High travel, high clearance & high octane, a streetable adventure LJ story - Page 23 - JeepForum.com
 45Likes
post #331 of 338 Old 06-11-2019, 07:19 PM
Trevlaw
Trevlaw's Avatar
Looking good, glad to see you making progress still.
I'm a little confused on the tie rod though, why did you decide to do the DOM with the 4140 inner sleeve vs just a chromoly tube tie rod? Seems like the two piece would probably be a stiffer overall setup, but I would think the DOM would defeat the benefit of the chromoly being able to deflect and spring back more. I'm sure you have your reasons, just curious
I want a J-Series
TJ Build:
Trevlaw is offline
post #332 of 338 Old 06-12-2019, 09:38 AM
07wurubi
2006 LJ Rubicon
07wurubi's Avatar
The hooks you have on the front here, where did you get them and were they a direct bolt on to the frame? I had to remove my stock hooks to mount some pod lights on my new bumper but still want hooks in the front. I believe something like this would work for my situation.
Mike Fox
My Jeeps:
00 Wrangler Sport
06 Wrangler LJ Rubicon
work in progress.
07wurubi is offline
post #333 of 338 Old 06-12-2019, 10:10 AM Thread Starter
toximus
I'm glad I'm making progress again too. I had to take a hiatus to work on the khaki TJ and clean out my garage. Nearly 10 years of Jeep building was catching up to me and I had to sell off unused parts to make room to work in the garage.
It comes down to availability and cost. The DOM + 4140 was something I could cut, mockup, and weld myself and should be strong enough. If I bend it, then I will look into something like a solid 4140 and heat treating it. But that requires a final measurement, money, and time. That said, I might get on that sooner rather than later so I can have a spare available on the shelf.
Building the right way for 37s.
toximus is offline
post #334 of 338 Old 06-12-2019, 10:31 AM Thread Starter
toximus
Those came with the bumper from Savvy. They do bolt onto the frame without modification. The part number is TH6B.
07wurubi likes this.
toximus is offline
post #335 of 338 Old 06-12-2019, 01:25 PM
Trevlaw
Trevlaw's Avatar
Gotcha, yeah I hadn't thought of finalizing the measurements on it. I know the cluttered feeling, I have a full double garage to myself and it's already a mess. I think you should be able to get plenty of life out of that tie rod setup though, just don't go start punching trees with the Jeep like Paul lol
I want a J-Series
TJ Build:
Trevlaw is offline
post #336 of 338 Old 06-12-2019, 02:13 PM
07wurubi
2006 LJ Rubicon
07wurubi's Avatar
Thank you
Mike Fox
My Jeeps:
00 Wrangler Sport
work in progress.
07wurubi is offline
post #337 of 338 Old 06-13-2019, 09:02 PM Thread Starter
toximus
I copied the final mockup steering arm plate over to 3/4" steel plate and drilled and reamed it. I'll be cleaning this plate up later and will weld it to the upper steering arm, but first I need to finalize my steering a little more before I want to commit.
Mud Machine likes this.
toximus is offline
post #338 of 338 Old 06-13-2019, 09:18 PM Thread Starter
toximus
The last part of the steering to go in is hydro-assist. To turn the big 37s offroad and keep the power steering pump in good shape, hydro-assist is mandatory.
Here's my parts list:
* PSC cylinder with 1.75" bore x 10" stroke (SC2216) <--- edit: I changed the cylinder out to a 1.75" bore x 8" stroke (SC2201)
* Female 3/4"x3/4" rod end (REXFR12)
* Male 3/4"x5/8" rod end (REXMR10-12)
* Two 3/4" jam nuts (FSNJ-3/4-16RH or FKB-SJNR12)
* And two mounting tabs (MB01)
I wanted protection for the cylinder from trail hazards so I placed it above the tierod as high as I could. This way the tierod will also act as a bumper for it. Additionally by attaching to the knuckle steering arm bolt, compared to attaching one end to the tierod, there is no dead spot roll before the HA starts to push/pull.
Just like how the steering gear stops need to hit exactly when the knuckle steering stops touch, so does the cylinder. The cylinder is positioned so that the shaft is fully compressed during a left turn -- this determines it's lateral position on the axle. When the wheels are pointed straight, the cylinder is level -- this determines it's height on the axle. When the axle is in a full right turn it needs to not hit the TRE threads or nut. I kept moving it down a little at a time until it cleared.
Full right turn clearance on TRE threads and nut:
To stop the cylinder from continuing to push on a right hand turn and busting the ball joints and other components, I need to destroked it by marking and measuring the total length of the shaft less the used length of shaft and cut a spacer to that length and placed it into the cylinder.
While measuring mine for destroking I realized that I'd need just over a 2.5" spacer with my 10" cylinder. So instead of using such a large spacer, I ordered a 8" cylinder and will only have to destroke it by 0.5". (PM me if you need a 10" cylinder SC2216)
toximus is offline
