Goliath WJ Overlander build - JeepForum.com
 15Likes
post #1 of 39 Old 05-27-2017, 08:30 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
GOLIATH WJ Overlander Build
Few weeks ago I picked up a red jeep grand cherokee WJ laredo.
Unfortunately I can't find any photo how the jeep looked like, but it was a typical laredo wj.
Goliath-XJ is offline
post #2 of 39 Old 05-27-2017, 08:32 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
At the shop we started to striping it down. Jeep had regular dana 30 on the front and dana 35 on the rear, because it is 4.0 inline 6. We took the axles out and made some room for dana 30 and 44a from overland WJ with quadra-drive ( hydraulic lockers ).
Also we test fitted some bushwacker flares and mock up the snorkel.
20170507_174300.jpg   20170507_174246.jpg   20170430_182931.jpg   20170430_182921.jpg
Grannyguste likes this.
post #3 of 39 Old 05-27-2017, 08:34 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
* Engine was blown, so we sold it to Titan engines in Ocala and made some money
Now it's time to beef up the axles a little bit. We are working on the trusses and diff covers for dana 30 and 44a.
post #4 of 39 Old 05-27-2017, 08:35 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Scored the carpet for the WJ on the junkyard yesterday. This thing is in perfect condition! Paid $16
post #5 of 39 Old 05-27-2017, 08:37 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
During the last few day I did some progress on the build
Spare tire area delete and shortening the gas tank skid plate. Now gas tank is sitting 6" higher than it was before. Nice upgrade to gain some ground clearence. Will post some more pictures when I get everything welded together and painted.
tybarious likes this.
post #6 of 39 Old 05-27-2017, 08:41 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Front axle received new coil buckets. Now start to build some long arms for the front.
I also painted whole undercarriage with some undercarriage paint with sound deadening additive.
20170520_164303.jpg   20170523_191500.jpg   20170523_191604.jpg   20170523_191622.jpg
post #7 of 39 Old 05-28-2017, 09:50 AM
Mark-318-IT
super good work also with this one, keep it up
Goliath-XJ likes this.
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is online now
post #8 of 39 Old 05-28-2017, 10:01 AM
caronaxtr2
caronaxtr2's Avatar
Like where this is going. Since the I6 was blown, are you going with something different or sticking with a 6?
Give us some ideas on the plans, tire size, lift height, plans for the D30/44a, etc.
Body looks like it's in great condition. Great base to work off of......
keep us up to date on the build.
Builds:
2002 WJ-ARB's f/r, swapped D44A, 4.5" Clayton, 33" SST Pro's, winch, armor, and other doo-dads
2001 TJ-T.B.D. as I'm still buildin' it
caronaxtr2 is offline
post #9 of 39 Old 05-28-2017, 07:33 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Yes, I'm going to stay with Inline 6. Picking up brand new engine with 100k miles warranty from Titan Engines, stock specs.
I'm not going crazy with this build. Tires gonna be 33s. Clayton springs 6". Long arms by Goliath Off Road front and rear + some 1 ton steering. Dana 30 is with hydraulic locker and dana 44A as well, so just gonna leave it as is, because it's enough for this build. Gears are stock from V8 WJ ( 3.73 ) which I'm also gona leave, because I don't need anything more for this set up. Dana 30 and 44A will receive our prototype trusses, diff covers and coil buckets
It's a Florida car. It's 100% rust free. Just painted the undercarriage to make it looks better, protect and the stuff that I sprayed is also with sound deadening.
I'm working on all my projects every day, so I'm gonna post every time when I make any progress.
post #10 of 39 Old 05-31-2017, 08:27 PM
turboquief
Looks like a nice clean Jeep! I'm form wisconsin and its super hard to come by a clean wj. I found a nice 2004 Freedom Edtion in Minnesota that I went a stole. Had 98k miles on it and got it for 6K. No rust at all. Also, has the High output V8. Looking for ideas with doing my 2" suspension lift. I bought the 2" lift from FatBobsGarage. What are some ideas such as tire size and spacers for the wheels. Last Jeep rubbed the paint right off the from lower control arms. I had the 245/70/ R17 duratracs on there.
TurboQuief
turboquief is offline
post #11 of 39 Old 05-31-2017, 09:02 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
I bought this WJ for $500. In Florida most of them are rust free.
With 2" of lift you won't go super crazy. My dad has 2 inch lift on his DD WJ and he is running stock size tires, only wheels have more offset .
If your duratracks rubbed on the paint on the control arms I would recommend 1" spacer or wheels with more offset so they stick out a little bit more than stock.
Thant's my dad's WJ
post #12 of 39 Old 06-01-2017, 01:59 AM
turboquief
Thant's my dad's WJ
Very nice! Yeah my Jeep is pretty much my daily drive for now and I want to keep is as reliable as possible, hence the 2" lift. I would like to run a little bit bigger of a tire, imma stick with the 245/70/ R17 tire size. Im going to stick with the stock rims from the freedom edition for now. I will probably go with a wheel space for sure though. 1" of wheel space should be good enough then you think?
TurboQuief
post #13 of 39 Old 06-01-2017, 07:44 AM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Yeah, 1" will be enough. It doesn't look very big, but on the car it makes a difference.
post #14 of 39 Old 06-14-2017, 08:49 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Tank tuck is complete! I have to paint it as the rest of the undercarriage also.
Now is time to make some suspension.
Goliath Off Road
post #15 of 39 Old 06-15-2017, 09:04 AM
tybarious
tybarious's Avatar
I like where this is going, keep it up!
tybarious is offline
