Banana 'manche project - JeepForum.com
 6Likes
post #1 of 22 Old 04-03-2019, 10:25 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
The Banana 'manche project
I bought this jeep a few weeks back as an unfinished project. It's a 1989 Jeep Comanche short bed. The truck started its life as a Renix 4.0 with a 5-speed transmission.
The previous owner started the '97+ conversion but never finished it. I bought the Comanche "as is", along with another, parts Cherokee.
The deal was too good to pass up.
The jeep was bought and kept in Florida its whole life, so it's very solid. There are only a few, very little spots on the floor pans with some rust showing, but it's a quick fix, so I don't really worry about that.
Quick plan for the build:
- newer engine, automatic transmission, and wiring harness swap
- 3/4 ton axles (8 lug ford HP dana 44 and full float dana 60)
- 35" tires
- new paint job (yellow)
- front clip and interior swap to the older style
- fuel cell
and a lot more...
Here are some pictures of the jeep when I got it. Of course first, I went thru all the stuff that was on the bed of the truck and all the additional parts that came with the deal.
Goliath Off Road
Goliath-XJ is offline
post #2 of 22 Old 04-03-2019, 10:43 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
I already have a bunch of parts waiting to be installed on the Comanche.
Axles are getting new 4.10 gears. Both axles have trusses. For the front, I went with TnT XJ/MJ swap kit with a high steer track bar mount, and on the rear dana 60, I just welded a simple, plain truss.
As soon as the axle come back regeared, I will start putting them back together. Everything in the axles is going to be new, all the bearings, seals and bolts.
Front axle is going to get a LockRight locker, warn premium hubs, Yukon Chromoly axle shafts, high steer arm, RuffStuff diff cover, new spindles, ball joints etc.
Rear axle is equipped with a factory track lock differential, so I'm going to keep that for now. Other than that it's getting all new bearings, gears, seals and steel diff cover.
I also found a Comanche specific topper/camper locally, and it's in very good condition. I'm going to paint the same color as the jeep will be.
Goliath Off Road
post #3 of 22 Old 04-04-2019, 11:09 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
This is worth watching.
Goliath-XJ likes this.
***Chris***
chris87xj is offline
post #4 of 22 Old 04-04-2019, 10:16 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Nice. Looking forward to following your build.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #5 of 22 Old 04-12-2019, 09:48 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
I spent the last week fixing some rust problems in the cab an engine bay. Everything is nicely patched, sprayed with ospho and is waiting for some anti-rust paint next week.*
There were about 10 little rust holes in the cab. About golf ball size. I think Comanches tend to have rust on the floor pans. This is my third Comanche, and they can be perfect everywhere and have rusty*floor pans...*
Also, I think the rear sliding*window was poorly designed. They were leaking like crazy and Comanches*were rusting behind the front seats. Mine don't have rust on the back of the cab, thankfully.*
Goliath Off Road
post #6 of 22 Old 04-12-2019, 10:00 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Few of the missing pieces for the suspension came in. New factory leaf springs (they flex more than lift leaf springs). I'm doing a spring over the axle, instead of the factory under the axle set up. That and some custom leaf spring hangers should give me about 6.5" on the back. I already have 6.5" front Clayton Off Road springs.*
And some fox shocks performance series to go with it. Should ride pretty nicely *
Goliath Off Road
post #7 of 22 Old 04-13-2019, 12:11 PM
Jakegrovephoto
Jakegrovephoto's Avatar
1931
Subscribed
Came real close to picking up a 2wd 88 MJ a few weeks back to swap in a 4x4 AX-15 and 231 I have around. This build looks like you have a solid plan going for it
Jakegrovephoto is offline
post #8 of 22 Old 04-14-2019, 09:39 AM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Originally Posted by Jakegrovephoto View Post
Subscribed
I never have a solid plan for my builds haha
I always change stuff as I go, but this one is going to be nice.
Stay tuned for more
Goliath Off Road
post #9 of 22 Old 04-17-2019, 10:53 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Today, I started cutting the metal!
