The Wasteland Survival Guide: Engineering Greta - Page 510 - JeepForum.com
post #7636 of 8099 Old 11-03-2014, 07:18 AM Thread Starter
Sundowner
Sundowner's Avatar
Originally Posted by dongalonga View Post
Glad to hear you dad is doing better. Outside food should help immensely!
I agree...and the improvement continues, so that's even better news.
Originally Posted by spyder6 View Post
You don't call, you don't write. Shenanigans.
Hey...you're the one that vanished with even more alacrity than I usually exhibit...but since we're not pointing fingers, here, I hope you - and everyone, for that matter - will accept my apologies for being entirely too busy with...well, everything...for quite some time, now.
Sundowner is offline
post #7637 of 8099 Old 11-03-2014, 07:54 AM Thread Starter
Sundowner
Sundowner's Avatar
Today's Jeeping: Can someone PLEASE answer these questions for me: Why don't link bridges/trusses hug the axle tubes and housings? Why do most of them seem obtrusively large and stand off from the housing itself? Does nobody make something that wraps the differential a bit closer than the common offerings? ???
post #7638 of 8099 Old 11-03-2014, 10:06 AM
LA-Sahara
Not sure what you're looking for, but my Barnes4wd bridge is only about a 1/2" above my 44. And can always be cut down dome more.
LA-Sahara is offline
post #7639 of 8099 Old 11-03-2014, 10:11 AM
clintrivera
clintrivera's Avatar
If you look at your stock axle, the lower control arms are mounted below axle center line. Most people raise them to axle center line for better clearance. That means the uppers have to move up. Also, axle link separation is supposed to be around 25% of tire diameter, so big boy tires require even more separation. Hence, tall trusses. Of course tall truss + "Low COG" = cutting the floor. Also some trusses are "generic", as in can be used for a variety of diffs.
As said, you can always cut yours down, but that defeats some of the purpose of buying one.
clintrivera is offline
post #7640 of 8099 Old 11-03-2014, 11:51 AM
84jeepcj7rock
84jeepcj7rock's Avatar
my BTF truss hugs my diff really well, the included diff cover is really beady and it bolts the the truss
84jeepcj7rock is offline
post #7641 of 8099 Old 11-04-2014, 07:22 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
What can I say, I hate almost everybody here
My builds:
and
or follow us on
spyder6 is offline
post #7642 of 8099 Old 11-04-2014, 08:17 AM
srfnfly227
srfnfly227's Avatar
I've had the same questions about trusses lately. I'm pretty much decided on the Barnes 44 truss for the rear and Clayton for the front. Seems like the Barnes would be the easiest to modify if you want it to sit lower since it doesn't tie in to the diff cover.
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #7643 of 8099 Old 11-04-2014, 10:06 AM
CEScuzzy
Is the 25% of tire diameter a matter of strength, or geometry?
-Scuzz
"Some Assembly Required" is a target, not a deterrent.
CEScuzzy is offline
post #7644 of 8099 Old 11-04-2014, 12:17 PM
clintrivera
-Scuzz
A tire is basically a large lever trying to force the axle to twist forward and backward. The control arms stop it. The larger the tire, the more force applied to the control arms and brackets, truss, etc.
post #7645 of 8099 Old 11-04-2014, 12:26 PM Thread Starter
Sundowner
Sundowner's Avatar
Okay...roughly in order...
My main goal with a link bridge is to just give myself a good mounting surface for the axle end of the driver's side upper link...but I also want to keep the axle looking as "factory" as is possible; I don't have any sort of good reason for that, other than wanting to have a sleeper-esque HP44 front. Given my preferences and with cost as no option, I'd make a truss that essentially followed the contour of the housing and left very little room for daylight to show through; the main bridge would be 3/8" steel with a bend or four in it - actually it would probably have exactly four - and I'd weld on some skirting pieces in order to clean up the look, front and rear. End result: ultra-low-profile link bridge that can't easily be seen.
