AzDevilYJ's build thread... finally - Page 215 - JeepForum.com
 455Likes
post #3211 of 3234 Old 03-28-2021, 09:47 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Originally Posted by NashvilleTJ View Post
I donít recall - are you running a cooler?
Just a small GM OEM dual pass fin cooler.
Sent from my iPhone using Tapatalk
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #3212 of 3234 Old 03-28-2021, 09:49 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Originally Posted by 87TPIYJ View Post
Definitely run a cooler if you arenít. Your new pump may have been bad too. Good thing with the remote resi is the filter. Pumps like clean fluid.
I didnít get the resi with the oil can filter. I should have but itís was another 300 bucks or something like that
I got this kit and a seperate brake booster mounting plate
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3213 of 3234 Old 03-28-2021, 09:52 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
While looking at the spin on filter kit, I did come across this... do you know if this is included with what I got, or is it a seperate add on? EDIT: it looks like it does come with the kit I purchased thankfully
https://www.pscmotorsports.com/psc-srfilter.html
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3214 of 3234 Old 04-01-2021, 05:32 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Got my PSC stuff!!! But the bracket fitment is pretty lame. Itís supposed to be YJ/TJ bracket. Iím gonna ditch the grill supports To solve the problem
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3215 of 3234 Old 04-01-2021, 07:16 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I was going to say there is a filter in the one you got, but you already figured that out.
AZdEvilYJ likes this.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #3216 of 3234 Old 04-02-2021, 09:56 AM
janesy86
janesy86's Avatar
I ended up hacking my bracket up to flip it around so my reservoir was on the other side of the master.
I should have ditched the hood support as the bottom of my grille is welded to the frame now. Though not sure if I had room over there either.
Follow on Instagram: nickjanes***** *replace ***** w/ pregnantdog
janesy86 is offline
post #3217 of 3234 Old 04-03-2021, 07:14 AM
'92 vegas YJ
'92 vegas YJ's Avatar
I made my own bracket.
NashvilleTJ likes this.
'92 vegas YJ is offline
post #3218 of 3234 Old 04-05-2021, 05:32 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Thatís nice work! If I had thought it out a bit more before purchasing I probably would have gone that route lol. It was a little impulsive at the time
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3219 of 3234 Old 04-05-2021, 05:33 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Hmm Iíll have to take a look at it. Iíd like to keep it as far from the headers as I can tho
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3220 of 3234 Old 04-06-2021, 11:20 AM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Got the pump and resi installed. Iím gonna stop at the speed shop on my way home and get a 45į fitting. The kit comes with one straight, one 90į, and I donít like the way the hose gets routed with the 90.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3221 of 3234 Old 04-07-2021, 08:42 AM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Got everything installed. It was pretty simple. Now Iím going to flush and fill with the swepco 715 stuff psc recommends.
I donít know if itís the cause, but I used Lucas universal PS fluid on the last couple pumps and it looks like it got cooked pretty good by the color of it. Id never used it before, so I donít know if not using the gm recommended stuff was part of the culprit.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3222 of 3234 Old 04-07-2021, 09:18 AM
grandboost98
grandboost98's Avatar
FWIW I was having nothing but problems with power steering fluid once I went hydro assist. A couple friends recommended that I should run ATF with some lucas power steering stop leak. All my issues went away once I switched.
But if I had PSC parts, I would run the swepco stuff they recommend
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3223 of 3234 Old 04-09-2021, 09:55 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Biggest upgrade to date, my co-pilot is ready to party
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3224 of 3234 Old 04-14-2021, 09:07 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Gonna end up modifying the stupid bracket. The resi doesnít clear my hood
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #3225 of 3234 Old 04-15-2021, 03:55 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Congratulations on the baby, sucks about the bracket. FWIW I went ACDelco fluid over swepco because I can source it easier if I need more especially out wheeling.
87TPIYJ is offline
