A Hokies 04' TJ build - Page 50 - JeepForum.com
 1Likes
post #736 of 748 Old 12-06-2017, 11:29 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Originally Posted by jeepinhokie View Post
Fantastic video. I wish I was closer to Rausch.
Sent from my iPhone using Tapatalk
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #737 of 748 Old 01-16-2018, 09:02 AM Thread Starter
jeepinhokie
jeepinhokie's Avatar
Got the Poison Spyder lazer fit roll cage installed over the long weekend. I feel much better about bringing my kids along with me in the Jeep. I'm not going to change the way I drive because of the cage, just more protection for myself and the kids.
Down the line, I may cut out the plated A-Pillar and run a tube instead. Also plan to tie it into the frame at some point.
Next Wheeling trip is in two week to Gore.
HOKIES UNITED!
jeepinhokie is offline
post #738 of 748 Old 01-16-2018, 11:32 AM
NashvilleTJ
I miss the snow...
Thatís exactly what I wound up doing with my PS cage.
Build Thread:
post #739 of 748 Old 01-16-2018, 01:35 PM Thread Starter
jeepinhokie
Did you buy a tube or have someone locally bend you one?
HOKIES UNITED!
post #740 of 748 Old 01-16-2018, 02:07 PM
NashvilleTJ
I miss the snow...
All custom - bent it myself. I cut the a-pillar off where it meets the top bar, and welded in the new downtube and grab handle with the rest of the cage still in place. Worked well, and no interference with the vents if you position the new a-pillar tube correctly.
I also added a tubing connector in the a-pillar below the level of the dash so that I can remove the cage if need be without fully removing the dash. If not for that connector, the plate at the bottom of the tube would keep you from lifting it straight up and out through the dash.
Build Thread:
post #741 of 748 Old 05-07-2018, 09:45 AM Thread Starter
jeepinhokie
Took a day trip to Rausch Creek to celebrate by son's 3rd birthday. He loved it. Up and back from my house in southern MD makes for a long day though.
Towards the end of the day the LSD inside the rear locker was making one hell of a racket. Tore it apart when I got home and found chunks of metal in the diff. Its been going out for awhile I suspect. Nothing to repair, so no sense in taking the time to open the locker and diagnose further.
Ring and pinion and all bearings look good. I have a line on a front locker to slap into the rear. going to order a master install kit and swap over my gears to the new locker and get it set up at a shop.
Need to get it repaired before another big trip in two weeks with my club to the Cove.
HOKIES UNITED!
post #742 of 748 Old 05-08-2018, 06:31 AM Thread Starter
jeepinhokie
Birthday Boy on the back side of shoot the moon.
HOKIES UNITED!
post #743 of 748 Old 06-16-2020, 09:55 PM Thread Starter
jeepinhokie
Destroyed something in the rear end this weekend. Probably the locker. I got 2 years out of a stock front Rubicon locker in the rear.
Once I’ve taken it apart and I’ve confirmed it’s the rear I’ve got some decisions to make. To dump more money into the d44 or swap in a narrower d60.
I’ve got a lot of time and custom set up into the d44 and it should be able to hold up to my 35’s with an ARB.
HOKIES UNITED!
post #744 of 748 Old 06-16-2020, 09:56 PM Thread Starter
jeepinhokie
Top of hammer of the gods at Doe Valley
HOKIES UNITED!
post #745 of 748 Old 06-22-2020, 06:31 PM Thread Starter
jeepinhokie
Lockers spider gears crapped out. Time to replace the locker or whole axle. Decisions decisions.
HOKIES UNITED!
post #746 of 748 Old 06-22-2020, 06:32 PM Thread Starter
jeepinhokie
Also twisted the splines on the passenger side pretty good.
HOKIES UNITED!
post #747 of 748 Old 07-22-2020, 08:56 PM Thread Starter
jeepinhokie
Got the axle ready for the 35 spline upgrade.
Had to drill out the ARB for the larger ring gear bolts.
Closed off the existing sensor switch with a 1/4 NPT oil pan plug.
Removed and closed off the existing air line bulkhead fitting.
Drilled a 1.75” hole in the 1/2” thick truss so I can access the housing to drill for the ARB bulkhead fitting. Then tapped for a 1/4 NPT.
Just about ready to set up the Backlash on the new locker and slap it back together.
4 new Duroflex bushings arrived today as well. Will swap those out before I put the axle back under.
60B2D540-4B3B-4715-BCCF-0DE10B766AA2_1595472795152.jpg   F1CAC821-D1C5-4A76-95BC-A8EDF84106F8_1595472820374.jpg
HOKIES UNITED!
post #748 of 748 Old 07-28-2020, 09:13 PM Thread Starter
jeepinhokie
Got the Jeep back on the road today. Noting too spectacular just bolting the axle back in and putting everything back where it came.
Swapped the battery too because it wasn’t holding a charge.
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
