YJ Rear Winch - JeepForum.com
post #1 of 7 Old 09-10-2021, 10:39 AM Thread Starter
Never_done
YJ Rear Winch
Been toying with the idea of rebuilding the rear of my YJ to accommodate a rear winch. My jeep has already been stretched 5", rear of the frame has been repaired/reinforced. The rear bumper currently there is definitely not up to the abuse I put things through so I am going to build better, also my my winch leaves some to be desired so get better for the front and move current to the rear. And I think also going backwards a few inches isn't going to hurt my feelings as it will allow for a little more cargo space if needed. I need to be able to maintain the ability of opening the rear gate, I run a fuel cell crammed in back there so I have to be able to open the gate to put fuel in.
Anyone have any suggestions? Any thoughts on the topic? I have a few ideas of my own but am always open to other suggestions.
Never_done is offline
post #2 of 7 Old 09-27-2021, 10:15 PM
pg_jglr
1981 CJ5
I had a similar idea but I was only going to have 1 winch but have it receiver mounted and try to integrate a hitch to both bumpers somehow.
pg_jglr is online now
post #3 of 7 Old 09-28-2021, 03:45 AM
Liselelal
Liselelal's Avatar
nice
Liselelal is offline
post #4 of 7 Old 09-30-2021, 10:17 AM Thread Starter
Never_done
I considered doing some sort of movable winch but everyone I ever seen on those hitch mounts has bent the mount. Plus I want to get a better winch so this one will either end up on the back or maybe on my trailer. I dunno
I do really think I want some more cargo space so I decided to at least start the task of building a bigger bumper and I am going to build in a winch plate to the middle. I also think I might build in some small corner boxes to keep some small tools and other fun stuff that lives under my seat. Will see how ambitious I get. But I did pick up some tubing the other day to extend my frame rails a little bit so once I get the urge to begin this project I am ready.
post #5 of 7 Old 10-04-2021, 10:26 AM
pg_jglr
1981 CJ5
You have a good point. Reciever hitches are probably designed for a load mainly in one direction (in line with the hitch) but a winch could be pulling any which way...
Sent from my SAMSUNG-SM-G935A using Tapatalk
post #6 of 7 Old 10-08-2021, 09:26 AM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
I had one for a few years as a suck-down winch for the rear suspension. I used it 1 time to pull myself back a couple inches. Other than that 1 instance, I never considered or needed it for a recovery. Personally I wouldn't bother with it.
Also, I doubt my install would help with ideas for your jeep.
bgredjeep is offline
post #7 of 7 Old 10-09-2021, 05:04 AM Thread Starter
Never_done
You are probably right that it won't get used, or at least not used much. My two biggest driving factors to doing the rear winch are:
1) I wheel alone a lot more than I should so this is just more help if I need it.
2) I want a better winch for the front so this is something good to do with the one I have now that otherwise aint worth much.
Another thing is that I need a new rear bumper anyway, what I have aint much and is turning into less the farther we go. On top of this, I am not sure that I will put a winch back there now, but I am building to be ready for that if I want. And also I figured that I would build a bigger rear bumper o give me room to strap down some more stuff if I needed to. I love my YJ but there just is NO room to carry extra gear.
