stock length and the lowers will adjust all the way down same as stock no problem. Not sure on maximum length.
