JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep Builds (https://www.jeepforum.com/forum/f22/)
-   -   A TJ LCG build with lofty aspirations. (https://www.jeepforum.com/forum/f22/tj-lcg-build-lofty-aspirations-3497194/)
psyviperx 11-13-2015 09:10 AM
Heres how it looked when i got it. (246271)
http://drive.google.com/uc?export=vi...0xiN1BqMG9CdzQ
http://drive.google.com/uc?export=vi...09zNTZzRWZoMVE
It came with lots of extras and a few to do's.
Extras:
Highlift jack
2.5" Heavy OME Lift; used, not installed (sold)
1.25" BL; used, not installed (not for a TJ)
Jeep Add-a-Trunk (sold)
Trail Cover
Dust Cover
Bikini Top (not for a TJ)
2 Soft top frames.
To do:
Front brakes (done)
Transmission output seal
Drivers seat back (done)
Preliminary Build Plans:
Engine
Cowl intake
2k+ Header
2.5" header back
Highflow Cat
Undecided Muffler
Update Ignition
Drive line
MML (done)
TT
Lockers
Stretch (maybe)
Suspension
Refresh bushings
HD Control arms, most likely adjustable (not likely, see edit)
New stock height springs
Body
1.25" BL (done)
New Paint
Highline
Dropdown Tailgate
Armor
Skids
Bumpers
Interior
Dual stock switch panel
Bedliner
Fix/New front seats (fixed...kinda)
New roll bar pads
Electrical/Other
Upgrade Soundbar (done)
Upgrade HU
120v Power
Lights
OBA
Other supporting mods as needed.
This is going to be primarily a DD with the occasional Weekend trip so, i want to keep the road manners as nice as possible. I also like the look of an LCG build and it should be able to handle anything i ask it to do. It's a rather lofty build on my budget so, it will be a little slow and subject to change.
Edit: My initial plans for this little guy have changed, but only a bit. I've decided I'm going to use as many stock (not necessarily jeep or even mopar) parts as possible. The reasoning being, quick and easy repairs anywhere.
EXAMPLE: If an IRO control arm gets smashed i have to order and pay for a new IRO control arm and I'm stuck without a ride until it's fixed. If i smash a stock control arm i can go to the nearest junk yard or auto parts store and have a replacement in a day or two without having to pay shipping or hope the manufacturer is still in business.
This restriction really only effects the suspension, drive line, engine, and brake systems. Electrical, bodywork, and armor are still fair game for aftermarket replacements/upgrades since they normally won't leave you stranded because of a failed specialty component.
psyviperx 11-13-2015 09:15 AM
Brakes (246396)
When i picked it up the left front brake was worn down to the steel on both pads and the rotor had been taking a beating.
https://drive.google.com/uc?export=v...UZFNFpfUEF6QjQ
After pulling the wheel off i noticed that the sway link was broken as well.
https://drive.google.com/uc?export=v...U1NNm5URURpUUk
Luckily, in one of my bags of goodies that came with it was a new link (a new set od pads was also included).
Back to the brakes, i got the caliper pulled off without incident and fitted into a hoby vise to compress the piston. The piston was seized enough that it bent the arm on my vise. Nuts. I stepped areount to the right side and checked it out.
https://drive.google.com/uc?export=v...WRybEl2S21CbjQ
It wasn't quite as bad as the left....
I decided that i didn't want to deal with rebuilding the calipers and since i would have to make an unplanned trip to the parts store any way i bought two new calipers and another sway link.
While digging through the bags i also found a bushing kit for the front sway bar. They got installed as well.
psyviperx 11-13-2015 09:18 AM
Tool Box
I have had this Craftsman Rally Box taking up space under my work bench for a couple years now. Someone was tossing it so i rescued it from the scrap bin. I finally found a use for it.
I'm thinking i want to mount it like this.
https://drive.google.com/uc?export=v...mhDaV9tSDUzRTg
This would allow it to be mounted facing the interioir or exterior and its out of the way of the seat movement.
psyviperx 11-13-2015 01:58 PM
3 Attachment(s)
A little front yard flexing just for s&g's.
Attachment 2508306
Attachment 2508314
I also picked up some of the wipe new as seen on tv stuff too try out. I find it entertaining that they use TJ flares on their box.
Attachment 2508322
psyviperx 01-04-2016 03:21 AM
Floofing the Soundbar
I had a couple 6" alpine speakers laying around from an older project so, i decided to upgrade the 5.25s in the soundbar.
When i pulled the factory speakers out i realized just how bad off they were.
http://drive.google.com/uc?export=vi...XM0SGFVeVhLWEE
Once i had the speakers out i stuffed the soundbar with a generous amount of floof.
http://drive.google.com/uc?export=vi...GJwNVJBN0otYzQ
After stuffing the soundbar i returned my attention to the speakers. I decided, because i had the time mostly, that i wanted to use the stock speaker plugs with the new speakers.
http://drive.google.com/uc?export=vi...mp1d21mZTdPVlU
I unsoldered the leads and removed the plugs. There's little clip that fits into the speaker frame and locks them on. Don't just yank them off.
I had to file the frame of the Alpines to accept the plug and drill a small hole for the retention clip. If the clip doesn't get seated correctly the male ends wont plug in.
http://drive.google.com/uc?export=vi...TVxYUUtamRsTXM
http://drive.google.com/uc?export=vi...jZSR2l2VVdLdEU
After i got it all buttoned back up i went for a drive. The sound was much better. I did create a problem though. The sound from the sound bar now overwhelms the single 4x6 i have in the front. My next project is to try and stuff some 5x7s in the dash.
psyviperx 03-16-2016 10:54 AM
(247279)
Replaced the worn serpentine belt the other day. I stopped by the parts store and grabbed the belt and headed home to dive in to the engine compartment.
Got the old belt off, loosened the tensioner to what i thought should be enough and started routing the new belt. I needed another 1" or to to get it on so loosened the tensioner some more. It didn't help. I double checked the belt p/n on Google, it was correct but, there was no way that belt was going to fit.
I grabbed both the old and new belts and headed back to the parts store. We measured the old belt. Which is becoming a lost art apparently. We decided that the belt I needed was a Dayco 5060940, which is not listed for any Jeep engines and only one Chrysler. Not sure whats funky with my setup but, it definitely isn't "stock."
psyviperx 04-24-2017 10:52 PM
2 Attachment(s)
There's been some progress.
New shoes: 32x11.5 Nankang Mudstar 880s on stock Gambler rims with a 1" spacer in the rear.
Attachment 3299426
The 1.25" BL and 1" MML were also completed. For the MML, I went with spacer blocks instead of the taller mounts. (See post 1 edit)
Attachment 3299434
The broken seat back has also been fixed. Now I just need to fix the seat mounts they're mounted at different heights and the driver's seat won't slide forward or back.
rollout1 04-25-2017 07:45 AM
Looks like you have a P71 in the driveway too. :)
psyviperx 04-25-2017 08:00 AM
That's been upgraded as well. It's now a '13 Charger. Haha
The time now is 12:11 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
