Danno's DD TJ Build - Page 85 - JeepForum.com
post #1261 of 1319 Old 04-21-2014, 11:08 AM
aw12345
aw12345's Avatar
Its neat looking but not entirely practical .
I am with Greg, will be a pain to get anything out from underneath. I still prefer a spare hanging from the back, my funky tire carrier is easy to open to get access to the back and the darn billy goat Jeep still out climbs darn near every Jeep I wheel with, even with the big donut hanging from the back. It would work better for ya if the tire folded or slid out somehow.
aw12345 is offline
post #1262 of 1319 Old 04-22-2014, 04:39 AM Thread Starter
Danno6102
Danno6102's Avatar
I realize it's not for everyone, but it gets me a few things I wanted & avoids a few things I didn't want.
1. I didn't want a rear mounted tire. Not a fan of the look & I hated hitting the tire when dropping off steep ledges. I always felt I was going to rip it off or damage the door & hinges. I realize I may still hit this one, but it's tucked in a lot further & I can always add more bars to slide down if needed. I'm also not a fan of the huge tire carriers like the genright type. Just not for me. Most importantly, I think mine looks cool. I should get mad cred at the mall.
2. I wanted it as far forward as I could get it to help with COG & as low as I could get it for visibility. With the addition of the fuel cell, just throwing it in the tub like I had done before was no longer an option. I could have kept it completely in the tub & still used the rear door, but it would have had to mount too vertical & obstructed view. Moving it back also allows for the addition of some things above the fuel call like a small cooler & room to run the remote fuel fill.
3. There is storage room under the tire. Small things can easily be accessed by reaching through the side windows. In all reality, all that will be under there are a few basic tools & spare parts. Not something I have to get too often. With the Y strap, the tire can be out in about 30 seconds. Yes, it's a little heavy & will get heavier when upgraded to a 37, but really not that bad to tip it up, spin it 90 & roll it out. A flip out design would be cool & I may redesign it later to do that, but for now I think this works good, & was simple to build. The flip out design would more than likely required cutting the tub quite a bit for the tubes to clear to keep the tire below the crossbar for the rear window. Plus if I decide to redo it, it's something cheap to satisfy my fabrication fix.
Originally Posted by boilerup1998 View Post
I was wanting to mount my spare like that....unfortunately at 39" doesn't fit so nicely in that space.
I'll have to either massage the fender wells when I go to a 37, or build some new sheet metal fenders. It'll be a tight fit.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1263 of 1319 Old 04-22-2014, 05:37 AM
Sundowner
Sundowner's Avatar
I'll have to either massage the fender wells when I got to a 37, or build some new sheet metal fenders. It'll be a tight fit.
Personally, I like the design...but I'm admittedly a bit biased. I don't think people realize how obtrusive the rear-mouted spare tire is, visibility-wise, until they either go without one or move it to the position in which you've located yours; you can move it up another twelve inches or so and you'll still have more rearview-mirror usage than anyone with a tailgate-mounted spare. Also, the Y-strap is a great way to secure it the tire; I thought long and hard about using one of those before I settled on two crossed cam straps, and to be honest there's basically no difference between the two systems...both will hold it down retard-tight. I have anecdotal evidence that you can stuff a 37" tire in the cargo area without cutting sheet metal, but I can't say that I've tried it myself; I think it requires letting all the air out and then using a lot of persuasion to wedge it into place.
Nice work.
Sundowner is offline
post #1264 of 1319 Old 04-22-2014, 07:00 AM
AngryTJ
AngryTJ's Avatar
Why not just use a center clamp like this and forget the entire rear addition all together
AngryTJ is offline
post #1265 of 1319 Old 04-22-2014, 07:25 AM Thread Starter
Danno6102
Danno6102's Avatar
Fuel cell & having space for future addition of a small cooler behind the passenger seat above the fuel cell, & my remote fill hose that will run towards the rear of the roll cage on the driver side for easy access by unzipping the rear corner of the window. if the tire was pushed all the way in, there wouldn't be enough room for all of it mount like it needs to. Especially the fuel filler hose. I'll post pics when I get it all installed, hopefully tonight, so you guys can see what's going on a little better.
post #1266 of 1319 Old 04-22-2014, 07:30 AM
AngryTJ
AngryTJ's Avatar
Im saying keep it mounted in the exact same location as you have it pictured and run a tube thats attached to the tub up through the center of the wheel with a clamp to keep the tire from going anywhere.
AngryTJ is offline
post #1267 of 1319 Old 04-22-2014, 07:39 AM Thread Starter
Danno6102
Danno6102's Avatar
Oh I got ya! I thought you meant bring the tire in all the way & use that. I could have done the screw clamp, but I just like the Y strap mount for some reason. I've often wondered if those threaded clamps ever vibrate loose over time. The bars around the back are also there for a little protection. That's what's nice about having a welder & a grinder. If I don't like something I've done, I can always cut it off, grind it smooth & do something else.
post #1268 of 1319 Old 04-22-2014, 08:50 PM
aw12345
aw12345's Avatar
I am still quite happy with my lil tire carrier, thing still out climbs most all Jeeps on waterfalls, clears 4-5 foot ledges just fine, acts as a stinger on Helldorado. Would not want to do it any other way. Kinda defies the logic that a spare on it arse keeps it from climbing steep stuff
aw12345 is offline
post #1269 of 1319 Old 04-23-2014, 06:39 AM Thread Starter
Danno6102
Danno6102's Avatar
Finished it up last night. I'm happy with the way it turned out. I think it will look even better once I stretch the rear axle back 6"-7". We'll see how it performs this weekend.
Untitled
Untitled
Untitled
Untitled
Untitled
Untitled
post #1270 of 1319 Old 04-23-2014, 06:50 AM
green50gt
green50gt's Avatar
Looks pretty rad!
green50gt is offline
post #1271 of 1319 Old 04-23-2014, 06:51 AM
REDLYNER
REDLYNER's Avatar
Looking good!
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #1272 of 1319 Old 04-23-2014, 07:16 AM
janesy86
janesy86's Avatar
Pretty cool dude! And if its what works for you that's all that matters.
Follow on Instagram: nickjanes***** *replace ***** w/ pregnantdog
janesy86 is offline
post #1273 of 1319 Old 04-23-2014, 09:00 AM
g-rocc
g-rocc's Avatar
That is going to work out really nice. I don't think I could forsake my Rokmen tailgate though.
g-rocc is offline
post #1274 of 1319 Old 04-24-2014, 06:54 AM
joshr1987
joshr1987's Avatar
Subscribed.
joshr1987 is offline
post #1275 of 1319 Old 04-24-2014, 08:07 AM
G Beasley
G Beasley's Avatar
That turned out really good ...
G Beasley is offline
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
