AzDevilYJ's build thread... finally - Page 195 - JeepForum.com
 336Likes
post #2911 of 2935 Old 09-21-2019, 08:43 AM
jmart2119
jmart2119's Avatar
So I have up and pulled the hinge and put it in the vice. Well I clamped the Fíer down hard and beat it like a red headed step child.
No luck... lol ended up bending and distorting the whole thing pretty bad so I said f it and ordered some new ones from Omix Ada
Do you think they come as pictured, with rust? Lol
2018 YJ of the Year
YJOTM | Aug'15 | Dec'16 | Jan'18
1989 YJ - 98 5.7L Vortec, 4L60E, NP241, D30+8.8, 5.13's, 35" ProComp MT2's
jmart2119 is offline
post #2912 of 2935 Old 09-21-2019, 10:28 AM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Pretty sure theyíre zinc coated. But patina is all the rage, so maybe??? Lol
Sent from my iPhone using Tapatalk
jmart2119 likes this.
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #2913 of 2935 Old 09-21-2019, 06:04 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Replaced all the fuel lines with the correct hosing finally. Out with the ptfe and in with the rubber.
Pulled the adjustable fuel regulator and added the gauge inline on the feed line
Ordered a 14lb spring to bump up the factory regulator within the throttle body
And picked up some 2Ē spacers for the front to help tuck my hubs into the wheels some
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2914 of 2935 Old 09-21-2019, 07:11 PM
Bong_Holyeo
Bong_Holyeo's Avatar
Report back how the oil cooler helps, Ive been meaning to add one to mine ever since you first mentioned it a few months back.
April 2018 YJOTM
June 2019 YJOTM
Bong_Holyeo is offline
post #2915 of 2935 Old 09-21-2019, 09:03 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
I forgot to mention, my oil cooler adapter put my oil filter right into my driveshaft so I ordered up a remote filter conversion which I can still use my cooler inline with it. Just got to figure out where I want to put it that is still convenient for oil changes.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2916 of 2935 Old 09-22-2019, 06:04 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Got the spacers on today. Now my hubs are much safer, although the front tires are completely outside the Jeep. Zero fender coverage
Got my hinges on today, and just my luck I have to break out the drill and grinder for these too lol the welded the ends of the pins. Also these are much thinner than the stock hinges. While they are steel, the feel is kinda cheap.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2917 of 2935 Old 09-23-2019, 06:13 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Ground the welds down and then punched the pins out. Finally a victory, small one but still.
Watching paint dry now... but a beautiful overcast day
87TPIYJ likes this.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2918 of 2935 Old 09-23-2019, 08:19 PM
Kenaikid123
Awesome!
Kenaikid123 is offline
post #2919 of 2935 Old 10-03-2019, 02:31 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Junkyard adventures from last sat.
Pulled this beast, then realized it was a d50 after it was out so we left it for some lucky person
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2920 of 2935 Old 10-09-2019, 11:32 PM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
$4 at Home Depot!
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2921 of 2935 Old 10-10-2019, 08:07 AM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Ordered another water pump cuz I like to waste money. Canít hurt, but It was highly recommended to me running a similar setup and the reviews online are excellent.
FlowKooler hi volume has a special impeller that moves a lot more water more efficiently
https://www.flowkoolerwaterpumps.com...32b6f473&_ss=r
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2922 of 2935 Old 10-10-2019, 08:29 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Cool. A water pump that says it is for rock crawling. I need to get some reliable gauges in my Jeep so I can get a better handle on typical operating temp. This will certainly be something to keep in mind if needed.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #2923 of 2935 Old 10-10-2019, 11:18 AM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Got this in the mail yesterday! Hopefully get some time to get the windshield back on today
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2924 of 2935 Old 10-10-2019, 11:48 AM Thread Starter
AZdEvilYJ
Keyboard Cowboy
AZdEvilYJ's Avatar
Iím running the factory yj gauges. They seem to be accurate. My gauge reads the same as the area around the sensor.
I do have an adapter to fit the yj sensor into the Chevy head so now that Iím thinking about it, it could be reading high because the head is heating the adapter? Not sure if thatís a thing tho.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #2925 of 2935 Old 10-10-2019, 12:43 PM
daddyjeep87
1987 YJ Wrangler
I do have an adapter to fit the yj sensor into the Chevy head.
That is most likely my issue. I have all of the GM sensors wired to the YJ gauges. I have been wanting to go with aftermarket anyway to get a fuel level gauge that works with the fuel cell and a trans temp gauge. I am going with the cheaper lines of Autometer gauges, Autogauge and Z series.
YJOTM August 19
