Jeep CJ5 Electric - Page 5 - JeepForum.com
 44Likes
post #61 of 191 Old 03-10-2017, 04:05 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Did that splined shaft unscrew from the armature or did you cut it off?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #62 of 191 Old 03-10-2017, 05:14 PM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
Originally Posted by Fourtrail View Post
What voltage are you planning on running and are you planning on standard 12VDC batteries or a higher voltage battery option to reach the running voltage?
It may sound strange but I do not know.
I intend to do, my project one section at a time. There are so many people who did it I can not believe I would not find a way to do it for my jeep. At the moment I am at the coupling of the engine to the transmission.
It was cut by a machinist
ben-jeep is offline
post #63 of 191 Old 03-10-2017, 05:26 PM
John Strenk
1976 CJ5
I cut it.
Nice cut.
Did you do it on a lathe?
I know you have to make an adapter to duplicate the end of the crank so you can attache the flywheel to the shaft but how are you attaching the adapter to the motor shaft?
Interference fit? a Keyway? Welded?
Is the recess for the end of the clutch shaft coming out of the tranny? Are you going to slip a pilot bushing in there?
[edit] I see you clarified who did the cut. Still a nice job.. [/Edit]
post #64 of 191 Old 03-11-2017, 05:16 PM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
This part I leave it to the machinist. I think it will make me a keyway
ben-jeep is offline
post #65 of 191 Old 03-12-2017, 04:50 PM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
The coupling plate of the electric motor with the transmission just arrived.
Fourtrail likes this.
ben-jeep is offline
post #66 of 191 Old 03-13-2017, 08:04 AM
John Strenk
1976 CJ5
Move to Jeep Builds at the request of ben-jeep.
Keep letting us know whats happening with updates in the "What did I do to my CJ today" thread
post #67 of 191 Old 03-13-2017, 08:50 AM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
I was asked the question: Why not use a straight plate to connect to my transmission?
My electric motor was purchased used. The front part was cracked. The person who engineered the parts proposed to make the missing part of my engine directly on the plate instead of redoing the front face of the engine.
ben-jeep is offline
post #68 of 191 Old 03-14-2017, 02:03 PM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
I just finished reassembling my transmission. It's the turn of the differentials to be inspected and cleaned. When the electric motor will be tested with the new parts, coupling plate and flywheel adapter, I will repaint everything.
ben-jeep is offline
post #69 of 191 Old 03-18-2017, 09:04 AM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
Some photos of the coupling plate manufacturing
ben-jeep is offline
post #70 of 191 Old 03-19-2017, 08:51 AM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
The coupling parts are installed. I fix the transmission and I will be ready to do the first real tests with my electric motor. I will put a video of my test.
John Strenk likes this.
ben-jeep is offline
post #71 of 191 Old 03-19-2017, 10:12 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Subscribed.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
Facebook: Hill’s Angels 4x4 Club
RARECJ8 is offline
post #72 of 191 Old 03-19-2017, 10:23 AM
lovett86
lovett86's Avatar
That's awesome what you're doing
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #73 of 191 Old 03-22-2017, 08:37 AM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
A small error in taking measurements on the adapter. It was necessary to remake other holes to fix the flywheel
ben-jeep is offline
post #74 of 191 Old 03-22-2017, 08:44 AM
stgil
1982 CJ7
Originally Posted by RARECJ8 View Post
Subscribed.
Too! In France , car mod are unlawfull...If not, I would do this mod!
Keep us dreaming!
Regards,
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->https://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #75 of 191 Old 03-22-2017, 08:51 AM Thread Starter
ben-jeep
ben-jeep's Avatar
1975 CJ5
Originally Posted by stgil View Post
Too! In France , car mod are unlawfull...If not I would do this mod!
Keep us dreaming!
Regards,
Gilles
---- Ici, au Québec, modifier un véhicule est TRÈS difficile. Je me lance dans un projet plus qu'incertain (légalement parlant) ----
Here in Quebec, modifying a vehicle is VERY difficult. I embark on a uncertain project (Legally speaking)
ben-jeep is offline
