The I should be studying build TJ build.. - Page 4 - JeepForum.com
 2Likes
post #46 of 58 Old 12-17-2016, 11:16 PM Thread Starter
00TJTweety
Did a little more modeling tonight.
00TJTweety is offline
post #47 of 58 Old 12-26-2016, 07:49 PM Thread Starter
00TJTweety
Big Progress these past couple days.
I finished the full suspension model in CAD.
post #48 of 58 Old 12-26-2016, 07:58 PM Thread Starter
00TJTweety
Also got all of the brackets welded up
Front lower link frame bracket
Both rear upper link frame brackets
Front upper link frame bracket
Got both lower link axle brackets tacked on to the axle
Also tacked the rear upper link frame brackets into place
Aswell as tacking the truss top plate into place.
post #49 of 58 Old 12-31-2016, 03:10 PM
Mulvihill64
Mulvihill64's Avatar
Nice work! I'm another ME major, currently planning out a similar 3/4 link. Definitely taking notes
Instagram: Mulvihill64
Mulvihill64 is offline
post #50 of 58 Old 01-02-2017, 09:36 AM Thread Starter
00TJTweety
Thanks man, its a process for sure.
post #51 of 58 Old 01-02-2017, 09:37 AM Thread Starter
00TJTweety
These helped start the new year off right. 14" STX ORIs
post #52 of 58 Old 01-16-2017, 08:37 PM Thread Starter
00TJTweety
Been making slow but steady progress. All the rear brackets have been mounted other than the strut brackets.
Full Droop
About a inch till bump. Need to cut the floor to get that extra inch.
post #53 of 58 Old 01-16-2017, 09:53 PM
xgerstandtx
Great looking build. Always good to see TJ's getting the Tons. I may have missed it do you have a body lift? I've got a 1'' on mine and couldn't hardly get by with out it. Makes rear bump way easier and the upper 3 link easier to weld and move in. Only thing I'm really missing that you have is the ORI's. Good work!
xgerstandtx is offline
post #54 of 58 Old 01-16-2017, 10:07 PM Thread Starter
00TJTweety
Thanks man, its a work in progress for sure. I have 1.25" body lift but with it being so low i cant get around cutting into the body. Gonna have to cut into it anyways for the struts to be mounted so no big deal. Hopefully ill get the 3 link mocked up this week. The bracket that I designed should be tight enough to the frame that it wont rub the driveshaft but will see.
post #55 of 58 Old 04-03-2017, 09:45 PM Thread Starter
00TJTweety
It has been awhile since i updated this and the jeep is still unfortunately in pieces...However i have the rear strut mounts in and final welded minus the gussets, crossbar and filling the frame notch. Also got the tub clearanced and the wheelwells cut but i still have to fill everything back in. Right now I am set at 7 inches of uptravel in the rear at a 21 inch frame height.
My front frame also disappeared in the search for uptravel
Here is where i am currently at in the frame rebuild process. Should allow 6.5" of uptravel.
post #56 of 58 Old 10-21-2018, 10:41 PM Thread Starter
00TJTweety
This thread may have died....but i am still kicking it. The build is currently taking a drastic turn towards a 4800/4500 class U4 build. Here are some concept pictures.
Ride Height Suspension With Frame v2 v1.jpg   Ride Height Suspension With Frame v2 v2.jpg   Ride Height Suspension With Frame v2 v3.jpg
post #57 of 58 Old 10-23-2018, 12:07 PM Thread Starter
00TJTweety
Basic Plan:
Engine: 4.0
Transmission: NV3550
Transfer Case: 3.8 to 1 two speed atlas. Hydraulic Cutting brake.
Front axle: 79 HP Dana 60 5.13 Gears. Spartan Locker. 35 spline chromoly shafts. Reid Knuckles. Artec Highsteer Arms.
Rear Axle: Shaved Eaton HO72. 5.13 Gears. Factory NO-SPIN locker.
Tires: Currently 40" Bias Maxxis Trepadors. 37" Bias Trepadors with Procomp Vapor beadlocks for racing.
Steering: 1.75" x 8" PSC Ram. PSC Pump setup. Stock TJ steering box ported for Hydro Assist. Astro Van pitman arm.
Suspension: Barnes 4x4 Enduro Joints. 2" .25 wall Links. 3 Link front. 4 link Rear. 14" ORI Struts. Reservoirs will be added later.
Fuel: 32 Gallon JAZ fuel Cell. In tank pump with a pickup in a each corner.
Cooling: Rear Mounted 33x19 Dual Pass radiator. Ford Windstar Fan.
MISC: Sparco EVO composite seats. HANS device. Sparco Harnesses. RIGID Radio setup. RIGID air pumper.
post #58 of 58 Old 10-23-2018, 12:13 PM Thread Starter
00TJTweety
Also, here are my final suspension numbers if anyone is curious.
