Iron Rock Offroad Adjustable Control Arms Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $600.00
Average Price: $476.63
Manufacturer: Iron Rock Offroad
Recommended?
Yes: 19 / No: 0
IRO Adjustable Control Arms
None
coldspit47
coldspit47's Reviews
05-04-2016, 01:13 PM
Price: $800.00
Pros: BEEFY components
Cons: No install/spec sheet
Recommended? Yes
Comments: HIGHLY recommend. Install was easy except for the front UCA bushing (no fault of arms, the old bushing was severely rusted and seized into housing).
Setup was very easy, despite having no instructions included. I took one star off for this fact and this fact only. I had to call IRO a few times to reach someone for the specs, but they are a small company and I believe they were at an offroad event, so I'm not bothered by that.
On-road manners are now excellent for a lifted vehicle.
mashunitjeep
mashunitjeep's Reviews
12-07-2015, 02:13 AM
Price: $315.00
Pros: ADJUSTABLE AND GREASABLE
Cons: PRICE
Recommended? Yes
Comments: GOOD AND GREASABLE BUT PRICE IT HIGH THEY TREATE DME WELL AND VERY STRONG
Highschool_WJ
Highschool_WJ's Reviews
03-08-2015, 03:46 PM
Price: $179.00
Pros: Easy to install and built tough
Cons: Not sure how long the bushings will hold up
Recommended? Yes
Comments: Very easy to install, but I would recommend having a knowledgeable shop install and set the proper length unless you have the means to do so yourself.
Also built tough, just not sure of the bushing quality yet
GreenMachine_x
GreenMachine_x's Reviews
08-27-2013, 03:33 PM
Price: $1,300.00
Pros: HAD TO GET THEM WITH THE LIFT,
Cons: NONE
Recommended? Yes
Comments: HAD TO GET THE REAL ONES, TO GET THE REAL AXLE CENTER OF THE WHEEL WELL , the hole lift kit with control arms and other stuff,
capcyclone
capcyclone's Reviews
08-10-2013, 01:28 AM
Price: $600.00
Pros: Solid & Beefy!
Cons: Price, but worth it!
Recommended? Yes
Comments: Excellent quality - solid & beefy! Well built - Highly recommend!
LIMITEDwoLIMITS
LIMITEDwoLIMITS's Reviews
06-20-2013, 05:35 PM
Price: $500.00
Pros: HUGE
Cons: IDK YET
Recommended? Yes
Comments: not installed just yet. sitting in a box. Look to be very rugged and they are huge. much more beefy than stock and fully adj up to 6.5"
94whitewidow
94whitewidow's Reviews
04-24-2013, 01:37 PM
Price: $143.00
Pros: Way stronger then I will ever need.
Cons: ? Yea right these were awesome.
Recommended? Yes
Comments: I ordered a set of its control arms fixed lowers adjustable uppers for a 3" lift. I couldn't have asked for better they dropped right in out of the box already painted and at a good price.
WJ_allday04
WJ_allday04's Reviews
03-14-2013, 11:40 PM
Price: $320.00
Pros: very well built, adjustable
Cons: none
Recommended? Yes
Comments: I havent yet installed these but from the looks of them, they are very well built. I just wish IRO.com would give you reccommended lengths for them at specific lift heights.
GTO71
GTO71's Reviews
11-25-2012, 07:14 PM
Price: $321.00
Pros: Easy Instal & Ajustable
Cons: No grease fitting
Recommended? Yes
Comments: Got the rear adjustable, rides nice, east install, great quality, good company
Airborn
Airborn's Reviews
08-06-2012, 05:17 PM
Price: $380.00
Pros: Strong
Cons: none
Recommended? Yes
Comments: Great control arms, nice heavy duty, great adjustable capabilities
Omega88
Omega88's Reviews
07-13-2012, 02:38 PM
Price: $160.00
Pros: adjust to fit different lifts and pinion angles
Cons: long shipping period
Recommended? Yes
Comments: Heavy duty. installation was extremely easy, bolted right in place. Only complaint is that took about 3 weeks to get to me.
holdfast
holdfast's Reviews
01-13-2012, 07:09 AM
Price: $169.99
Pros: adjustable, sturdy, look good
Cons: price
Recommended? Yes
Comments: I bought these control arms after installing a 4 inch lift on my WJ and experiencing a little shimmy and vibration, once I pulled the stock front upper control arms off and replaced with the front upper adjustable control arms from IRO, the vibration was for the most pary corrected.
dlane2155
dlane2155's Reviews
11-24-2010, 05:08 PM
Price: $1,800.00
Pros: Fairly cheap, good 3 piece cross-member design
Cons: Y link driver side, caster adjuster.
Recommended? Yes
Comments: I have Iron Rock 8" long arm kit with their new style adjustable control arms. The three piece cross-member design makes it easy to work on the transfer case without removing the control arms. I have not decided if I like the Y-link or not yet, though the kit does perform well off-road and gives a lot of flex. The caster adjuster is a little screwy and I don't like it. I would rather have an adjustable upper arm. Iron Rock has good customer service. I had to get my long arms replaced because I could not properly set the caster on my XJ, I'm assuming due to a bent axle or something, and they made me a custom driver side arm and sent it out at no charge.
OlBlueBucket8
OlBlueBucket8's Reviews
08-16-2010, 08:30 AM
Price: $340.00
Pros: Beefy
Cons: None to Think of
Recommended? Yes
Comments: I have lower Fixed and Upper Adj. They are pretty Beefy.
jeepster4x4
Guest
jeepster4x4's Reviews
10-06-2009, 02:42 PM
Price: $129.00
Pros: heavy duty
Cons: no cons
Recommended? Yes
Comments: got both top control arms with adjustable ones will get for bottom ones
mtnmarc
mtnmarc's Reviews
07-30-2009, 03:58 AM
Price: $180.00
Pros: very adjustable
Cons: pairing the same size up perfectly
Recommended? Yes
Comments: very durable control arms. im gunna buy rears soon. they can take a beating and still remain perfect
kmk108
kmk108's Reviews
06-29-2009, 12:33 AM
Price: $359.00
Pros: Beefy, great brand, cheap
Cons: none that i can see
Recommended? Yes
Comments: I needed to get these because my alignment shop couldn't align my suspension because my stock arms were too short. I bought my lift from IRO and only had good things to think of them. I got these and less than a week later, they were on and my front end was aligned. They do what they are supposed to and let me flex a lot better.
RrCoX22
RrCoX22's Reviews
04-07-2009, 05:48 AM
Price: $600.00
Recommended? Yes
Comments: Lot's of versatility and very heavy duty. Great product for some short arms.
doublejz
doublejz's Reviews
10-18-2008, 10:21 AM
Price: $460.00
Recommended? Yes
Comments: These can be a life saver when your pinion angles get outta whack due to lifting your vehicle. Just slap these babies on and dial the angles back in. Plus it makes the ride a little softer then the stock arms.
ThreadForumRepliesLast Post
Iron Rock Offroad Iron Rock 3" Lift Complete Lift Kits 12 05-04-2016 12:03 PM
Iron Rock Offroad IRO 3.5" Suspension Kit Complete Lift Kits 26 04-20-2016 04:03 PM
Rock Krawler Adjustable control arms Control Arms 8 12-02-2015 09:25 PM
Iron Rock Offroad IR-W4CPK Complete Lift Kits 11 05-29-2014 10:54 PM
Iron Rock Offroad 3.5" ZJ Spring Springs 5 11-25-2012 06:16 PM
