GrandWillys Project - Page 42 - JeepForum.com
 948Likes
post #616 of 873 Old 05-23-2020, 05:39 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
Originally Posted by JoonHoss View Post
Any concern of not being able to get paint in between the mesh and the back of the grill slots, and having debris work it's way in between the contact points and casing corrosion/ rust?
Hoss
This just unbolts when it comes time for painting. I made it also sit hard against the bottom of the slots and will know at time of strip down if anything has collected during its bare metal period on the road.
JoonHoss likes this.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #617 of 873 Old 05-24-2020, 02:17 AM Thread Starter
Gojeep
Gojeep's Avatar
1948
Haven't quite finished putting it all back together but wanted to show the mesh installed with the radiator behind. Gives more security this way too as no way to release the bonnet catch except by the release lever inside the cab.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #618 of 873 Old 05-24-2020, 07:58 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
GrandWillys Project
Itís amazing how such a subtle change can have such a big visual impact. That looks very good - much less semi-truck looking.
Gojeep likes this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #619 of 873 Old 05-25-2020, 12:18 PM
jlcoble
jlcoble's Avatar
As always great work looks amazing
Gojeep likes this.
jlcoble is offline
post #620 of 873 Old 05-26-2020, 06:20 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
Thank you.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #621 of 873 Old 05-26-2020, 07:31 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
I tried the gravel tray at many different heights until I was happy. This is the position I have decided on. It is sitting 19mm-3/4" higher in front of the grille than before, but still leaving more distance from the bottom of the slots to tray.
Bumper back on to finally see if it was worth it or not. The distance from the slots to the top of the tray is now half that of slots to the top of the grille. This is the same proportions as the stock 48 flat nose grille which is different to the 58 pointy nose grille.
Ok, just put together a before and after. About 20 shots it took to get it as close as I could, even brought the dog in! So left the overall height of the grille the same, but shortened the slots by 50mm-2". Then raised the stone tray 19mm-3/4". Also the grille mesh has been added which helps more in the flesh than it does in these photos. I think it doesn't need the horizontal grilles bars to be added as well anymore.
99sajeep and underscore like this.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #622 of 873 Old 05-26-2020, 08:31 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Waaaaay better proportions...Looks SO much better now!
Hoss
Gojeep likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #623 of 873 Old 05-27-2020, 05:51 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
Hoss
Awesome, glad I'm not the only one. Best thing is my wife now likes it as is now without extra adornment of the horizontal bars.
JoonHoss and 19GCTrailhawk like this.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #624 of 873 Old 05-27-2020, 06:32 PM
NashvilleTJ
I miss the snow...
Your wife has a good eye...
Gojeep, JoonHoss and underscore like this.
Build Thread:
post #625 of 873 Old 05-29-2020, 12:23 AM Thread Starter
Gojeep
Gojeep's Avatar
1948
Video update.
99sajeep likes this.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #626 of 873 Old 05-29-2020, 12:23 AM Thread Starter
Gojeep
Gojeep's Avatar
1948
Double post
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #627 of 873 Old 05-29-2020, 08:20 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Most enjoyable and informative 6:59 I've had in a while!
Hoss
Gojeep and 19GCTrailhawk like this.
JoonHoss is offline
post #628 of 873 Old 05-29-2020, 08:19 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
Hoss
Well that is great to hear.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
post #629 of 873 Old 05-30-2020, 11:54 AM
Wrangler266
Wrangler266's Avatar
This build should be taken into production. You can be proud on your results so far Marcus.
Keep up the good work!
Math
Gojeep likes this.
Wrangler266 is offline
post #630 of 873 Old 05-30-2020, 06:49 PM Thread Starter
Gojeep
Gojeep's Avatar
1948
Math
Much appreciated Math.
Marcus:aka. Gojeep
Victoria, Australia
Gojeep is offline