I "trimmed" the bed to clear the new 37's. I'm also planning to make a nice rear bumper that will be low profile, go around the corners, and won't take away any clearance. In order to do that I cut the rear lower section of the bed, leaving just a little bit of lip to make it look cleaner. I think it looks much better now.
I also started working on my new seats. Since the jeep came without seats, and the XJ seats from the donor won't really fit I had to make something. I had these Mastercraft Nomad seats since forever and thought they would look cool in the 'manche. However, considering the fact that I'm 6'4", the regular "bolt-on" brackets won't fit, I had to make my own. These are going to work just fine, and I won't be touching the roof with my head. I also made the sliders for them (not pictured).
Frame stiffeners from T&M Fab came in the mail the other day. I will be welding them after the jeep is painted.
I was looking for the dedicated Comanche stiffeners for a long time, and I saw these on Instagram. Decided to give them a try.
The problem with the Comanche is that they are the same as the Cherokee, to just about the middle of the cab. After that, they are completely different and regular Cherokee stuff won't fit without a lot of modifications.
This is the full set that goes from the very begging of the jeep to the very end (front, mid, and bed section)
So far, they look good, we will see how they fit...
Goliath Off Road
post #10 of 22 Old 04-20-2019, 11:02 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
I finished cutting the bed today. It looks like crap now, but once the proper tires roll in, it's going to be badass.
Also, since the axles are really wide (full width) I will probably make some kind of fender flares, to cover some of the tire.
I couldn't resist and put the topper on the Comanche to see how it would look. It already looks good, but it will be much better all painted the same color.
Also, the rusty spots in the floor are fixed, sealed and the floorboards are ready to be painted next week.
danno627 likes this.
Goliath Off Road
post #11 of 22 Old 04-22-2019, 10:06 AM
Highgear1
Highgear1's Avatar
Cool build I'm putting an nsg370 6 speed in my 89
Highgear1 is offline
post #12 of 22 Old 04-29-2019, 01:27 PM
dougcherokee
1994 ZJ
Absolutely gorgeous.
dougcherokee is offline
post #13 of 22 Old 05-05-2019, 06:06 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
nice!
Goliath Off Road
post #14 of 22 Old 05-05-2019, 07:00 PM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Some progress from the past few days, on the Comanche.
The floor is done. All welded, sealed, and painted.
Front fenders are cut to fit the 37" tires. I want to keep it low, so had to trim a little bit more than it normally would be.
I took the bed off, sanded it for paint and fixed some little dents. While I had the bed off I pushed the Comanche outside and clean the rear frame and the bed from all the dirt and grime. The frame on that Comanche is just perfect. There is not even surface rust on it. I was kinda impressed.
I also sanded and painted the engine bay. It was sprayed with an ugly black primer that was peeling off. Now it's nice and black. And looks fresh too. The engine bay is ready to install the engine!
Goliath Off Road
post #15 of 22 Old 06-30-2019, 12:08 AM Thread Starter
Goliath-XJ
Goliath-XJ's Avatar
Not much progress on the 'manche. It's getting ready to head out for some new paint next week. I had to fix a lot of dents, rust holes around the rear window etc.
It's a lot of work, especially since the jeep has every panel in a different color, and only God knows how many times it was painted before...
When it gets back from the paint, I can actually start doing the fun stuff, assembly!
For now, I just came across a great deal on a brand new Trail Gear steering assist, and just couldn't pass the opportunity.
Also scored a set of JK Rubicon axles, complete with e-lockers, so that's what I'm going to use on this build.
Goliath Off Road
Project Freakshow (Homemade TJ Brute) TJsRedTJ Jeep Builds 67 11-25-2019 07:12 AM
Project CJ7 "PJ edition" complete rebuild ! KristPJ Jeep CJ Forum 87 07-21-2019 06:52 PM
Project CJ7 "PJ edition" complete rebuild ! KristPJ Jeep Builds 75 07-21-2019 06:44 PM
CJ5 won't start, turned into rebuild project pic heavy. davidt443 Jeep CJ Forum 29 06-20-2019 10:10 AM
Monstaliner Project for my 2004 TJ - project started with pics matrix311 Paint and Body 6 11-12-2018 12:05 AM
