90 yj frame swap and build up - Page 10 - JeepForum.com
post #136 of 185 Old 08-22-2016, 03:17 PM Thread Starter
lovett86
lovett86's Avatar
Spent some time at the wrecking yard to see what they had, I was already there getting a door for a friends car. Thought I found the perfect truck but it turned out to be a 5.2 and not the 5.9. I've been looking on Kijiji at vans and trucks, seen a few but nothing close enough to me
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #137 of 185 Old 11-27-2016, 07:30 PM Thread Starter
lovett86
lovett86's Avatar
Bought another dash and a rad for it, the jeep is taking a time out for a while, will still be collecting parts for it. We have a new edition to the family and a my wife got her dream car from her dad. So the Camaro is going to be first on the list of things to do
its a rusty one
lovett86 is offline
post #138 of 185 Old 01-29-2017, 02:33 PM Thread Starter
lovett86
lovett86's Avatar
No progress on the car or jeep, but the other day at work I put a 2 1/2 skyjacker lift kit on one of our parts guy's jeep, it was a 2013 wrangler
its a rusty one
lovett86 is offline
post #139 of 185 Old 04-22-2017, 06:50 PM Thread Starter
lovett86
lovett86's Avatar
Sold the original engine today and used the jeep as a work bench
its a rusty one
lovett86 is offline
post #140 of 185 Old 07-03-2017, 08:29 PM Thread Starter
lovett86
lovett86's Avatar
I have my pieces for my transmission crossmember at work and I loaded up some hardware for it into the car tonight. Hopefully gonna at least tac weld some of it together tomorrow
its a rusty one
lovett86 is offline
post #141 of 185 Old 07-19-2017, 10:00 PM Thread Starter
lovett86
lovett86's Avatar
Made some progress on the crossmember. Welded nuts to the center plate then welded plate into place
its a rusty one
lovett86 is offline
post #142 of 185 Old 07-21-2017, 04:24 PM Thread Starter
lovett86
lovett86's Avatar
A little more welding done today. Got the 2 inner end peices in place
its a rusty one
lovett86 is offline
post #143 of 185 Old 07-23-2017, 01:49 PM
RedJeepster1
RedJeepster1's Avatar
Why not take the couple minutes to clean up the steel before welding? Will make it weld a little easier.
Sent from my iPhone using Tapatalk Pro
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Silver XJ, 4.0, AW4 with 350k+, Locked C8.25 w/ Chromos, Trussed hp30, 4.56's, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's
RedJeepster1 is online now
post #144 of 185 Old 07-23-2017, 04:30 PM Thread Starter
lovett86
lovett86's Avatar
I cleaned up about a 1" area around the area I needed to weld. Will clean the whole thing up before I paint it. My phone takes horrible pics
its a rusty one
lovett86 is offline
post #145 of 185 Old 01-10-2019, 06:29 PM Thread Starter
lovett86
lovett86's Avatar
Haven't really done anything in the last year with the jeep. Just moved it in and out of the drive way. Ordered a gasket kit for the dana 300. Started working on the wiring harness for the engine today and seeing about building a new shifter for it
its a rusty one
lovett86 is offline
post #146 of 185 Old 01-12-2019, 04:34 PM Thread Starter
lovett86
lovett86's Avatar
Cleaned up and degreased the wiring harness for the jeep at work. Going to start removing all of the unnecessary wiring for the computer since il be running a carb set up. I have Monday off from work. Have to do a couple things around the house then I'm spending some time on the jeep again.
Here's a picture of the wiring harness
mostly cleaned up. I already spliced a new trailer wire harness into the rear vehicle harness as well20190112_151438_1547335974412.jpg
its a rusty one
lovett86 is offline
post #147 of 185 Old 01-12-2019, 06:02 PM Thread Starter
lovett86
lovett86's Avatar
Also just ordered a new lower steering column bearing kit
its a rusty one
lovett86 is offline
post #148 of 185 Old 01-14-2019, 03:58 PM Thread Starter
lovett86
lovett86's Avatar
Column bearing kit came in today
its a rusty one
lovett86 is offline
post #149 of 185 Old 01-15-2019, 09:05 PM Thread Starter
lovett86
lovett86's Avatar
Did some work on my cj dash. Made a new hole for the yj heater controls. I'm going to make a new switch panel where the cj heater controls originally went. The new switches will be for the extra lights, winch and what ever else gets added. Took a pic of my work bench at work. Brought my jeep parts to work so I'd have something to do since its slowing down at work
its a rusty one
lovett86 is offline
post #150 of 185 Old 01-15-2019, 09:08 PM Thread Starter
lovett86
lovett86's Avatar
its a rusty one
lovett86 is offline
