LJ Resurrection - Page 3 - JeepForum.com
 74Likes
post #31 of 134 Old 12-06-2019, 11:42 PM Thread Starter
g23crawler
Got the one I had mounted. Pretty easy and dog approved.
NashvilleTJ likes this.
g23crawler is offline
post #32 of 134 Old 12-10-2019, 07:26 AM Thread Starter
g23crawler
Got all 4 tires mounted last night. Need to move the tank back and start mocking up the rear 4 link.
post #33 of 134 Old 12-10-2019, 10:09 PM
MetalMountainGoat
MetalMountainGoat's Avatar
Going to be beast. Love the look of this jeep.
MetalMountainGoat is offline
post #34 of 134 Old 01-24-2020, 10:19 PM Thread Starter
g23crawler
Been busy with work and waiting on parts. Motobilt 4 link is here, atlas still a 3-4 weeks out, engine and tranny still a week to two out. In the mean time got the engine and tub pulled, started mocking up the 4 link kit. Hope to get the frame all cleaned up and start mocking up all the suspension in the next week or two.
07wurubi likes this.
post #35 of 134 Old 01-26-2020, 07:22 PM Thread Starter
g23crawler
Got the frame cleaned up, also cut the rear cross member out and moved the tank back 5". Need to take my brackets to work tomorrow and drill out all of the holes to 5/8". Also the motobilt kit uses 1.75" width top joints. Going to order the new currie joints for the top.
07wurubi and intrepidroad like this.
post #36 of 134 Old 01-27-2020, 04:02 PM
MetalMountainGoat
When you said simple build earlier in this post, I wasn't expecting the tub to be removed...lol.
post #37 of 134 Old 01-27-2020, 04:13 PM Thread Starter
g23crawler
I also wasn't expecting to have a big power plant, atlas and fancy 4 link system lol. As far as the tub, it was actually really easy, since I already had the motor pulled I took out the 6-8 body bolts and used the cherry picker to move it over. Only took me and a couple buddies 30 minuets and few too many beers. Im glad I did it, will make welding and mocking stuff up alot easier.
post #38 of 134 Old 01-28-2020, 12:27 AM
intrepidroad
That looks massive. Incredible jeep you got there.
intrepidroad is offline
post #39 of 134 Old 01-28-2020, 08:37 AM
snobrder540
snobrder540's Avatar
this is a 'simple build' WOW I'm following along!!
snobrder540 is offline
post #40 of 134 Old 02-01-2020, 04:43 PM Thread Starter
g23crawler
Nothing to crazy, rear 4 link mocked up. Started to pull the LS1 for the jeep.
post #41 of 134 Old 02-17-2020, 08:12 AM Thread Starter
g23crawler
Rear 4 link is done, waiting on engine and tcase to mock up the front.
post #42 of 134 Old 02-17-2020, 08:13 AM Thread Starter
g23crawler
Pics
post #43 of 134 Old 02-17-2020, 08:25 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Nice. Did you run your rear numbers through a 4-link calculator?
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #44 of 134 Old 02-17-2020, 08:31 AM Thread Starter
g23crawler
I played with it a little bit but I couldn't tell you what anything means. I wasn't too concerned since the only adjustment I can do is the hole position for the upper links.
post #45 of 134 Old 02-17-2020, 08:46 AM
NashvilleTJ
I miss the snow...
Post it up if you can. It would be interesting to see how the position of the upper frame side mounts impact the anti-squat.
Enjoying your build. Looking forward to seeing the engine work you have planned.
Build Thread:
