Little Red XJ - Page 19 - JeepForum.com
 37Likes
post #271 of 302 Old 04-29-2019, 05:37 AM Thread Starter
RedJeepster1
RedJeepster1's Avatar
Originally Posted by Mhixson View Post
Nicely done! Anxious to see how they perform.
Thanks! Me too. Today and tomorrow I have to install a new engine harness and my detroit locker in the front. Wednesday is just to finish up anything that's left and Thursday I'm driving it 5 hours to Rausch Creek in PA to go wheeling for a couple days. Between the drive down and a few days of wheeling, it should be a good break in to see how the new setup performs.
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Silver XJ, 4.0, AW4 with 350k+, Locked C8.25 w/ Chromos, Trussed hp30, 4.56's, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's
RedJeepster1 is offline
post #272 of 302 Old 04-29-2019, 12:15 PM
dougcherokee
1994 ZJ
Over 300k!! They weren't screwing around when designing those engines.
dougcherokee is offline
post #273 of 302 Old 05-01-2019, 03:06 AM Thread Starter
RedJeepster1
So while I was waiting for my friends dad to show up yesterday to help with the sensor, I knocked out a couple small things that needed to get done before the trip. For one, I found out I had installed my new shocks upside down. I assumed the shaft needed to go up and the body down, but I found out that was not correct. While I was flipping them I measured to find out how close I had gotten on picking the correct length. This picture is full droop on the leafs. I had 3/4Ē of shock travel left.
And this is approximately ride height. Realistically it will settle another inch or two once there is weight in the back. The Jeep was completely empty and Iíll be traveling with tools and spare parts in the back.
Next I worked on putting my plastics back together in the back of the Jeep and getting the rear seat back into position. And finally I cut off the old lower shock mounts. No longer anything hanging below the axle. I was always dragging these brackets on the rocks so Iím looking forward to having them gone.
Planning to drive the Jeep to work today just to make sure nothing else is acting up. Itís good to have it back in good tuning condition.
Sent from my iPhone using Tapatalk Pro
post #274 of 302 Old 05-01-2019, 04:58 AM Thread Starter
RedJeepster1
I also did figure out the issue with the sensor. He was able to confirm that the sensor itself was functioning and that the wiring was working properly, which is what I had tested for prior to him getting there. What we determined that I couldn't though was that the signal coming out of the sensor was not changing with the sensor. He determined that another sensor was back feeding the circuit and causing the issue. Upon a little more investigation we figured out that it was the clock spring causing the issues. It had gotten wet after the Jeep got rolled and sat outside with no windshield and because of that went bad. We unplugged the clock spring and the Jeep is running perfect again. Drove it 50 miles to work today and it back to it's normal self. Cooling system is completely sorted and the running issues are fixed. Almost ready for Rausch in 2 days.
post #275 of 302 Old 05-01-2019, 06:37 PM Thread Starter
RedJeepster1
Installed the Detroit after work today. Just under 3 hours start to finish. Tested it out and it seems to be working as intended. So Jeep is now officially locked front and rear.
NashvilleTJ likes this.
post #276 of 302 Old 05-02-2019, 12:10 PM Thread Starter
RedJeepster1
Ran down to the scale quick before I loaded the Jeep for Rausch. Iíve always wondered what this Jeep weighed with all the extra steel welded to the frame.
post #277 of 302 Old 05-04-2019, 01:09 PM Thread Starter
RedJeepster1
Having a blast this weekend. Iíll have more pics this week.
post #278 of 302 Old 05-04-2019, 01:37 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
She's a porker now 20% over birth weight lol. Mine clocks about 5k locked and loaded. Looking good this weekend!
RedJeepster1 likes this.
***Chris***
chris87xj is offline
post #279 of 302 Old 05-06-2019, 09:09 AM Thread Starter
RedJeepster1
Picture dump from the weekend. Drove the Jeep down, aired down, wheeled for 2 days, aired up, and drove 300 miles home. Never turned a wrench. We all had an absolute blast and laughed so hard my stomach hurt. Doesnít get any better than this.
Jakegrovephoto likes this.
post #280 of 302 Old 05-17-2019, 09:27 PM Thread Starter
RedJeepster1
Wasnít planning to work on the Jeep today but when I opened the trunk to put my spare shafts in there, I found the ambition to build a spare tire carrier. No more ratchet straps needed. And itís way more secure. When I tighten the center bolt, it squeezes the tire against the bar and makes it super solid.
jordanperkins03 likes this.
post #281 of 302 Old 05-18-2019, 08:17 PM Thread Starter
RedJeepster1
Had some fun with the Jeep today on the black trail at go topless day.
post #282 of 302 Old 05-31-2019, 06:25 AM Thread Starter
RedJeepster1
Here’s some footage from my trip to Rausch a couple weeks ago. One of the guys has a YouTube channel and put a short video together. It was the break in run for his Jeep, the Black TJ on 40’s.
post #283 of 302 Old 06-01-2019, 11:07 AM Thread Starter
RedJeepster1
Rausch day 2
post #284 of 302 Old 06-02-2019, 11:02 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Weekends don't get much better than that. Excellent group of jeepers there.
***Chris***
post #285 of 302 Old 06-02-2019, 11:06 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Way to drive that ***** like you stole it and getter dun!
***Chris***
