AzDevilYJ's build thread... finally - Page 110 - JeepForum.com
 498Likes
post #1636 of 3384 Old 08-04-2015, 02:24 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
just clearance the fire wall with a hammer
It will still be pretty close for comfort, and do you think it will still probably contact under motor twist? That would hear the floor board up pretty bad
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #1637 of 3384 Old 08-04-2015, 02:24 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Originally Posted by Randonexplosion
Will center dump headers land on your motor mounts?
I gotta do some reading... It would be close there too.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1638 of 3384 Old 08-04-2015, 02:47 PM
Randonexplosion
Randonexplosion's Avatar
With the poly AA bushings I don't think I get much drivetrain flex under load at all. My suspension sure twists when I put it in 4 low and hold the brake though
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #1639 of 3384 Old 08-04-2015, 02:56 PM
ashland82391
ashland82391's Avatar
I think you'll be fine. I think you should go with it.
ashland82391 is offline
post #1640 of 3384 Old 08-04-2015, 04:02 PM
zte87
GIVE IT THE ONION
zte87's Avatar
dido
zte87 is offline
post #1641 of 3384 Old 08-04-2015, 04:47 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Either way, they look F'n sick in there! :boner: lol
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1642 of 3384 Old 08-04-2015, 04:48 PM
ashland82391
now get that thing running!
post #1643 of 3384 Old 08-04-2015, 10:15 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
I'm curious as to what to do with the wires that plugged into the firewall bulkhead on the driver side.
Our jeeps have the same type of setup. Is that we're the engine and chassis harness plug into the underdash fuse box or what?
I cut those wires out of the plug because it was pack full of a black resin and I didn't wana make a mess of that crap. Im assuming those wires are the fused wires or am I way off?
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1644 of 3384 Old 08-04-2015, 10:48 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
It looks like they're the + 12v key-on feed for the sensors,etc. What's the best way to feed these key on power? Junction box to a single wire splice? Or fuse box?
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1645 of 3384 Old 08-05-2015, 01:33 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Found a bulkhead pinout for a 94 YJ in another thread, and supposedly 93-95 are the same.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1646 of 3384 Old 08-05-2015, 01:36 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Idk why the second one showed up so small. Ill scan in what I printed and post it larger since its the more important one
Edit - Actually they are the same, just show the male and female versions of the connectors, but the pinouts are identical
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1647 of 3384 Old 08-05-2015, 08:02 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Damn, Summit's shipping turn around is no joke!! Ordered these Monday night... One piece is was out of stock until next week, but started playing with the fittings and learning how they work.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1648 of 3384 Old 08-07-2015, 05:32 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
So I think Im gonna throw the headers up on CL for what I paid for them and order me up some either shorties or block hugger headers.
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1649 of 3384 Old 08-07-2015, 08:35 PM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Got the quick dc fittings in the mail and the jeep fuel lines I can say now are both 5/16" and fit the new fittings perfectly!
Also got my prefilter today!!
'95 YJ 2.5L
My Build Thread
-Albert Einstein
post #1650 of 3384 Old 08-08-2015, 01:45 AM Thread Starter
AZdEvilYJ
AZdEvilYJ's Avatar
Got the fuel lines hooked up. It was a pita to cut the braided line with old dikes but I managed. I took the second pic before I hooked up the return, but you get the idea. The fittings all worked out perfect. Now cross my fingers for no leaks but we can cross that path when we breathe life back into her soon! I should mention that I did have to move the ign coil To the firewall for the return line clearance
Size:  550.8 KB Name:  image-1499627138.jpg
Pulled the header and am looking at different options for headers. May go with center dump which for clearance of everything other than the motor mounts, may be the best option or go with manifold replacement shorty header. Hedman makes a YJ 350 swap, but then stainless version would be outa my budget for that. The ram horn manifolds are the overall best option for price, reliability and overall clearance but man I think they look lame as F. Name:  image-1657645693.jpg
'95 YJ 2.5L
My Build Thread
-Albert Einstein
