Project White Squid --- one ton YJ - Page 33 - JeepForum.com
 280Likes
post #481 of 580 Old 04-29-2019, 06:19 PM Thread Starter
'92 vegas YJ
'92 vegas YJ's Avatar
Looking forward to wheeling pics!
Quick question, how long is your upper link vs your lowers up front? Pic of your frameside bracket?
Sent from my SM-N960U using Tapatalk
All links up front are 32 3/8" bolt hole to bolt hole.
Pics of frame side brackets
'92 vegas YJ is offline
post #482 of 580 Old 04-30-2019, 06:50 PM Thread Starter
'92 vegas YJ
Found my problem with the ARB
This isn't supposed to look like this...
And this sure isn't supposed to fall out when I remove the diff cover.
I believe what happened was when I removed the ARB air line from the bulkhead fitting that the copper tube fell into hole a little further which caused the copper line on the inside to come into contact with the ring gear. I never pulled the cover during the build so I never saw this before I drove it. Obviously driving it around chewed threw the copper tube. I will call ECGS tomorrow and order another seal housing. Only crummy thing is I have to pull my carrier to replace it, which means tearing my axle all the way down... ugh.
post #483 of 580 Old 04-30-2019, 07:37 PM
NHfireLJ
NHfireLJ's Avatar
Ugh, at least its a relatively easy fix..
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #484 of 580 Old 05-01-2019, 03:49 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Blue tooth lockers?
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #485 of 580 Old 05-01-2019, 08:13 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Wouldn't have happened to a Detroit.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #486 of 580 Old 05-01-2019, 05:51 PM Thread Starter
'92 vegas YJ
Easy, just time consuming.
Originally Posted by 87TPIYJ View Post
Blue tooth lockers?
Yea, they're the new hotness.
You're right. I enjoy having a selectable locker though. I've had auto lockers in the past and they're a pain anytime between obstacles. This damage was my fault, i messed up when I pulled the fitting and reinstalled. I know now what I did wrong and I cant blame anyone but myself.
post #487 of 580 Old 06-10-2019, 01:17 PM Thread Starter
'92 vegas YJ
Have a trip coming up soon so I wanted to knock a few things out real quick.
First thing I did was install some rock lights. These are the All4offroad lights. http://all4offroad.com/index.html
Then I built a spare rear driveshaft. After my 1st trip out where I busted a driveshaft yoke I've always been a little worried about my driveshafts.
Went to the JY and picked up a ZJ front driveshaft for $30
Cut out the stock 1.75x.120 tubing and replaced it with some 2x.250" DOM cut to the length I needed which was 19.5" for a overall static driveshaft lenth of 34.75"
here's a picture of the stock tube cut out and the slip yoke already pressed into the new shaft tubing
And then I welded it up and installed a brand new axle side 1350 Ujoint. Also in this picture is a new 1350 yoke with new 1350 Ujoint as a spare for my front driveshaft and 2 spare 1310 ujoints for my Tcase side.
Sorry I didn't take more pictures of the whole build process but it really wasn't that hard and only took about 2 hours from start to finish. The driveshaft is now painted and hanging up to dry.
post #488 of 580 Old 06-16-2019, 07:48 PM Thread Starter
'92 vegas YJ
Used the Jeep the other day to help cut some trees down at my house.
Then today I threw the Jeep on some scales to see how thick she is. My guess was 5,000#. Looks like I was pretty spot on as she ended up at 5,011 pounds. That is with a full tank of gas and all of my trail tools loaded up. Pretty decent front/rear and left/right in my opinion. Again pretty much what I thought it'd be.
total without me inside
and 5,189# with me inside
53/47% front/rear
and pretty much 50/50 left to right
bgredjeep and NHfireLJ like this.
post #489 of 580 Old 06-17-2019, 09:24 AM
daddyjeep87
1987 YJ Wrangler
178.... Somebody better give you a burger and a beer.
YJOTM August 19
post #490 of 580 Old 06-23-2019, 01:54 PM Thread Starter
'92 vegas YJ
Had a great weekend at Big Dogs again. Jeep is performing awesome and I really have nothing to complain about so far. I am straight mashing this rig offroad and she keeps giving me everything she has. I did have a problem with my clutch master cylinder that ended my weekend early but stuff happens. There was plenty of wheeling this weekend and plenty of carnage for the guys in my group.
Onto some pics
87TPIYJ and NHfireLJ like this.
post #491 of 580 Old 06-23-2019, 02:09 PM Thread Starter
'92 vegas YJ
Jeff coming through Bunny Crack
Tyler almost flopping his rig
And Scott did flop his rig
Tyler replacing a red label
And loaded up after some clutch master cylinder issues
Total carnage for the weekend was a 35 spline SD D60 stub shaft, 35 spline Yukon hardcore hub, (1) 39" red label with sidewall puncture, (1) front driveshaft, (1) PSC steering pump, (1) ARB locker air line, (1) subwoofer and amp, (1) clutch, (1) clutch master cylinder and a trailer tire. The only 2 things that were weekend show stoppers that we didn't have spare parts for were the clutch on Scott's Jeep and the master on mine.
NHfireLJ and Bong_Holyeo like this.
post #492 of 580 Old 06-23-2019, 02:11 PM Thread Starter
'92 vegas YJ
Couple videos
bgredjeep likes this.
post #493 of 580 Old 06-23-2019, 02:22 PM Thread Starter
'92 vegas YJ
I'll always take a free burger and beer.
daddyjeep87 likes this.
post #494 of 580 Old 06-23-2019, 02:22 PM
NHfireLJ
NHfireLJ's Avatar
Couple videos
Sweet...
Lil bit of skinny pedal eh....
SOLD
style intake
NHfireLJ is offline
post #495 of 580 Old 06-23-2019, 02:52 PM Thread Starter
'92 vegas YJ
Sweet...
Only way to get through some spots.
