Impact Orange LJ - Page 19 - JeepForum.com
post #271 of 1924 Old 08-20-2012, 05:55 PM
G Beasley
G Beasley's Avatar
Originally Posted by dayriesw View Post
No, just another front plate from a local for free! He had a 231 minus the rear output assembly and let me rob what I needed (he is out of jeeps and into American Muscle). Just had to give him a hand with removing some stuff from his project for a couple hours.
Very cool , tell him he will be back into a Jeep sooner than later .
G Beasley is offline
post #272 of 1924 Old 08-21-2012, 08:24 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I think he knew. I mean who saves a t-case when you only own muscle?
Went to test drive JKs last night also...
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #273 of 1924 Old 08-21-2012, 08:51 AM
mcannon111
mcannon111's Avatar
A stock jk with a hardtop on drives like a car. I can't decide if I like it or not!
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #274 of 1924 Old 08-21-2012, 08:55 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I test drove an X with soft top, full doors and 6 speed. Man it was sick, but did not feel or drive like any jeep I have owned.....
16 Taco
dayriesw is offline
post #275 of 1924 Old 08-21-2012, 09:58 AM
mcannon111
mcannon111's Avatar
how'd that new engine hit when you gave it some juice?
post #276 of 1924 Old 08-21-2012, 11:39 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
It has so much more power (compared to my worn 4.0).......with the same six speed, I got it up to 65, just shifting into 5th around 60 (shifting at 3g)..... which is where mine shifts into 6th. And it had more power to give.....
16 Taco
dayriesw is offline
post #277 of 1924 Old 08-21-2012, 11:59 AM
B2CARPEN
B2CARPEN's Avatar
I'm a huge fan of our TJ / LJ AMC 242 I6 4.0L. I have around 200,000 miles on mine and it runs incredible, with only some minor modifications and frequent maintenance. It runs better then it did 100k miles ago when I bought it back in 2007, which is unlike most motors that are lucky to even make it to the 200k mark. I will stroke it to a 4.7L when the time comes for an engine rebuild, but unfortunately my engine is running so damn good I don't think that's gonna be happening any time soon
If you want to take the time to tune up your 4.0L let me know and I'll let you in on the mods and maintenance I did to mine.
Founder of
B2CARPEN is offline
post #278 of 1924 Old 08-21-2012, 01:24 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I would love to know what you did. I have done ruteen (sp) maintenance but am willing to do more. Let me know where in your build it is at or what you recommend. btw mine is at 74,xxx averaging 11-12 mpg
16 Taco
dayriesw is offline
post #279 of 1924 Old 08-21-2012, 04:59 PM
B2CARPEN
B2CARPEN's Avatar
Mine is at 196,xxx miles averaging 16 to 17 mgs I no longer have a build thread so I will list out the mods I did that helped my engine perform better here in your build...
For starters, always maintain your oils and filters more then regularly, especially when your mileage starts to get up there.
I replaced the following items that have all contributed to the engine running smooth and minor performance gains...
- Replaced my IAC and thoroughly cleaned out my intake, throttle body, and intake manifold.
- Replaced my standard spark plugs for E3 plugs.. look here for more info about E3 plugs. Don't forget to cover the inside of you plug boots and outside of the plug stems with dielectric grease.
- Replaced my fan clutch since it was seized up and not allowing the clutch to let the fan spin at a slower rpm. This quieted things down a lot and took a ton of extra unnecessary load off the motor. If you can run an electric fan then I would recommend that, or check to be sure your fan clutch is in good condition.
- Run a good air intake with a good filter to allow the engine to breath without sacrificing filteration or particles. I run a true flow enclosed intake and it keeps the manafold and throttle body nice and clean. Stock intake with a good paper filter works well too.. don't run knn.
- One of the biggest mods I did that helped the engine run better was the PSC hood louver. Not only does it prevent heat soak, but it also promotes air flow through the engine compartment and provides your intake with cooler air, vs 210 - 240 degree temps. Without a louver of some sort, the air in the engine compartment has no flow and bakes everything within, robbing performance.
- Replace up-stream O2 sensors, these have a huge effect on how rich or lean your engine runs. I replaced mine due to regular maintenance a while back and I've continued to see good mpg results and power.
Last but not least, be sure to regear based on your tire size. This is the number one performance gain you can do to allow the engine to run at proper rpms while not straining to push those bigger tires. This single task alone made my jeep so much quicker. I'm on 35s w/ 4.88 Yukon gears and a 5 speed trans.
There's more little things here and there that I've done but can't recall at the moment. What I've listed out are the biggest and the most noticable increases with power, performance, and MPGs.
Hope that helps, I'm sure you knew most of these already.
Founder of
B2CARPEN is offline
post #280 of 1924 Old 08-21-2012, 06:35 PM
midnight_f150
midnight_f150's Avatar
Why not?
midnight_f150 is offline
post #281 of 1924 Old 08-22-2012, 10:51 AM
B2CARPEN
B2CARPEN's Avatar
Originally Posted by midnight_f150 View Post
Why not?
I deleted it. I'll prob start a new thread one day when I tackle some of the bigger mods.
Founder of
B2CARPEN is offline
post #282 of 1924 Old 09-02-2012, 08:29 AM
G Beasley
G Beasley's Avatar
Is the new T Case in ?
post #283 of 1924 Old 09-02-2012, 08:46 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
The second new case is in the mail.
This weekend: Pulling the problem one out, putting the other rear axle shaft in and starting on the maintenance listed above/below.
16 Taco
dayriesw is offline
post #284 of 1924 Old 09-02-2012, 08:50 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have done all the rest except for what is listed above. I will have to get to these ASAP. Thanks B2
Edit: pretty sure my mech fan it locked up. Just checked.
16 Taco
dayriesw is offline
post #285 of 1924 Old 09-02-2012, 08:54 AM
G Beasley
G Beasley's Avatar
What the heck ? You have the t case blues !
Closed Thread
Impact Orange Jeep Rjsimms Jeep Picture Requests 50 03-31-2013 07:29 PM
Impact Orange, AC Orange, or Intense Blue. 4x4Mudmonster Jeep Picture Requests 4 08-04-2009 10:19 PM
My New Toy: Impact Orange TJ RHD Chalice Jeep Builds 15 07-21-2006 10:16 PM
Impact Orange Scoobert Jeep Picture Requests 4 10-24-2005 03:41 PM
