Tanners 79 CJ5 Build - Page 22 - JeepForum.com
 124Likes
post #316 of 490 Old 12-03-2019, 04:39 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Originally Posted by NashvilleTJ View Post
Just make that Jeep a two wheel drive sand rail...
I dig it, that would be way fun. Probably outta finish up one build before I dive into others.
NashvilleTJ likes this.
tbunch is offline
post #317 of 490 Old 12-04-2019, 07:53 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Just stop it with those logical ideas. I wouldn't know what to do with only one project going on. Lets see... the Jeep, the square body Chevy, the camper, the kids' Jeep, the CJ2A that I am dying to get started on.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #318 of 490 Old 12-16-2019, 09:18 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Welp, still here, haven’t given up on this thing yet. Though, motivation goes in and out. Haven’t been as good at updating, but not much has gone on, mostly planning.
That said, I have done some stuff. Main thing is finishing the frame extension. I full welded the splices and fish plates, then added tube gussets to add to the strength.
Painted it up.
Then it was on to the tub extension. I measured it 100 times, clamped it with a bunch of sheet metal clamps and spent the better part of an afternoon stitching it together.
All seemed well, but I have run into a snag. Although I lined it all up, the driver side is not right. I don’t know if the tub warped, or if I just screwed something else up, or just wasn’t paying attention, but it’s bowed.
Still not sure exactly what happened, but I’ve got some ideas to fix it and it should be fairly simple, though I will have to re-do some of the stitch welds. My fault though.
Beyond that, I sold my old tires and wheels, 1 of the axles, still pushing to sell the rest. Also tore down the 14 bolt.
In a nutshell, the plan is this now: the front is getting the Dana60. Its a weird one, basically it’s a 96 dodge 60, nobody likes them because they are CAD, have 30 spline shafts and are hubless unit bearings. However, the guy I got them from spent way too much money and retubed it for passenger drop, eliminated the CAD, got 35 spline inner shafts and 33 spline outers. Still hubless unit bearings, but since this is trailered I don’t care and can swap the outers later if I hate it. Because of the truss, and because I wanted too, the front is ditching the leaf springs and getting a 3 link with air shocks.
The rear is a 14bolt with disc brake conversion, both are 67” WMS and 8 on 6.5 lug pattern. Got the 14 bolt with a ruffstuff diff cover, disc brake conversion with the calipers, rotors and pads (still in the boxes) and an anti wrap bar kit (also in the box) and diff gasket for 300! The guy also gave me a d44 gearset for free, just to have it gone. I sold the wrap bar and gearset for $130! So I’m in the 14bolt $170. I also sold my leaf spring stuff which will cover an artec truss to match the front.
The rear is still getting 4 linked, but I’m gonna run coils back there for now until I can afford more air shocks. I have a few sets to play with so we’ll see what works.
Oh, and I’m planning either 5.13’s or 5.38’s for both axles. And drilling my steering. Gear for Hydro assist.
Engine is staying the same, getting an E350 master cylinder for the brakes.. that’s only $22.
There’s a ton of other details I have in the works, but these things are all but set in stone. The leafs are gone and some brackets cut off so I can’t bail now.
Hoping to fix the tub and start the cage next week!
tbunch is offline
post #319 of 490 Old 12-16-2019, 07:41 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Woh.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #320 of 490 Old 12-17-2019, 04:08 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Go ahead and do 5.38. I did 5.13's two years ago because I was only going to run 37's... Well last night I just mounted up two of the four 43's. So yeah go deep!
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #321 of 490 Old 12-17-2019, 07:31 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Woh.
haha, I can only guess you mean "woh, how did you weld the tub so crooked!?"
As for gearing, I'm partial to the benefits of the 5.38's, the only reason I would consider 5.13's is that my buddy, who I trust more than anyone I know when it comes to wheeling machines, has seen 5.38 pinions break as they are smaller when you get that deep. Now, I doubt that will happen with just 40's, but I also thought my D44 would be invincible with just 35's so...
Either way, I'll be doing the gear setup, so if I choose poorly, while it would mean buying new gears, at least I could sell them and not be out the whole setup cost twice. ultimately id like to eventually put a selectable locker in the front so I may end up doing the gears again anyways. For now, its either getting a lunchbox or just welded depending how much money I have. Id rather drive it all season with a welded front, than lose a whole season just waiting for parts. Same thing goes for the rear, though that's probably getting welded and will be that way for a while.
tbunch is offline
post #322 of 490 Old 12-20-2019, 07:20 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Just a quick little plug here since I fixed the crooked tub.
It was even easier than I expected, cut a little notch, clamped it together and welded it up. Good to go now. Also finish welded it and started grinding the weld down, but got sick of that about halfway through so I’ll hit it another day.
Also got the bender set-up for the cage work!
