20 Gal tank upgrade with Electric Fuel Pump Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Carburetors Next Product
Rating: None
Product Information
I have a 1990 YJ 4.2 with the BBD, mechanical fuel pump and a 15 Gal fuel tank. I just bought a new 20 Gal Poly tank and a Warrior skid plate. I installed a 1991 YJ in-tank Fuel Pump/Pickup assembly.
I plan on upgrading the BBD in the future with a Holly Sniper EFI (not even remotely interested in the Howell system) and that’s why I’m going electric with the fuel pump. I’m in California and currently the Holly Sniper is not CARB compliant so I’ll does this down the road. I’ll be adding a pressure regulator and I’ll just block off the old mechanical pump to fuel the existing carburetor which works well.
Here’s my question, does anyone know a shortcut on where I can trace to fuel pump wiring up front? I’m about to trace it all down but was hoping for help.
The original fuel sending unit has a 3 wire Weatherpack connector with only 2 wires from the sending unit. The 3rd wire port was a blank hole with a rubber plug. The factory wiring harness the sending unit plugs into has the 3rd wire, Orange/Black, already there so I’m going to take advantage of that. I cutoff the old connector and installed it to the new fuel pump (I have all the fancy weatherpack connector parts and crimper). I’m assuming that Jeep just used the same wiring harness for both the 4 and 6 cylinder that year. Since the 4 banger is fuel injected it has a factory electric fuel pump and that is what the Orange/Black wire is the for. I haven’t traced it under the dash yet but on schematics I’ve been pouring over, it looks like it ran to the MCU on the 4 cylinder.
The 4.2 MCU is not the same as the 4 cylinder so my MCU isn’t programmed to handle an electric fuel pump. I’m assuming that is where I should find the Orange/Black wire nearby.
I know I’ll need a relay and an oil pressure switch so this is my puzzle to figure out.
How to wire it and to where? Is there already a relay next to the battery I can use? Any help will be appreciated.
None