I'm going to keep my lowers about 1" below the centerline on the axle end; any higher and all of my numbers start to get...weird. I hadn't really thought about link separation in terms of tire diameter, but it seems to make sense to me now that I consider it in that way. That would be a good starting point for that portion of the suspension's design.
Exactly; if I'm going to modify something to any significant degree, I'd be better off getting exactly what I want custom-made...or making it myself.
I like the way the BTF stuff bolts in; that's something to consider.
The Clayton is about the lowest-profile that I've found so far, but it's only listed for the TJ44...not an HP44. Regardless, Jankoid has assured me that it will, indeed, work on the latter axle...so it's in contention as either a solution or a starting point.
Link separation is more about transfer of force; that's the easiest way to generalize it.
Well, I'm glad you showed back up, regardless.
post #7646 of 8099 Old 11-04-2014, 01:00 PM
CEScuzzy
Strength then, gotcha.
I expected something along those lines. I used the word strength to refer to the system's ability to withstand and redirect torque through the control arms (perhaps a hasty generalization to sum that up in one word.) Longer mount brackets allow the control arms to exert more resistance to the torque placed upon the system by the tires.
If I had more time, I'd run the numbers.
-Scuzz
CEScuzzy is offline
post #7647 of 8099 Old 11-04-2014, 01:26 PM Thread Starter
Sundowner
Sundowner's Avatar
Sort of...
...and in turn, take more load, themselves. In the world of suspensions, nothing is free and everything is a compromise...and often, it's a compromise between opposing forces. I'm not doing anything terribly radical with my suspension design - it's actually nothing more than the stock geometry warped into a better configuration for larger tires - and there's a very good reason for it; past a certain point the compromises start stacking up and building on each other. It's not limited to the first-order effects, either; much as Clint mentioned - and as we've discussed before - there are second- and third-order impacts. Floors may need cutting, frames may get in the way, engines may have to be relocated, and the suspension itself may have to be partially redesigned in order to keep from getting in its own way...and that's just the start of it.
post #7648 of 8099 Old 11-04-2014, 01:44 PM
357transam
357transam's Avatar
You're staying 4 link with track bar front? Or 3 link with track bar?
357transam is offline
post #7649 of 8099 Old 11-04-2014, 01:46 PM
CEScuzzy
Sort of...
I know this has probably crossed the conversation before, but if you're introducing modifications this extensive, why not just go straight to some manner of tube buggy? Not that I disapprove of your philosophy here, but by the time you complete this design, it seems to me that you will be nearly there already.
That said, I understand that you want to do it, and that's all that really matters here.
-Scuzz
CEScuzzy is offline
post #7650 of 8099 Old 11-04-2014, 01:56 PM
dongalonga
The conversation is getting interested again. I like learning.
dongalonga is offline
annabelle , bewbs , chic-fil-a , custom , d&d , fallout , firefly , girly things , guns , half cab , hard tonneau , needs to go wheeling , overbuilt , photography , pin-up , sammiches , starwars , survival , wasteland
  LinkBacks (?)
LinkBack to this Thread: https://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/
Posted By For Type Date
glockforum | BoardReader This thread Refback 08-15-2012 10:17 AM
sears diehard batteries - forum communication | BoardReader This thread Refback 07-31-2012 08:50 AM
go there engineering bumpers austonreeves Jeep Picture Requests 4 07-29-2012 10:54 PM
What makes yours a Survival or Wilderness Jeep? fishinjeeper Jeep Picture Requests 39 07-23-2012 01:02 PM
BOV/Survival Jeeps ttony Jeep Picture Requests 2 09-30-2010 05:47 PM
33 engineering bigj1974 Jeep Picture Requests 2 02-03-2008 09:28 PM
GRETA .... then and now GRETA97 Jeep Builds 6 05-05-2004 09:41 PM