It’s just got the manual handle for now, which is a workout, but it does the job.
Pretty excited about this, wanted one forever, just haven’t justified it, now I’m just mapping the cage out and I’ll start knocking it together next week.
87TPIYJ and daddyjeep87 like this.
tbunch is offline
post #323 of 490 Old 12-29-2019, 08:38 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Well, been pretty busy with Christmas and holidays and everything, but did make some headway.
First, I made a ghetto modification to my bender. Since hydro is just an unnecessary expense right now, I tried something I’ve only seen a few people do. I basically used a trailer jack, built a mounting from scrap metal and hooked it up to the bender, almost like you would a air/hyd ram. Then I took the handle off and tried running it with the cordless drill. It worked, but was a huge strain on the drill, so I threw the handle back on and have been just turning that, rather than pulling the long manual lever. It’s still a workout, but it’s easy to control and there’s no spring back and less strain on the bender and mounting.
Started by bending up a grill guard and stinger. Had to tweak them a bit after this pic, but you get the idea.
Then I jumped into the cage and just went to work. It’s slow going, but for my first tube work I’m pleased. I haven’t ruined any tube yet and have almost no waste. Laying out the bends makes a lot of sense in my head for some reason, so that’s good. This is as far as I’ve gotten.
It may not look like much, but it is all squared up, tacked and I had to drill 2 foot plates for every mounting location, and drill holes in the tub.
I still have to do the rear kickers off that little half-halo loop, then do roof bars, then front seat tie ins, harness bar, then finish weld and paint the whole thing. I have a cage tie-in kit I got from a buddy so I’ll be playing part of the frame and building frame connections. It will mount to the frame in 8 places. This should stand up to some major abuse.
I also checked off another item and got new beadlocks. Just picked them up today, so no pics, but they are simple black allied beadlocks. Good price so I’m happy to have that off the list.
Moving slow but really my motivation is low and it’s cold outside so...
87TPIYJ likes this.
tbunch is offline
post #324 of 490 Old 12-30-2019, 06:46 PM
lovett86
lovett86's Avatar
Looks great. Keep it up.
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #325 of 490 Old 01-02-2020, 04:43 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
You are moving way faster than I am on my cage. Good work.
87TPIYJ is offline
post #326 of 490 Old 01-02-2020, 07:43 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Thanks guys, its definitely moving along, but in reality its more time consuming than I anticipated. The bending is quite easy, its the notching, and getting a tight fit at funny angles that is quite tedious. This is especially true when I have things that need to be symmetrical and centered. Seems I can get about 2 bars done at a time then I have to take a break and do something else. I'm also almost through all of my tube, which is nuts since I bought tons and have hardly scrapped more than a foot or 2 in total. I have an extra stick of DOM that I am holding for a buddy, I may end up cutting into that since he wont need it for a while, then replace it later. That way I don't have to stop production so to speak.
On a side-note, I picked up a set of gears for the 14bolt for really cheap. They are 5.13's. I was on the fence between 5.13 and 5.38, but I kept getting feedback from people experiencing breakage on the 5.38's. The guy I bought the 5.13's from said his buddy has gone through 3 sets of 5.38's, granted that's on 43 stickies, a huge motor, heavy foot and poor judgement, but still. For the price I can give them a whirl. I calculated my overall crawl speed will still be slower with 40's and 5.13's then it was on 35's with 4.10's.
Gotta finish the cage, then I can setup the rear suspension, then the front, then finish the axles. Hanfull of little tasks involved in that, but it'll get there.
tbunch is offline
post #327 of 490 Old 01-02-2020, 08:00 AM
daddyjeep87
1987 YJ Wrangler
The cage is coming out great.
YJOTM August 19
post #328 of 490 Old 01-03-2020, 07:53 AM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Thanks!
Here’s a few more pics of the progress. Once again, notching nodes kinda sucks.. or I kinda suck at notching nodes? Either way, it’s slow going.ec8b31e7-d59c-4d87-bfb3-3a95aa812b8c_1578063129665.jpg
tbunch is offline
post #329 of 490 Old 01-09-2020, 03:40 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Hard to tell in your pics, but is your rear halo in the same plane as the rest of the cage? I should be starting my rear halo either today or tomorrow. Was planning on putting it in the same plane. Do you have a good profile pic of it? Thanks!
87TPIYJ is offline
post #330 of 490 Old 01-09-2020, 09:32 PM Thread Starter
tbunch
tbunch's Avatar
1979 CJ5
Don’t have a better side pic of it, but it is intentionally out of plane with the main hoops, it kicks down at about 8 degrees. I like the look, takes away some of the boxy-ness of it and gives it more of a rounded feel, not enough to limit room in the back seat, just really for looks.
87TPIYJ likes this.
tbunch is offline
