ABCs One ton XJ build - JeepForum.com
 16Likes
post #1 of 72 Old 10-06-2019, 11:30 PM Thread Starter
abc_was_here
abc_was_here's Avatar
1992 XJ Cherokee
I was in the middle of building my YJ when finding out my wife was pregnant, so I decided the YJ build was over. I want to build something a little more street friendly and easier to load gear, our dog, and something for the newest addition to our family.
All thats really left of the old YJ
still in the middle of parting the YJ out however ive also started the tear down of the cheap XJ I already owned as a future mud drag jeep. Now its going to get a 04 SD Dana 60 with spartan locker, and 78 GM 10.5 with Torq locker both with 5.38 gears.
Started working on in this week
1992 Cherokee 4.0L HO
Ax15 5 Speed (Swapped external slave from my YJ)
NP231J w/AA SYE and Teraflex 2 Low (also taken from my YJ)
Day I picked it up just as a one day some day project paid $250 bucks, not perfect cosmetically but rust free and a solid unibody.
lucky to have access to a lift got the transmission and transfer case swapped
moved it out of the shop to begin tear down
Got the axles and bumpers out over the weekend
Tires I got from a buddy 37/12.5r17s will last me long enough to decide to go large or buy new 37s
mounted on my beadlocks
Dana 60 and 14 bolt (need to get some paint on those new parts)
Some of the parts I need to install plus waiting on my Truss and 3 link Crossmember from a local company
1992 Jeep XJ one ton build
1995 Jeep YJ 4.0L wheeler PARTED
1992 Jeep XJ 4.0L Supercharged PARTED
abc_was_here is offline
post #2 of 72 Old 10-08-2019, 11:18 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Got more parts, these hiems from ruffstuff are beefy
got my new exhaust, 3 link crossmember, truss and stiffeners
some of my welds that seem to be improving
post #3 of 72 Old 10-09-2019, 07:07 AM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
Looks like this will be worth watching.
***Chris***
chris87xj is offline
post #4 of 72 Old 10-10-2019, 11:01 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Ran out of welding wire so I fired up the plasma cutter and cut off the perches I recently welded on for the YJ
Not the greatest with the plasma cutter and managed to blow through a tip pretty quick (helps if you remember to turn on the air compressor) lol still way better then using cut off wheels!
post #5 of 72 Old 10-10-2019, 11:04 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Hopefully I can keep some updates coming! I've got some unrealistic aspirations when I want this thing wheelable.
post #6 of 72 Old 10-15-2019, 11:05 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Getting started on the frame stiffeners, I need to go buy a couple more C-clamps and replace the ends on my extension cord for my welder so I can reach the jeep outside the garage.
This thing was completely in the way. Read several things saying to modify the stiffener to fit around it, instead Im going to weld it back onto the stiffener.
getting the rail all cleaned up
all mocked up
post #7 of 72 Old 10-16-2019, 09:58 AM
lovett86
lovett86's Avatar
Pretty nice build your doing
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #8 of 72 Old 10-17-2019, 10:57 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Thanks! hopefully it stops raining so I can get more stuff done.
post #9 of 72 Old 10-24-2019, 10:43 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Finally got got the rear frame stiffeners finished. Once the new fuel filler lines in I can reinstall the fuel tank and get started on the rear suspension. I also got made the rear bastard pack.
also my welder broke and a friend let me borrow this bad boy
Leisnerracing77 likes this.
post #10 of 72 Old 11-09-2019, 12:25 AM Thread Starter
abc_was_here
1992 XJ Cherokee
Finally got to do a little more work on the Jeep. Got the gas tank reinstalled, new filler hoses, gas tank skid, hitch, shackle relocation boxes, lift shackles, and my bastard pack.
part of the reason I havent been working on the XJ, been a long time project and used rubbing compound and wax. Really impressed how it turned out. wish I took a good before and after shot.
post #11 of 72 Old 11-09-2019, 10:27 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Got the rear end mocked up
Shackle angle to much?
Really not as much lift as I was expecting, I still think after trimming a 37 will fit just fine
post #12 of 72 Old 11-10-2019, 09:42 PM Thread Starter
abc_was_here
1992 XJ Cherokee
Finished burning in the new leaf spring perches, and got the rear end bolted in so I can remove the rear jack stands to install the mid unibody stiffeners.
now that all the holes are marked just need to clean up the rail and start welding
post #13 of 72 Old 11-23-2019, 12:07 AM Thread Starter
abc_was_here
1992 XJ Cherokee
Finally got the frame stiffeners finished up. Took way longer then I was expecting, and went through a ton of welding wire and gas.
Cleaning up the front part of the frame rails to make room for the front bumper
Starting mocking up my lower frame side 3-link bracket
Just wanted to see how the 37s looked
post #14 of 72 Old 11-23-2019, 12:13 AM Thread Starter
abc_was_here
1992 XJ Cherokee
Also scored a OR-Fab rear bumper, I had to straighten it since it was on a jeep that rolled but turned out pretty good.
Also got some Rusty's sliders in the deal, now I just need to clean them up and paint them. Satin or Gloss?
post #15 of 72 Old 11-25-2019, 12:38 AM Thread Starter
abc_was_here
1992 XJ Cherokee
Worked a little on the Jeep this weekend. Got part of the exhaust finished, Ill let the exhaust shop finish it over the axle when its drive able.
Cleaned up the passanger side of the dana 60 to make room for the truss, now I need to trim a bit off the short side to make room for the lower link mount.
