Tanners 79 CJ5 Build - Page 33 - JeepForum.com
 126Likes
post #481 of 491 Old 06-29-2020, 07:02 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Problem is lack of funds to fill said offshore account... plus the wife is an accountant who balances everything to the penny every month... No sneaking around that! 🙂
You forgot all the random other colors going into my scheme, red silver and black, but then 40 year old off white, still unpainted steel, dirt and about 3 variants of black! Haha, she definitely will need a bit of paint lovin at some point, but I want to make sure everything is working right before I freshen her up.
And yellow is still loved, all the love to yellow Jeeps!
tbunch is offline
post #482 of 491 Old 06-30-2020, 07:20 AM
MrPink42
MrPink42's Avatar
2015 MK Patriot
I told my wife when i get my TJ i am not getting a Yellow one lmao. i like yellow but not on a vehicle. i am leaning towards white, dark blue, green or black.
-Justin
Thumb Jeeps Member since 2014
MrPink42 is online now
post #483 of 491 Old 07-01-2020, 09:55 AM
coggsdsmt
coggsdsmt's Avatar
Love the tube work!! Damn I need a bender...
coggsdsmt is offline
post #484 of 491 Old 07-01-2020, 04:17 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Thanks coggsdsmt
So I’ve here’s kinda where I’m at. I’ve spoken at length to the guys at busted knuckle, the folks at accutune, my local fab shop and some buddies and have come to a few conclusions.
First and foremost, I need a sway bar. There just isn’t an easy way around this one. I spoke to Tony at TK1 racing and settled on a 42” rock crawler bar with 16” arms. And pulled the trigger. He was pretty convinced I didn’t need the double shear kit for my setup. Hopefully it comes soon so I can get it in and really do some testing.
Then there is the ride height. I got all kinds of suggestions on this, from moving my mounting locations, to changing to 14’s to running tender coils, several different spring rates and heigh calculations. And so on.
To rule a few things out I re-measured and re-ran all my measurements through the 4 and 3 link calculators. This let me see if there were any glaring link geometry issues that needed to be resolved. Fortunately the numbers looked great. I’m at 84% AS in back and 89% up front. And my roll axis angles are not bad, -1 in back (perfect) and 4.3 up front. The front will contribute to oversteer and body lean, but not by much.
So what I have done for now is this. I went somewhat against the grain and relieved much of my spring preload. Currently I have about .25-.5” of preload on all the springs. It’s definitely lower than I should be running, but it accomplishes the ride height I need and since my axles have limit straps I don’t think I’ll ever be in a situation where I don’t have more actual downforce on the spring than just the preload.
I have also lowered the adjuster nuts to an inch above the slider so that the dual rate comes into effect sooner. Easy to change if it’s too soon.
In all I was able to lose just over 1” on ride height. And it’s honestly about perfect. When I get in it it still leans, but only 1.5 degrees. Not terrible. I’ll probably add some additional pre-load on the driver side just to hold it level when I’m in it alone.
Other things to do eventually is change the shock valving so it has better control. I can also go with a tender coil in the rear and use slightly heavier springs which will help more with lean and load capacity. For now though I’m going to try it with the sway bar and see where I’m at.
This is a more tedious process than I thought, but I want to try and do it correctly. In reality I should have used a 14” coilover or air shocks, but live and learn.
On the plus side my buddy gave me some nice LED headlights he had from an old project that will be a nice upgrade to my old ones!
tbunch is offline
post #485 of 491 Old 07-01-2020, 10:41 PM
RAMMJETT
Wow what a build , nice job ..
RAMMJETT is online now
post #486 of 491 Old 07-06-2020, 02:10 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Got a couple more pics of the exhaust, not great pics, but it’s something. I need to have it coated or painted with header paint since it’s not all stainless.
I also got my LED lights in, they look so much better so I’m excited!
Then I also got this package of goodies in the mail today!
Pretty stoked to get it in and see how it changes stuff. Hoping this one is enough, if I have to add a front one I can do so once the funds have rebounded.
Unless I run into some major complications I should be ready to do some trail testing this weekend. Not gonna go if things aren’t ready though.
87TPIYJ likes this.
tbunch is offline
post #487 of 491 Old 07-06-2020, 05:41 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Canít wait - we might be more excited than you to see that beast in the dirt.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #488 of 491 Old 07-08-2020, 12:13 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Originally Posted by NashvilleTJ View Post
Can’t wait - we might be more excited than you to see that beast in the dirt.
Haha, it’s definitely felt like a long time in the garage, long as it’s all worth it and it works like it should I’ll be happy!
It’s very close though. I’ve put in some hours yesterday and today to get the sway bar knocked out. It was more work than anticipated, but I’m pretty excited about it.
Placement was a bear because I had not designed anything with a sway bar in mind, love and learn I suppose. Issue was my slider lands exactly where I should have had the tube go through the frame. Can’t go in front or it will hit the coilovers, below hit the links, so I was able to barely squeeze it in on top of the frame.
Doesn’t look like much, but I had to cut the edge of the tub and then spend all night cutting little bits off the bottom of the tub, take the whole fuel system apart, eat a mournful of dirt and the bar juuuust fits. Some Oates that weld to the frame on both sides and it’s quite stout! Mocked up the arms just to see.
It does have one drawback that I will lock myself for later.. the bar cannot be removed.. my frame tie-ins are directly in the way. I played with it as much as I could, but there was no way to make it happy. The back of the arm hits if I go forward, front hits if I go back. Hopefully it just stays on there forever and never fails... maybe?
