Barkdog67's YJ build - JeepForum.com
post #1 of 15 Old 09-22-2014, 12:41 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I purchased my first YJ back in April of this year with the sole intentions of building a nice jeep to keep for me and the wife. I have had a couple TJ's, a grand Cherokee, and a JK in the past and when we traded the JK off for my truck I was without a jeep for a while. I had a friend of the family on the east coast that had a YJ setting in his garage that I have been drooling over for the past 5 years and he was never really interested in letting go of it. He called me in April and made me a deal I couldn't refuse. It's a 1989 Jeep YJ 4.2 3 speed auto with pretty much zero rust on the frame and body. We made the trip out to Virginia in April and I tailored it back. Since then I have done a lot of modifications to the jeep and I figured I should start a build thread to keep track of my progress. Here she is the day I brought her home.
BARKDOG67 is offline
post #2 of 15 Old 09-22-2014, 12:54 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I am going to play catch up to where I am now with the jeep. Cosmetically the jeep needed a lot but that didn't bother me considering it was rust free. I plan on keeping this one so I didn't mind sinking a lot of my time into it. When I first got it I started replacing the little things like seals and the windshield hinges the old ones were seized and I scored a set of cj hinges for free so I went ahead replaced those. while i had the windshield down I figured it was a good time to address some surface rust I found under the windshield so I took the dash out and addressed it and painted the dash black and replaced the lower windshield seal.
post #3 of 15 Old 09-22-2014, 01:02 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I noticed the jeep had a clunk in the rear end and upon further investigation I seen that my aft spring bushings were shot. I ordered front and rear 2 inch BDS springs for the jeep. I also threw on a 1"inch boom shackle lift to level out the front since it had some rake to it. I initially got over 3" of lift with these springs so I had to install a transfer case drop for the vibes and it turned out pretty good.
post #4 of 15 Old 09-22-2014, 01:43 PM Thread Starter
BARKDOG67
2015 JK Wrangler
The previous owner had installed a Weber carburetor on the 4.2 and did the nutter bypass I did a tune up on it and got it running good but it had some blow-by and I was constantly chasing oil leaks. I drove it this way for a few months until it blew the lower pan seal. I had planned on taking it out of commission for the winter to address the motor but when it blew the oil pan seal I went ahead and parked it for a while. I contemplated rebuilding the 4.2 but didn't really like the power it had plus the TF 999 trans that was in it had a front pump leak. I did some researching with motor swaps and I always wanted a v8 wrangler so this was the prime opportunity to jump on it. I have been tearing the jeep down in my spare time in the garage this past month and I have managed to get the front clip off and the motor and trans removed from the jeep. This past week I went ahead and cut the motor mounts loose from the frame, ground the frame down and painted it. I have decided to go with a SBC 350 so I ordered a trans dapt engine cradle and got that mounted.
post #5 of 15 Old 09-22-2014, 01:50 PM Thread Starter
BARKDOG67
2015 JK Wrangler
The body mounts on the jeep were in bad need of replacement so I ordered a 1 inch pro-thane body mount kit for the jeep. That came in the mail Saturday and since I was off today I went ahead and got that installed. Luckily I didn't have any problems with the body mount bolts and was a fast install.
post #6 of 15 Old 09-22-2014, 02:03 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I am currently thinking about whether to source a used 350 or to just go ahead and go with a new crate motor. The wife is getting irritated with me dumping money in the jeep so I might go ahead and work on the 8.8 axle I acquired for the rear until more funds come in. I still have a ton of work ahead of me and was hoping to have this thing back on the road next summer.
post #7 of 15 Old 09-22-2014, 03:55 PM
The_Goob
The_Goob's Avatar
Good start so far! That "old" engine looks pretty clean and painted, sell that baby to fund the SBC. Have you decided on a transmission? the jeep 3 speed is a good tranny but having overdrive would be better and you could avoid buying adaptors.
YJoTM~April '14~June '15~April '17
The_Goob is offline
post #8 of 15 Old 09-22-2014, 05:03 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I have the engine for sale right now but have had no luck in selling it. I might throw it in the classifieds on the forum. As for the transmission I already have a rebuilt 700r4 I want to put in it. I just need to get a motor.
post #9 of 15 Old 09-22-2014, 05:09 PM
The_Goob
The_Goob's Avatar
Cool. Just get FI or at least TBI, might be a little more work with wiring and whatnot but not having to deal with carb issues is worth it. Do you plan on wheeling it or going big at all?
The_Goob is offline
post #10 of 15 Old 09-22-2014, 08:22 PM Thread Starter
BARKDOG67
2015 JK Wrangler
Well I would like to go TBI eventually but im going to start off with a carb so I can at least get it moving and get all the linkages worked out. I will definetly wheel it some but 33's will be as big im going to go for a while.
post #11 of 15 Old 11-24-2014, 01:06 PM Thread Starter
BARKDOG67
2015 JK Wrangler
yj build
Its been a while since I updated this thread I have been working a lot but have also got some things finished with the jeep. I finally got the inside of the tub painted and it turned out really good. It didn't have carpet when I got it and the inside of the tub had some surface rust in places. I sanded down the inside of the tube and rolled on some rust-oleum bed-liner for the time being. I haven't decided if I'm going to put carpet back in it or not I may just run it without. The bed-liner is cheap and easy to patch up if needed. It actually turned out better than I thought it would. Here is a pic tubs a little dusty since I did the bed-liner.
post #12 of 15 Old 11-24-2014, 01:15 PM Thread Starter
BARKDOG67
2015 JK Wrangler
yj build
I finally got my motor in its a crate 350 chevy. I pulled a serpentine belt setup off a late 80's Chevy pickup in the yard to run on this motor. I sand blasted both brackets and painted them and put them on for test fit I should be going in with the drive train within the next couple of weeks when I get the time like I said in my last post I have been working a lot and its been a slow process.
post #13 of 15 Old 11-24-2014, 08:14 PM
YnotJ92
Are CJ windshield hinges more desireable than YJ ones? Or did you just happen to find some CJ ones for free so you used them?
Thanks
YnotJ92 is offline
post #14 of 15 Old 11-24-2014, 08:21 PM Thread Starter
BARKDOG67
2015 JK Wrangler
I just stumbled across them.
post #15 of 15 Old 11-24-2014, 08:47 PM
YnotJ92
Cool. Thanks
YnotJ92 is offline
