Goob's "Hell on Wheels" YJ Build - Page 58 - JeepForum.com
 40Likes
post #856 of 874 Old 03-09-2021, 09:30 AM
grandboost98
grandboost98's Avatar
FWIW you can call up trail worthy fab and get another H1 wheel. The guys there are real easy to work with. He found me an 8 bolt H1 wheel with a rock ring on it already, I just had to recenter it. I forget exactly how much but I was happy with the price. Unfortunately, my club requires you to carry a spare so I carry mine in the back
Yeah, I was barely able to do about 40 in 3rd gear. Once I hit 4th I would lose speed. Hopefully going from 4.56 to 5.38 will help with that. Not that I plan to drive it on the road often, just nice to know I can.
And I found using an engine hoist easiest for moving these anchors around. Its no fun picking up a +500lb axle by yourself!
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #857 of 874 Old 03-09-2021, 11:37 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Originally Posted by The_Goob View Post
just need it to be able to run down the highway. Axles are heavy as f. Also
Sent from my iPhone using Tapatalk
Caugh....LS Swap.... Ahem. Sorry, had to clear my throat.
87 YJ, 5.7/TH350/NP241/HP Dana44/9", Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
daddyjeep87 is offline
post #858 of 874 Old 03-09-2021, 12:06 PM Thread Starter
The_Goob
The_Goob's Avatar
My comment was more in reference to getting them to balance. I put a good bit of airsoft in there
YJoTM~April '14~June '15~April '17~July '20
Subscribe to my YouTube!-->
The_Goob is offline
post #859 of 874 Old 03-09-2021, 12:47 PM
daddyjeep87
1987 YJ Wrangler
That's boring then. I was thinking that there is a lot of weight to get spinning there.
post #860 of 874 Old 03-09-2021, 04:51 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Cough...%=&spark plug wires&$#....cough.
daddyjeep87 likes this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #861 of 874 Old 03-10-2021, 12:41 PM
grandboost98
I didn't add anything to my wheels to balance them. I haven't got mine over 45 yet but its been smooth up to that speed, even with a square driveshaft. I forget what you're running but I have 39.5x13.5 bias plys and I run about 15psi on the road
post #862 of 874 Old 03-10-2021, 01:35 PM Thread Starter
The_Goob
The_Goob's Avatar
37 Humvee mtrs
The_Goob is offline
post #863 of 874 Old 03-22-2021, 05:23 PM Thread Starter
The_Goob
The_Goob's Avatar
Man I have been so busy, I scrapped the bastard packs and got another set of new waggy springs just like what I put on rear. GOt the first bar and the mount done on my traction bar. front axle perches were 1" wider than yj frame so rather than outboard I just welded the pin holes up and re drilled them 1/2" inboard on each perch. Had to grind away a little casting on D side but it worked
Also Finished the wheels!
Here is the part 2 vid on the wheels, shows how to finish them up and the final product.
The_Goob is offline
post #864 of 874 Old 03-24-2021, 03:24 PM Thread Starter
The_Goob
The_Goob's Avatar
Got a new toy the other day, and a few pics showing the start I got on my traction bar and having to modify the driver side u bolt plate
The_Goob is offline
post #865 of 874 Old 03-25-2021, 08:06 AM
daddyjeep87
1987 YJ Wrangler
Nice. I cheaped out and built my own break.... Video in my build thread.
post #866 of 874 Old 03-25-2021, 05:11 PM Thread Starter
The_Goob
The_Goob's Avatar
Stimmy purchase
The_Goob is offline
post #867 of 874 Old 03-25-2021, 06:12 PM
xjloverforlife8
Balancing the wheels can be unnecessary from time to time. Of course, it all depends on what youíre running.
The_Goob likes this.
xjloverforlife8 is offline
post #868 of 874 Old 03-31-2021, 10:28 PM Thread Starter
The_Goob
The_Goob's Avatar
I showcase some of the problems Im having with the swap in this video, inboarding front axle spring perches, traction bar mounting, skid plate interference with my transfer case(due to the aw4 swap)
The_Goob is offline
post #869 of 874 Old 04-06-2021, 09:00 AM Thread Starter
The_Goob
The_Goob's Avatar
Got her off jackstands, see whatís left to do here
My Jeep YJ is Finally off Jackstands! SOA & Axle swap almost done
The_Goob is offline
post #870 of 874 Old 04-11-2021, 07:57 PM Thread Starter
The_Goob
The_Goob's Avatar
After not Getting much done in the last couple weeks Iím back out here modifying my homemade gas tank skid plate trying to keep the fuel tank and not switch to a fuel cell
I just got the swag off road finger brake built and installed also, finished the traction bar also which I decided to make a vid on chop saw notching, way easier than doubling with a hole saw.
The_Goob is offline
build , islander , YJ