Anyways, today I welded it up since there was gas everywhere yesterday, painted it up and installed the arms for real.
Also knocked out the rear limit straps. Been waiting for 18’s, but they are in back order from PRP so I made 16’s work.
Not perfect, but they will work. My bump pads are too big to put them directly in line with the shocks.
Tonight I made the links and welded tabs to the axle and got it installed and back on all 4.
Pics are a little dark, but you can see how it all fits. It’s basically textbook. I have 16” shocks so I got 16” arms, it’s perfectly level at half shock travel, links are 17” eye to eye and the tabs on the axle are just a little wider than the arms.
I need to play with it a little tomorrow and probably preload one side so it better resists the torque lean, just try and get it down.
Basically just the little stuff left. The plan is to get it on dirt on Friday to get some real world testing done. Quite excited. I have one more little side project to knock out that I’m pretty excited about, I’ll share that if it all works out! Extremely close now!
tbunch is offline
post #489 of 491 Old 07-11-2020, 10:41 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Well, success with a small helping of failure. But not to worry.
First things first. I had some good help this week from buddies ready to get out with me. We buttoned you small details like harnesses, painting some things, tuning the springs a bit more and just little things, one of which was discovering that I wired my fuel pump backwards.. for pretty mad since I thought I had a bad pump... stupid thing really.
I was able to go on some street drives with my buddy and took my 3yo daughter on a cruise around the neighborhood since she has been anxiously waiting for daddy to finish the Jeep!
In the midst of all this I ordered my self a little gift for getting to this point.
Finally ditched the steel cable for safer rope. I justified it because that little side project is making my winch dual pull so I have a suck down. Cut a hole in my bumper plate and with the help of my buds we fixed a hawse fairlead on it. I still need to weld the attachment point to the bumper and hardwire controls to the cab, but it will work nicely!
Then to the good stuff. After some additional final details we finally got it out on some rocks!
The verdict so far: it flexes like a beast! The pictures don’t even show it, but it just drops those tires down all the way! And it keeps traction so well. My buddy is pretty hardcore, but very experienced and he put me right into time tough spots and it walked most everything.
However, I need seat time badly! The Jeep drives and feels so incredibly different than it did on leafs. It’s no surprise, but actually feeling it is eerie. Looking at the pics I can see where I was stable as ever, but it felt like I was going over constantly. I really don’t know it’s limits yet and I don’t know where my tires are, it definitely had my nerves up, but once I get familiar with it, it’s gonna be able to tackle some tough stuff!
Other thing is that the suck down winch will be very useful. In truth, the front suspension doesn’t unload as much as I thought, but if I’m climbing something like a ledge it does go up before the wheels climb. As a point of confession, I can’t actually climb onto my trailer. The body jacks up enough and the truck moves enough that it just doesn’t want to do it. Not a big deal though.
Unfortunately our fun was cut short due to shortcomings with my steering. Midway through a pretty tough obstacle I lost basically all steering to the right. At the repeated advice of several hydro assist retailers I was convinced I didn’t need a PS cooler. I also hadn’t modified my pump at all and am using a 2” ram. All effects combined to my steering fluid boiling over and everything stopping. We limoednit back to the trailer and I got it back to the garage for another day.
My friend gave me a good sized cooler to use and I’m going to try modifying my pump. If that fails I’ll have to save up for a higher volume pump, alternatively, my other friend has a smaller PSC ram sitting there that might be the correct throw, but require less fluid to move. Since I’m ultimately now out of money I’m searching for the cheapest solution.
In all I’m excited, steering being the only failure, and one I half anticipated, is acceptable.
My brakes need some work also, try as I may, the pedal is still soft. There is likely still air in them, but I’m starting to suspect that’s may have too short of a pushrod for the MC I’m using. All research says no, but I can’t help feeling it’s not compressing things all the way. Gonna sit on everything for a day or 2 To build up some energy to get after it again.
Very exciting though!
tbunch is offline
post #490 of 491 Old Yesterday, 10:56 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Congratulations. It looks like it did great. I have been learning mine as well, pushing a little further every time. I have also learned that my steering is becoming a problem. I just got a cooler yesterday that is going to work well and have been looking at the West Texas Steering Mod. I have to pull my pump due to the brackets so I haven't dove into that yet.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #491 of 491 Old Today, 11:48 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
I’m excited for its potential for sure, and to get out and start using it.
As for the steering, I think I have the solution. I spent some time on the phone with West Texas Offroad (redneck ram), and we discussed my setup. I also spoke to some buddies and the guys at poly performance) the consensus is that my pump is the weak link, along with the lack of a cooler. My pump is the original from before the motor rebuild and as such it has over 170k miles. Add to that the fact that it’s not been modified for flow or pressure and you get a serious weak link. I was able to wrangle up some cash by returning bits and pieces I haven’t used on the build and I have a new pump I’m picking up today. Once I do the west Texas mods and add a cooler the thinking is it should work perfectly.
The only drawback mentioned is that with the large ram and big bore steering gear I’m running my steering will be slow, on the flip side, if the pump works as expected, I should have gobs of steering power despite low speed. This also shouldn’t matter since the majority of my wheeling is technical crawling and this isn’t built to go fast.
On that note, I will at some point need to re-valve my shocks. The valving is not right and while it handles great in the rocks, it’s not a very smooth ride. If I hit larger bumps/dips at speed (speed being like 25-30mph) it bottoms out hard and it’s very rough.. anothe breast for another day.
Also going to try and adjust the pushrod on my master cyl to make sure I’m getting full compression on my brakes.
Little bit at a time.
tbunch is offline
