my first build could use help 1995 jeep wrangler - JeepForum.com
post #1 of 36 Old 05-01-2013, 02:34 AM Thread Starter
mshows577
2016 JK Wrangler
So about 8 months ago i spent every dime in my savings to buy a 1995 jeep wrangler, 2.5l 4 banger, stock worn out suspension, stock tires, stock wheels, paint fading on the hood, rust all over the undercage(not deep rust just surface)
So this summer i start an internship and will be making pretty decent money and all of it is going to go to my jeep. Work all week and build all weekend. there is a lot i want to do and i dont have a whole lot of experience.
mshows577 is offline
post #2 of 36 Old 05-01-2013, 02:43 AM Thread Starter
mshows577
2016 JK Wrangler
My jeep right after I got it. Found the rims in Craigslist and put them on that day
post #3 of 36 Old 05-01-2013, 02:45 AM Thread Starter
mshows577
2016 JK Wrangler
Got it a little muddy the next day.
post #4 of 36 Old 05-01-2013, 02:49 AM Thread Starter
mshows577
2016 JK Wrangler
Everything I have done so far. American racing rims from Craig's list(200) bran new guard dog 31 inch mudders from treadwright(600) seat covers(100)
post #5 of 36 Old 05-01-2013, 02:50 AM Thread Starter
mshows577
2016 JK Wrangler
Another picture of it now
post #6 of 36 Old 05-01-2013, 02:55 AM Thread Starter
mshows577
2016 JK Wrangler
Things I want to do this summer( lift, side bars, light bar, lights, carpet, new sound bar, new waterproof stero, fix the doors, hard top, fix any rust, and I'm open to suggestions if y'all have some for me.
post #7 of 36 Old 05-01-2013, 02:59 AM Thread Starter
mshows577
2016 JK Wrangler
As far as the lift goes. It's the first thing I wanna do. I will have money but not crazy amounts so I'm looking at either the RC 2.5 and maybe a 1 inch body or the RC 4 inch. I'm worried that the 2.5 kit will need (break line extensions potman arm extension and transfer drop kit which it does not come with, but I'm also worried that if I get the 4 inch it will look bad with only 31 tires. And it's my DD so I don't wanna go over 31 and it lose all it's power. Suggestions and comments would be appreciated
post #8 of 36 Old 05-01-2013, 09:13 AM
Shipbane
Well for starters you could always save that money for an engine upgrade and just do a spring over for starters. My future DD in ny garage will run 33s with a base spring over and a possible 1" body lift. But even going up to a 4.0 HO will show a difference in that jeep. Not to mention you can find decent ones on cl in older cherokees pretty cheap. And keep an eye out for an ax15 trans attached to that 4.0 and go from there. I wouldn't worry much about the lifting before I got all the power I wanyed, and just go basics. Sort the rust, check on a new drive train, upgrade the front and rears with spring over set up already and then worry over lifts.
Shipbane is offline
post #9 of 36 Old 05-01-2013, 09:30 AM
Randonexplosion
Randonexplosion's Avatar
A proper Spring Over is going to cost more than a 4" "kit". SOA generally gives around 5" of lift on stock springs. You would need to change steering accordingly, brake lines and SYE/ CV driveshaft. If you are wanting to keep it small I would suggest some quality 2-2.5" springs (OME, BDS).
Nice looking YJ!
Randonexplosion is offline
post #10 of 36 Old 05-04-2013, 02:59 PM Thread Starter
mshows577
2016 JK Wrangler
Probably gonna go with the 2.5 lift. And seriously thinking about painting it blue and doing. Full new black interior. It needs new seats and carpet anyway
post #11 of 36 Old 05-04-2013, 03:03 PM Thread Starter
mshows577
2016 JK Wrangler
I would change the engine. Only problem I have is that everything I do to the jeep has to be done one weekend at a time. It's the only vehicle I have to get to work with. I'm not good enough to do an engine swap in that short amount of time
post #12 of 36 Old 05-17-2013, 07:17 AM Thread Starter
mshows577
2016 JK Wrangler
so i just bought a hardtop on craigs list. now my next step will be to buy a rear bumper and tire carrier. i would much prefer to buy a tire carrier that opens with the tailgate. maybe somehting that mounts to the brackets that hold up the tailgate? and a new back bumper with d rings and a hitch. any suggestions? and i would like to keep it on the lower side of the money spending too
post #13 of 36 Old 06-04-2013, 06:54 AM Thread Starter
mshows577
2016 JK Wrangler
got my hardtop last weekend! 400 on craigslist. its not the prettiest in the world and needs some tlc but its solid and has all the glass(or the plexiglass whatever its called) i already ordered my new front bumper(199 from truck and winch) and this weekend i will be ordering either a 2.5 inch lift from rough country or my back bumper with swing out tire carrier. i havent decided yet
post #14 of 36 Old 06-04-2013, 06:55 AM Thread Starter
mshows577
2016 JK Wrangler
spend allllllll weekend changing the u joint in the front right axel. took me 2 days to break the 36 mil bolt and the 3 bots holding on the chunk. but i finaly did it and got the axel out. had to take it to a place and let them put the new u joint in i couldnt seem to get the dang pins out.
post #15 of 36 Old 06-07-2013, 06:19 AM Thread Starter
mshows577
2016 JK Wrangler
just got a new front bumper!!!! i bought the tuff stuff front winch bumper from ebay. ebay wouldnt let me pay for it so i called truck and winch and they let me order it from them for the 215 price i got it at on ebay. so it just came in yesterday and i got it halfway installed. heres my review of it. its made of 3/16 steel so thats good. whats not so good is they completly welded the front grinded it down and painted it. but they did not completly weld the back of the plates. not a problem if your not going to put it through serious abuse. or if u have a welder and dont mind finishing the back of the bumper up. it was pretty heavy. i say around 60 lb. which is good, heavy duty but not super heavy on the jeep. now for the mounting. it has tabs that go on the top of the fram and the bottom. and 6 bolts. that screw directly into factory threaded holes on the frame. it is a ***** the put the new bolts into 17 year old threaded holes. and the tabs need work. mine are about a quarter inch too wide so i have to grind down the outside of the tab and the holes for the bolts. but all and all for 200 bucks i cant complain much. plus it might be my jeep frame that is messed up not the tabs. but who knows.
