Jmart2119's Black Beauty Build - Page 59 - JeepForum.com
 220Likes
post #871 of 920 Old 06-09-2019, 09:06 PM Thread Starter
jmart2119
jmart2119's Avatar
Well I guess this is happening. As much as I donít want to do the work, it makes the most sense to fix all the tub damage. Plus my tub had plenty of rust and other issues before the roll.
Picked this thing up today for $375. It has one small rust spot above the rear passenger opening and one dent on the passenger side rocker. He cut two of the heads off the bolts for the two body mounts in the middle. Other than that it is in perfect shape, so well worth the price and the work.
The opening above the rear wheel is gonna get cut out for larger wheel openings anyway and the dent is gonna get covered by my rocker guards. Iíll weld a couple bolts to the seized body mounts and pull them out.
Gonna prep this tub and get it ready to go over the next couple weeks. Monstaliner is on order for the inside of the tub and gonna repaint the firewall and underside of the tub, then knock out the swap over the weekend.
2018 YJ of the Year
YJOTM | Aug'15 | Dec'16 | Jan'18
1989 YJ - 98 5.7L Vortec, 4L60E, NP241, D30+8.8, 5.13's, 35" ProComp MT2's
jmart2119 is offline
post #872 of 920 Old 06-10-2019, 04:40 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Unlimited stretch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
Randonexplosion and Luuca like this.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #873 of 920 Old 06-10-2019, 10:34 AM Thread Starter
jmart2119
jmart2119's Avatar
that is not happening!
2018 YJ of the Year
post #874 of 920 Old 06-10-2019, 11:34 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Its the perfect time too.
jmart2119 likes this.
87TPIYJ is offline
post #875 of 920 Old 06-10-2019, 12:14 PM Thread Starter
jmart2119
jmart2119's Avatar
There is no doubt that this would be the perfect time for it. However, it has never been in my plans. Your rig is just nasty and looks great(and Im sure will wheel great), I have just always wanted to keep mine in stockish jeep form and prefer the stock length tub look.
87TPIYJ likes this.
2018 YJ of the Year
post #876 of 920 Old 06-10-2019, 11:41 PM
JeepinJeff72
JeepinJeff72's Avatar
Hey jmart. Was glancing through your thread. I need to read it through. Good job man! Louvres aren't for me (not mine) but otherwise I like. Is the coupler at the bumper lead from on-board compressor or nitrogen tank? Whichever, where did you install it? That's awesome.
Sent from my SM-N950U using Tapatalk
JeepinJeff72 is offline
post #877 of 920 Old 06-12-2019, 02:27 PM Thread Starter
jmart2119
jmart2119's Avatar
Thanks. It is for OBA. The tank is mounted on the underside of the tub.
2018 YJ of the Year
post #878 of 920 Old 06-19-2019, 05:24 PM Thread Starter
jmart2119
jmart2119's Avatar
Making some slow progress on the tub. Just working on it a couple hours at night after work and on the weekends when time allows.
I got all the stock wiring harness, flares, stock side steps, tailgate and windshield hinges (did I mention I hate torx heads) and firewall items stripped off the tub and firewall:
There was some surface rust and pitting in the drivers side floor pan so I hit it with a wire wheel and Iíll spray it with some rust inhibitor:
Went out and pulled my tcase shifter so I could measure the opening for it and got that marked and cut out:
As well as the fuel pump access cutout:
Then borrowed my buddies pressure washer and got all of the dirt, grime and grease blasted out of the tub:
2018 YJ of the Year
post #879 of 920 Old 06-19-2019, 05:31 PM Thread Starter
jmart2119
jmart2119's Avatar
This thing has so many holes drilled in from the PO and from the stock side steps:
Both rear fender tops look like this:
He had a ton of footman loops installed in it and the holes for the stock side steps:
I decided I donít want all of these holes in it so I figure it was time to invest in a MIG welder so I ordered up a Hobart Handler 140 and it showed up yesterday. They were running a rebate for Fatherís Day for a free cart with it so once that comes in, I will be all set.
So the next step is to go down and get some .024 wire and C25 gas so I can get all these holes welded up.
Then itís on to tub prep and Monstaliner install, then Iíll get to work on the underside of it, then to swapping it onto the frame.
87TPIYJ likes this.
2018 YJ of the Year
post #880 of 920 Old 06-19-2019, 08:18 PM
Randonexplosion
Randonexplosion's Avatar
Looking good man. Sucks that you have to resort to a tub swap but at least everything will be nice and square. 6 points of frame tie in will be pretty high on the list eh?
Sent from my SM-N960U using Tapatalk
Randonexplosion is offline
post #881 of 920 Old 06-20-2019, 10:28 AM Thread Starter
jmart2119
jmart2119's Avatar
Yeah, its gonna be part of the tub swap. I don't plan on the jeep seeing any trails until the frame tie ins are installed. While none of this is hard work, it's very tedious and time consuming and I do not want to be doing this again anywhere in the near future and hopefully not ever.
Randonexplosion likes this.
2018 YJ of the Year
post #882 of 920 Old 06-23-2019, 03:51 PM Thread Starter
jmart2119
jmart2119's Avatar
Picked up some gas and put the new Hobart to use. Got all the holes welded up.
Then I got all of the surface rust out of the floor pans and hit those and the filled holes with rust inhibitor.
And finally started the transformation back to black. Got the firewall and side panels shot with black.
I am out of town for work this week but next weekend, itís time to prep the tub and lay out the Monstaliner.
Then itís time to paint the firewall and flip her over to get the underside ready. Getting closer to tub swap time.
87TPIYJ likes this.
2018 YJ of the Year
post #883 of 920 Old 06-23-2019, 11:34 PM
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Just monstaliner the whole damn thing
Sent from my iPhone using Tapatalk
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #884 of 920 Old 06-24-2019, 11:50 AM
tecksjeep
tecksjeep's Avatar
Don't listen to Azdevil. make that thing pretty!!!! when are we going to prep and spray that bad boy? easy to do it while the tub is off!
5.7 Vortec, D60 front w/ detroit,14 bolt rear w/spool. 16" FOA Coilovers in rear ORI struts in front, Barnes Enduro Joints, Daves custom boat sides/rear armor.
Check out my build here!
tecksjeep is offline
post #885 of 920 Old 06-24-2019, 01:45 PM
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Get out of here traitor!
'95 YJ 2.5L
My Build Thread
-Albert Einstein
