Danno's DD TJ Build - Page 78 - JeepForum.com
post #1156 of 1319 Old 03-03-2014, 08:01 AM
green50gt
green50gt's Avatar
VERY nice playground equipment! You need to add one of those plastic steering wheels and a lookout tower to really finish it all out!
Wow, really love it, again nice work!
green50gt is offline
post #1157 of 1319 Old 03-03-2014, 09:19 AM Thread Starter
Danno6102
Danno6102's Avatar
Your welds are MUCH better than mine, man... and that cage is turning out really well! Nice work!
Thanks guys! It should go in Tuesday night. Probably driveable Wednesday night finally.
Some good news! Getting my windshield replaced for free through my insurance company. Next one I do, I will place a sheet of plywood over the windshield & use more clamps to hold tubes in place. What happened was the upper windshield spreader slipped out & crashed down onto it.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1158 of 1319 Old 03-03-2014, 12:34 PM
boilerup1998
boilerup1998's Avatar
Looks really good Dan. Are you going to make it to the March 29 Badlands run?
boilerup1998 is offline
post #1159 of 1319 Old 03-03-2014, 01:31 PM Thread Starter
Danno6102
Danno6102's Avatar
Probably not. That week before is spring break, so we might not be around & as much time as I've been spending in the shop I better build up my happy wife points. We'll see though.
post #1160 of 1319 Old 03-04-2014, 06:06 AM Thread Starter
Danno6102
Danno6102's Avatar
All painted up & ready for install tonight!
post #1161 of 1319 Old 03-04-2014, 06:45 AM
Sundowner
Sundowner's Avatar
Sundowner is offline
post #1162 of 1319 Old 03-04-2014, 09:50 AM
bobthetj03
bobthetj03's Avatar
Solid!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #1163 of 1319 Old 03-04-2014, 05:55 PM
G Beasley
G Beasley's Avatar
That turned out great , and your avatar is way less creepy now
G Beasley is offline
post #1164 of 1319 Old 03-04-2014, 06:50 PM Thread Starter
Danno6102
Danno6102's Avatar
Thanks guys!
I loved that avatar simply for the magnitude of creepiness. I will miss it.
post #1165 of 1319 Old 03-04-2014, 10:32 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Cage looks great man. I'm sorry if you mentioned this earlier but did you use Bendtech to design it or did you do it all without computer aid? Also what bender are you using and notcher? One more question….. how much DOM was that?
gst95dsm is offline
post #1166 of 1319 Old 03-05-2014, 04:57 AM Thread Starter
Danno6102
Danno6102's Avatar
Yep, I used Bendtech. Was well worth the money for the two cages I've done from this design & hopefully I get to do a few more. It made life a whole lot easier! The notching templates are damn cool! I used them on every joint on my cage even if it was going in the notcher. I'd use it to visually position the tube. If it was a notch that wouldn't fit, I had nice lines to cut & grind to. It still took some test fitting, but not a whole lot.
I used a buddies bender. Home made one. Not the nicest bender out there, but it was adequate. No degree wheel on it, so I had to use my digital angle gauge. That was kind of a pain. I'm looking to buy my own bender not too far in the future. I'm considering Rogue Fab. It's a vertical rotary bender so it doesn't have to be bolted to the floor.
Notcher was a cheap *** Harbor Freight. It too was adequate. Had to make some mods to it right out of the box & all 3 bolts that lock the angle gauge in place have stripped out. Not a big deal I just need to drill through & use some longer bolts & nut the back sides. The brass bushings are getting a bit worn out after 2 cages worth of notching though & it's wobbling a bit. I don't have any idea what notcher I would buy next. JD2 maybe. A notcher is a convenience. You can notch just as good with a cut off wheel & a 40 grit flap wheel. Just takes a little longer.
There is just under 100' of 1 3/4" x .120 DOM in my cage.
With the help of a few great guys who drove over an hour to come help me put this thing in, it's in! Dash is in & steering wheel is in. Tonight's tasks consist of getting it bolted down at least at the B & C pillars & getting the seats & harnesses mounted & the center console back in. Then she'll be ready to drive. I'll need to remove my rockers to get the A pillars bolted down, but that'll wait until next week.
post #1167 of 1319 Old 03-06-2014, 06:45 AM Thread Starter
Danno6102
Danno6102's Avatar
All is right with the world now. Drove the Jeep to work today. I still have some things to finalize on it, but it's road worthy. I need to remove my rock sliders to tie in the A pillars. Replace the stupid star bolts on the B pillars with some hex heads so I can really torque them down. I also need to get some new lap straps for my harnesses. When I bought them I didn't plan on doing seat mounts right away so the lap belts are eye bolted to the floor. If the cage would happen to separate from the tub in a roll, that would be mighty painful. I also have to move my seat back a little. It's mounted way too close. I drilled the brackets so I have some adjustment fore & aft, so that's no big deal, just a paint to get in there to bolt it up. When the cage comes out again, I may weld some nuts to the bottom of the brackets so I only need to squeeze one arm under the seat instead of two.
post #1168 of 1319 Old 03-06-2014, 07:27 AM
green50gt
green50gt's Avatar
I suppose you could tease us and not post pictures of the jungle gym...
post #1169 of 1319 Old 03-06-2014, 07:40 AM Thread Starter
Danno6102
Danno6102's Avatar
Jeep needs a bath, & preferably the new windshield, before I post pictures. I did however vacuum it out last night before I mounted the seats.
post #1170 of 1319 Old 03-06-2014, 07:43 AM
green50gt
green50gt's Avatar
I'm very proud of you!
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
