Little Red XJ - Page 22 - JeepForum.com
 47Likes
post #316 of 329 Old 03-26-2021, 08:25 AM Thread Starter
RedJeepster1
RedJeepster1's Avatar
Guess the Jeep skipped leg day. New tires are in order.
Sent from my iPhone using Tapatalk Pro
NashvilleTJ likes this.
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Silver XJ, 4.0, AW4 with 350k+, Locked C8.25 w/ Chromos, Trussed hp30, 4.56's, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's
RedJeepster1 is online now
post #317 of 329 Old 03-26-2021, 10:46 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
What are you thinkiní?
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #318 of 329 Old 03-26-2021, 02:02 PM Thread Starter
RedJeepster1
My neighbor retired from Goodyear and was able to get me a big discount on a set of 35Ē MTRís. I picked up a very lightly used set of Black Rhino 17Ē aluminum beadlocks over the winter Iíll be putting the new tires on.
I also have a new locker and a master install kit on the way for the front axle as well. I figured since there was so much metal in the diff, I should just change all the bearings to be safe. I regear axles in the side so doing the work isnít a big deal, just time and $100 worth of bearings.
The locker exploding is actually what prompted the tire purchase. Iím gonna have it all apart anyway, and I already had the wheels...
Kinda crazy that each of these wheels cost more than I paid or the whole Jeep originally.
post #319 of 329 Old 03-31-2021, 07:17 AM Thread Starter
RedJeepster1
Picked up the tires yesterday. I have some work ahead of me getting them mounted. The outer bead is fighting me to get seated. Going to try something a little different today. I got them home pretty late last night and didnít want to fight with them.
post #320 of 329 Old 03-31-2021, 10:26 AM Thread Starter
RedJeepster1
Got one mounted up at lunch today. Took about an hour. 3 more to go.
NashvilleTJ and underscore like this.
post #321 of 329 Old 03-31-2021, 11:22 AM
NashvilleTJ
I miss the snow...
Thatís pretty sweet, Red.
Build Thread:
post #322 of 329 Old 03-31-2021, 06:33 PM Thread Starter
RedJeepster1
a little flashy for my usual style but I definitely like them.
underscore likes this.
post #323 of 329 Old 04-07-2021, 07:09 AM Thread Starter
RedJeepster1
Converted the front axle to 5x5 lug pattern. Since I already run WJ knuckles, it was pretty easy to just swap on the WJ unit bearings. No more spacer /adapters in the front. I also replaced my broken front locker while the axle was apart. I still need to convert the rear axle to 5x5. So currently the rear has spacers.
As you can see a little wider in the rear. Still narrower than most JKís though.
post #324 of 329 Old 04-07-2021, 08:41 PM Thread Starter
RedJeepster1
The doors seem to have fallen off it.
post #325 of 329 Old 04-09-2021, 11:45 AM Thread Starter
RedJeepster1
Stopped by a friends yesterday to check out his Comanche and realize that with my new tires I had a bit of a fender clearance issue. As the bump stop started to compress, the tire was getting into the fender a little bit.
And this was before the bump stop had too much load on it because the rear wasnít stuffed yet.
Resolved this issue today the way all XJ owners resolve fender clearance issues. With the angle grinder. This is the nee cut line. If I want any more up travel Iíll have to start modifying the inner fender.
post #326 of 329 Old 04-09-2021, 05:17 PM
xjloverforlife8
Honestly, the tires look terrific. Once you out them in the proper shape, please share some photos!
xjloverforlife8 is offline
post #327 of 329 Old 04-09-2021, 05:18 PM
xjloverforlife8
OMG the Jeep looks gorgeous! On the other hand, that red color in the tires is definitely a nice touch.
post #328 of 329 Old 04-09-2021, 07:06 PM Thread Starter
RedJeepster1
Thanks! Feels good to be working on the Jeep again. Iíve been working on other peoples Jeeps for months with no time for my own. Iím taking it out wheeling tomorrow.
post #329 of 329 Old 04-12-2021, 05:05 AM Thread Starter
RedJeepster1
Well I gave the Jeep a good workout on Saturday. It performed flawlessly. I was late getting there and forgot to refill my CO2 bottle on Friday so I just threw it in 4low and wheeled at street pressure. Surprisingly the tires hooked up way better than my old set, even at 26 lbs. I got hung up a few times but never had to pull cable. Overall a great day out in the woods. And the Jeep had no issues driving home at 75 mph afterwards.
