A YJ 5.3 build without a clever name - Page 165 - JeepForum.com
 299Likes
post #2461 of 2652 Old 01-16-2019, 03:22 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I could see that leaking from the diff cover unless its designed to fit over one? If thats the case why is the bolt pattern split in 2 pieces? Any particular reason for minimal truss? Weight?
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #2462 of 2652 Old 01-16-2019, 06:06 AM
NHfireLJ
NHfireLJ's Avatar
I've been looking for a minimalist front truss to use for an upper link mount and about all I'm finding is one made by Synergy.
It looks good but seems to be just old stock left from a few vendors and they only seem to carry the part # for a leaf spring setup. I'm not quite sure what difference that would make as they only show pictures of 1 model but dont say which, and the guy at Poly Performance wasn't much help. Maybe I'll try calling Synergy tomorrow.
Anyone have a suggestion for a truss? I'm not sure what's up with the ring around the bolts, does it go under the diff cover? I might be concerned about sealing issues...
Sent from my SM-N960U using Tapatalk
Definitely looks like it goes under the cover but I don't like the seem in the 2 pieces. That would have to be welded to have no leaks, Not sure I'd trust RTV to seal that joint...
AUDREY...95 YJ UNLIMITED
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #2463 of 2652 Old 01-16-2019, 10:10 AM Thread Starter
Randonexplosion
Randonexplosion's Avatar
Mainly space and ease of install. With sleeved tubes I dont need another 24" of truss extending to the passenger knuckle. That looks to be the only option though. Unless you wanted to put that fancy press brake to use
If it went over the diff cover then I would have to use the factory one. All or most aftermarket covers have individual recesses for the bolts instead of one flat plane. That wouldn't be that big of a deal though as I'm not the biggest fan of the Teraflex covers that I have.
Kinda odd that there isn't much info on it.
Randonexplosion is offline
post #2464 of 2652 Old 01-16-2019, 11:24 AM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
That one goes under for sure (between the cover and diff). I found this one.
https://davescustomsunlimited.com/d4...ar-axle-truss/
bgredjeep is offline
post #2465 of 2652 Old 01-16-2019, 02:20 PM Thread Starter
Randonexplosion
@bgredjeep good find. I found some more like that searching for link bridges rather than trusses specifically. That one has an optional tab to attach to the diff cover bolts too.
post #2466 of 2652 Old 01-16-2019, 04:42 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Ha! You got me. Of you were close Id say come on by and bring your 3/8 plate and beer.
Edit... or Burbon
Randonexplosion likes this.
87TPIYJ is offline
post #2467 of 2652 Old 01-16-2019, 05:29 PM Thread Starter
Randonexplosion
Edit... or Burbon
post #2468 of 2652 Old 01-17-2019, 06:58 PM Thread Starter
Randonexplosion
The truss from Aeris Fab looks pretty good. It has a slot cut to weld to the upper control arm after you cut off the bushing portion. The truss from Dave's Customs requires you to use their diff cover to attach the bracket.
I got the rest of the brackets cut off of the rear this afternoon. The lower control arm and track bar brackets were aftermarket and whoever installed them welded both sides. It was exhausting cutting them off but it was a lot faster than using a grinder. I still have to grind the welds down though.
bgredjeep and 87TPIYJ like this.
post #2469 of 2652 Old 01-19-2019, 08:14 PM Thread Starter
Randonexplosion
Looking for a little but of direction to move forward so I can get some parts ordered.
Is there any inherent advantage to running the upper link on the driver vs passenger side or is it based purely on space? If so then I'm still planning on mounting it on the driver side. It should sit nicely right over the driveshaft. I will have to rework the engine skid arm but that's not a big deal.
Also, Is it really worth it to try to stuff a 14" shock in there? I'm currently using probably 11" out of my 12" shocks and I feel like I have plenty of travel. Though i plan on mounting the new shocks out wider so that will eat up that travel a bit sooner.
Lastly, with how tight the space might be for the front upper, will a 2" JJ be sufficient? I'm running 2.5" joints in back with 1.5" shank lowers and 1" shank uppers.
post #2470 of 2652 Old 01-20-2019, 04:40 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Either side is fine. What ever packages better for you. I would definitely stick with 14 travel. No reason to limit yourself now. When looking at it I would have been able to keep 16 under the hood (barely). Smaller uppers is fine. Running the Motobilt kit (which is designed to use 7/8 upper heims) with JJs I had to get the smaller ones so my uppers are 1 shank and lowers are 1.25. If it was the wider 2-5/8 upper then my driveshaft would hit the upper mount. Just think there are people out there running upper and lower 7/8 heims. Wouldnt recommend that for lowers though.
87TPIYJ is offline
post #2471 of 2652 Old 01-20-2019, 11:25 PM Thread Starter
Randonexplosion
@87TPIYJ Thanks for the confirmation. I'm planning on running 14s front and rear.
I was doing some shopping for JJs this evening and even the smaller 2" housing with the .75" shank still seems to have a 2.625" mounting width. And they dont seem to have a tube insert available, at least through 4lowparts. How did a smaller housing help clear the driveshaft if the width was the same?
I got some local interest in my axles so despite coming down with a cold I drug my wife to the garage and we got the axles out. If all goes to plan I should have them out of the way next weekend and have some ORIs coming.
Here are some comparative pics. The 8.8 looks pretty beefy compared to the Rubi 44 but the additional width will be nice for mounting shocks.
NHfireLJ likes this.
post #2472 of 2652 Old 01-20-2019, 11:26 PM Thread Starter
Randonexplosion
Glad I never finished welding the upper coil buckets in
post #2473 of 2652 Old 01-21-2019, 06:56 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
They make different mounting widths. If you use a computer and go to Curries site when you go to the JJ section you can filter by mounting width, hole size, shank, etc. You can touch the sides of the insert with a flap disk if its close to the width you need. I had to take .050 off my uppers to get them to fit.
87TPIYJ is offline
post #2474 of 2652 Old 01-22-2019, 03:03 PM Thread Starter
Randonexplosion
I pulled the trigger on 14" ORIs for the front. After reading about lead times I didnt want to let the 2 go that were in stock at Poly Performance. They haven't gotten back with me about restock times yet but at least I'll have something to start mocking up.
I also ordered a front truss from Ares Fab and I'm getting a list of all of the JJs together for the front.
Man, Artec link brackets seem like they've gotten expensive since I did my 4 link. I'm going to do some shopping elsewhere, maybe take a look at Synergy or Barnes 4wd.
post #2475 of 2652 Old 01-24-2019, 08:58 AM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
I've had good luck with Barnes brackets.
You didn't list them, but I'd steer clear of Ballistic. They don't seem to be having the old delivery/service issues, but their axle link brackets just don't fit well. Frame side stuff is ok, but I'm going to have to cut off my current lower mounts before too long and replace them as they've caved in around my joints.
4 link , 5.3 vortec , engine swap
