RDaniel2405's 2006 TJ X - Page 12 - JeepForum.com
 1Likes
post #166 of 190 Old 10-02-2016, 11:53 AM Thread Starter
RDaniel2405
RDaniel2405's Avatar
Today I took the cheap eBay bumper/frame supports off and replaced them with a set from Poison Spyder
OEF Veteran & owner of a 2006 TJ
Instagram @theorangejeep
Pirate 4x4 @theorangejeep
RDaniel2405 is offline
post #167 of 190 Old 10-12-2016, 05:52 PM Thread Starter
RDaniel2405
Got some wood today for a project. I'm going to make something to to help take my hardtop off and on.
post #168 of 190 Old 10-13-2016, 10:52 AM
esad_b
Pretty straight forward! However I'd recommend use as many pulleys as you can to raise it. I did something similar last year and I did the T-bar method with 1 point of connection to raise it - it does work however the top spins around when raising it. Hopefully next spring I will add 4 corner pulleys so this keeps it square as I raise it. You can see some pictures in my 05 LJ build thread.
esad_b is offline
post #169 of 190 Old 10-13-2016, 12:07 PM Thread Starter
RDaniel2405
I started early this morning. I can pick up the hardtop by myself, but I can't maneuver it off without damage or scratches. Some day I will add a pulley system or some kind of hand crank, but for now this works for what I need.
neto_09 likes this.
post #170 of 190 Old 10-13-2016, 12:10 PM Thread Starter
RDaniel2405
Here is another pick. I just lifted from the center, and had my wife undo the hooks.
post #171 of 190 Old 10-14-2016, 05:54 AM
esad_b
Ah I see yah that works, wasn't sure if you meant for a few days storage for longer term.
What I did I put mine up for 4-5months so leaving it outside would deteriorate it Needless to say still innovative what you did!
esad_b is offline
post #172 of 190 Old 10-14-2016, 07:43 AM Thread Starter
RDaniel2405
I used pressure treated lumber so I can break it down to 3 pieces and store it outside in my side yard storage area. But for less than $40 it works for what I need.
As for my top, I have an dolly that holds it in the vertical position, and I will store that in the corner of my garage.
post #173 of 190 Old 10-16-2016, 06:10 PM
bobthetj03
bobthetj03's Avatar
Nice and simple. I use a similar method with 2 2x4's, some tie down straps, and 2 metal poles. The carport helps too.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #174 of 190 Old 10-19-2016, 07:59 AM Thread Starter
RDaniel2405
I don't know if anyone is actually fallowing my build or not. But just wanted to say I know it's slow and boring, sorry for that.
post #175 of 190 Old 10-19-2016, 10:18 AM
bobthetj03
bobthetj03's Avatar
You think your build is slow. I gave up on mine it's so slow. Your jeep is just so dang clean.
Bob's boring build:
post #176 of 190 Old 10-19-2016, 06:23 PM Thread Starter
RDaniel2405
I started to install a rear Currie Antirock. I'm taking my time installing it. One good thing while installing a rear Antirock is I previously installed a1.25" body lift. If I had only a 1" BL I would of had some trimming to do, but with the 1.25" I fits without. It's tight but so far so good.
post #177 of 190 Old 10-19-2016, 06:29 PM Thread Starter
RDaniel2405
This is as far I got for today, just the brackets fully bolted on. I will say Currie's direction are really good, 35 steps for installing a rear Antirock but the only thing I won't do is the axle brackets. I will have a shop with a better welder install them.
Tomorrow I will continue to fit the arms and start some trimming for arm clearance.
post #178 of 190 Old 11-01-2016, 05:46 PM Thread Starter
RDaniel2405
Yesterday I finally started the trimming for the rear Antirock arms. Here is a photo of the drivers side. I only trimmed out the size stated in Currie's directions. I will trill more later if needed.
post #179 of 190 Old 11-01-2016, 05:49 PM Thread Starter
RDaniel2405
Here is the passenger side after trimming and some spray paint. I have decided to not reinstall the rear plastic fender liners.
post #180 of 190 Old 11-01-2016, 05:50 PM Thread Starter
RDaniel2405
Back to the drivers side...
My 2006 KJ Silver65th Jeep Builds 6 11-03-2008 09:06 PM
My 2006 LJ Virginia_LJ Jeep Builds 16 04-28-2008 12:36 PM
2006 Unlimited. .Jch. Jeep Builds 5 10-01-2007 03:25 PM
2006 TJ, I love it!! SAB0602 Jeep Builds 3 11-10-2006 10:35 AM
