Project White Squid --- one ton YJ - Page 43 - JeepForum.com
 314Likes
post #631 of 635 Old 07-28-2020, 12:32 PM
cpia84
cpia84's Avatar
Definitely makes sense about doing the motor swap first then seeing what placement adjustments are needed for the axle. I also agree with the truss up front. I'll be tuning in to what happens next.
cpia84 is offline
post #632 of 635 Old 07-28-2020, 05:51 PM
Luke95
This is a fairly common failure. A truss will help but also weld all the way around the joint of the tube to the housing.
Sent from my SM-G965U using Tapatalk
97 XJ on 4Ds.
Luke95 is offline
post #633 of 635 Old Yesterday, 07:10 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Other than that, Mrs. Lincoln, how did you like the play?
Damn Chris, Iím just catching up after traveling a bit. When you do it, you do it right.
How did you like AOP?
NHfireLJ likes this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #634 of 635 Old Yesterday, 07:33 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Welding the tubes to the center section causes a stress riser from HAZ. I donít think it would help in this case. I know people do it to keep tubes from spinning (I did it to my old 8.8), but it does induce a lot of stress in that area. There are axle builders that donít weld the tubes for that reason.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #635 of 635 Old Yesterday, 07:53 AM
NHfireLJ
NHfireLJ's Avatar
Most impressive carnage Chris... Sucks to hear.... Good luck w the engine swap and axle swap...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
