94 YJ Sahara Build - JeepForum.com
 4Likes
post #1 of 19 Old 01-24-2020, 09:21 PM Thread Starter
YJ94TX
Junior Member
94 YJ Sahara Build
Picked up a 94 YJ Sahara with 313,000 miles in decent condition and no rust. Hoping to get help from experts on this forum as I go through this journey!
As-is pictures to follow...
YJ94TX is offline
post #2 of 19 Old 01-24-2020, 09:28 PM Thread Starter
YJ94TX
Junior Member
Exterior in decent shape.
Sent from my SM-G960U using Tapatalk
YJ94TX is offline
post #3 of 19 Old 01-24-2020, 09:38 PM Thread Starter
YJ94TX
Junior Member
Interior a little rough...
YJ94TX is offline
post #4 of 19 Old 01-29-2020, 06:52 AM
lovett86
lovett86's Avatar
Looks like a good jeep to start with
YJ94TX likes this.
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #5 of 19 Old 01-30-2020, 06:21 PM
cpia84
cpia84's Avatar
Definitely a good starting point. I would just do basic maintenance first and then drive it. See what leaks, what doesn’t leak. Does oil burn. Any noises from the engine. And then start addressing any issues that come up. Once the drive train is good and you know everything is driving and shifting well then work what you want to do next. I’m a fan of new projects and yours looks like a great start!
ppine likes this.
cpia84 is offline
post #6 of 19 Old 01-31-2020, 11:56 PM Thread Starter
YJ94TX
Junior Member
Originally Posted by cpia84 View Post
Definitely a good starting point. I would just do basic maintenance first and then drive it. See what leaks, what doesnít leak. Does oil burn. Any noises from the engine. And then start addressing any issues that come up. Once the drive train is good and you know everything is driving and shifting well then work what you want to do next. Iím a fan of new projects and yours looks like a great start!
Thanks for the advice. There are no leaks and engine runs ok. all gears engage but it hard to shift though. right now i am trying to remove everything that rattles
YJ94TX is offline
post #7 of 19 Old 01-31-2020, 11:58 PM Thread Starter
YJ94TX
Junior Member
I am planning to get rid of the hard top. Its in pretty good condition. Trying to see if there are folks looking for a 94 YJ hard top in the Houston area.
YJ94TX is offline
post #8 of 19 Old 02-01-2020, 08:35 AM
lovett86
lovett86's Avatar
That hard top should fit anything from an 85 to a 95 yj/cj 7 so you should be able to do something with it
its a rusty one
lovett86 is offline
post #9 of 19 Old 02-01-2020, 01:00 PM Thread Starter
YJ94TX
Junior Member
Thanks. I will post in the classifieds..
YJ94TX is offline
post #10 of 19 Old 02-01-2020, 01:04 PM Thread Starter
YJ94TX
Junior Member
I noticed some light surface rust on the tub near the pedals. What is the best way to stop it for now until I get the body blasted/repainted probably in a few months?
YJ94TX is offline
post #11 of 19 Old 02-08-2020, 11:11 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Take a wire brush to it to knock off the loose rust, and then brush on some POR 15.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #12 of 19 Old 02-23-2020, 11:59 AM Thread Starter
YJ94TX
Junior Member
Thanks.
YJ94TX is offline
post #13 of 19 Old 02-23-2020, 12:06 PM Thread Starter
YJ94TX
Junior Member
Finally got some time to work on the jeep. Got rid of the hard top and the dash pad and all the panel stuff.
Found at least 10 cigarette lighters stuffed in between the dash pad and windshield. There were a few inside the wiper assembly channel... Lol
YJ94TX is offline
post #14 of 19 Old 03-02-2020, 05:22 PM Thread Starter
YJ94TX
Junior Member
Picked up an 8.8 rear from a 98 explorer and a waggy 44 housing for the front.
YJ94TX is offline
post #15 of 19 Old 03-02-2020, 08:04 PM
lovett86
lovett86's Avatar
Are you going to run 2 different bolt patterns or are you going to re drill one of them.
its a rusty one
lovett86 is offline
