Jaretstuff’s 2000 XJ “Redemption” Build thread - Page 2 - JeepForum.com
 4Likes
post #16 of 34 Old 11-13-2019, 11:48 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Nice... It's come a long way in a short amount of time.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #17 of 34 Old 11-14-2019, 10:18 AM Thread Starter
jaretstuff
thank you very much. I try to put in a lot of work everyday I can
jaretstuff is offline
post #18 of 34 Old 11-17-2019, 07:44 PM Thread Starter
jaretstuff
Finished the front skeleton of the winch bumper, installed the tank straps and did the front balljoint that was bad. Now it literally just needs the headlights and two brake lines
196CF8C0-1259-4131-8EE7-682DD891C81C_1574041370622.jpg   19C07979-3145-4056-B0DA-6D90F2ABB931_1574041451361.jpg
post #19 of 34 Old 11-23-2019, 09:37 PM Thread Starter
jaretstuff
Well the day has finally come that the build can run and drive. There is definitely still some odds and ends but for the most part it can move, stop, start and run under its own power. I still have to wire the front lights, put the grille insert in, do a tailpipe, add a filler cap/neck, do some spring clamps and redo the front passenger balljoints and rivet the hood pins, and put the interior trim back on
970EEA20-227A-4268-96F3-50E19B2B06BA_1574566590385.jpg   A6EB0DF9-99EC-4BCF-AE7F-D5444BC52E0D_1574566639253.jpg
post #20 of 34 Old 11-30-2019, 08:47 PM Thread Starter
jaretstuff
I decided I wanted to cut the fenders, and I also pulled some dents out. I’ve been having a blast driving it around our property. Here is some pics from now and then when I first got it in September
CA69725B-26F6-46A0-A1CC-A9251692EEE2_1575168383697.jpg   753EECCD-244C-40CE-8975-203028AE7A4A_1575168412808.jpg   0D8C58C7-8758-40BB-B691-B9E8263A8CD3_1575168433005.jpg   D5C9774E-3096-4B55-9AB0-6AFE846942B3_1575168458859.jpg
post #21 of 34 Old 12-11-2019, 07:26 PM Thread Starter
jaretstuff
Not sure what I should do next. Was wondering if you all had some suggestions
post #22 of 34 Old 12-12-2019, 10:12 PM
lovett86
lovett86's Avatar
You could try wheeling the piss out of it and having some fun
daddyjeep87 likes this.
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #23 of 34 Old 12-12-2019, 11:00 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
This actually is the best way to figure out what else needs to be done.
***Chris***
chris87xj is offline
post #24 of 34 Old 12-13-2019, 09:45 AM Thread Starter
jaretstuff
Sounds like a solid plan, I’m excited to get it reliable and dependable.
post #25 of 34 Old 12-13-2019, 12:05 PM
OffRoadDevilD
OffRoadDevilD's Avatar
Rock sliders of some sort are always a good idea and fun to build. Great work so far, I enjoyed following along.
OffRoadDevilD is offline
post #26 of 34 Old 02-14-2020, 05:51 AM Thread Starter
jaretstuff
Here it is
here it is
post #27 of 34 Old 02-14-2020, 05:54 AM Thread Starter
jaretstuff
Still have the old XJ , fighting a sporadic misfire and breaking up issue
B57B7A15-94ED-4207-BE1F-ED0A8EF3C9AC_1581681247762.jpg   91C2BF30-CF4C-4776-8EDD-3A973F1A80B7_1581681263999.jpg
post #28 of 34 Old 02-14-2020, 07:13 AM
daddyjeep87
1987 YJ Wrangler
Might have been a good call changing that diff fluid.
YJOTM August 19
post #29 of 34 Old 02-14-2020, 11:37 AM Thread Starter
jaretstuff
yessir. I did an oil change as well, actually running decent oil for once lol. I need to drain the tank and clean the lines, think I have an injector wire that’s broken somewhere and that’s causing my misfire. I am also going to be doing some aftermarket dom steering and diff breather relocations. Also thinking about doing a Lincoln locker but unsure of at this moment as I don’t like spools
7758E69C-228E-4B6C-A151-6D0D5F5297FE_1581701805903.jpg   27729F91-851E-42D2-A51B-A31B502A7924_1581701832416.jpg
post #30 of 34 Old 02-14-2020, 11:53 AM
daddyjeep87
1987 YJ Wrangler
My wife's WJ was having a misfire issue in reverse only. Turns out that it is quite common. The harness rubs through on a stud on the back corner of the head and grounds out the injectors.
YJOTM August 19
