Holm-z's TJ build... work in progress - Page 20 - JeepForum.com
post #286 of 298 Old 10-20-2016, 09:33 PM Thread Starter
Holm-z
Holm-z's Avatar
Did some extra mods in the last few weeks. Added some LED marker/turn signal lights to my light bar. Lots of wiring and adding diodes and resistors thanks to some links here on JeepForum. I think it came out pretty good. Name:  image-2540136679.jpg
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #287 of 298 Old 02-09-2017, 12:23 AM Thread Starter
Holm-z
Holm-z's Avatar
Went out for a drive the other day and noticed my heat wasn't working. So today I flushed the heater core and now I have heat again! I also installed some limb risers I got for xmas.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #288 of 298 Old 02-22-2017, 01:25 PM Thread Starter
Holm-z
Holm-z's Avatar
It was a nice warm pre-spring day yesterday so I decided to take it out for a drive.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #289 of 298 Old 02-25-2017, 09:48 AM Thread Starter
Holm-z
Holm-z's Avatar
Changed the fluid in the transmission, engine and both diffs. Everything looked pretty good so that's a good sign! Next will be the transfer case... Name:  image-1096657024.jpg
Size:  484.0 KB Name:  image-1279487173.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #290 of 298 Old 02-25-2017, 09:49 AM Thread Starter
Holm-z
Holm-z's Avatar
I also installed a rugged ridge front diff skid plate. Name:  image-785146526.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #291 of 298 Old 02-27-2017, 07:43 AM
dylanbob87
looks good!
dylanbob87 is offline
post #292 of 298 Old 03-02-2017, 11:41 PM Thread Starter
Holm-z
Holm-z's Avatar
Originally Posted by dylanbob87
looks good!
thanks man! It's getting there slowly as time and funds allow.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #293 of 298 Old 03-02-2017, 11:46 PM Thread Starter
Holm-z
Holm-z's Avatar
I also added some LED reverse lights onto my rear bumper. Name:  image-3721964206.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #294 of 298 Old 07-11-2017, 06:26 PM Thread Starter
Holm-z
Holm-z's Avatar
Installed a oil pan skid tonight.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #295 of 298 Old 07-11-2017, 06:31 PM Thread Starter
Holm-z
Holm-z's Avatar
Size:  611.9 KB Club ride we went on for Red Line Jeeps in Maine. Took home a trophy for biggest club! Name:  image-627629398.jpg
Size:  683.2 KB Name:  image-2272604178.jpg
Size:  733.9 KB Name:  image-4217680046.jpg
Size:  394.1 KB Name:  image-845851391.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #296 of 298 Old 08-09-2017, 11:16 PM Thread Starter
Holm-z
Holm-z's Avatar
Installed a ZJ steering set-up. I also put a new bumper and steering box skid plate on. Name:  image-1888625552.jpg
Size:  440.3 KB Name:  image-2709812855.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #297 of 298 Old 10-03-2017, 06:44 PM Thread Starter
Holm-z
Holm-z's Avatar
Made a relay/fuse board to clean up some of the wiring mess I've had. I used a cutting board and mounted all the relays and fuse block then meticulously wired everything in. It came out pretty good I think. I have it mounted to my heat shield for my intake. I currently only have one picture of it, I should take more.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #298 of 298 Old 10-15-2017, 02:58 PM Thread Starter
Holm-z
Holm-z's Avatar
I replaced the rear brakes/shoes and the rear axle/pinion seals as they were starting to leak. Put a front wheel bearing on and also re-routed the air filter for my ARB compressor up by my air intake/switch board. Name:  image-1546202288.jpg
Size:  600.3 KB Name:  image-1321835915.jpg
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
1998 , nh , sport , tj , wrangler
My 97 TJ Build Current Work in Progress TinkerAB Jeep Builds 12 08-20-2011 03:55 PM
A Work in Progress... 04TJrubicon Jeep Builds 7 12-11-2009 09:18 AM
My 98 TJ, work in progress alex32TJ Jeep Builds 3 09-01-2009 01:04 PM
Another build in progress. AZ Bulldog Jeep Builds 5 12-04-2007 05:04 PM
Work in progress jeepnurse Jeep Builds 5 05-15-2006 08:32 AM
