2000 Jeep TJ 5.2 Magnum Swap Build - Page 4 - JeepForum.com
 27Likes
post #46 of 89 Old 10-28-2019, 06:16 AM Thread Starter
wytetrash
wytetrash's Avatar
Well, it’s alive!.....kinda. Finished installing the flywheel, clutch, transmission and bellhousing, etc etc. Went to fire it up and it dies after 2-3 sec max. From all the research I’ve done, it seems like more than likely the SKIM system in the ZJ ECU I’m using. I didn’t plan on using this ECU long term anyway, since it’s for an auto trans. Heres a video!
Only codes that I have are for the evap(not hooked up yet), and the auto trans, so this still leads me to believe it’s the SKIM system. Will be testing it with a certified non skim ECU to rule it out. Only other thing it could be would be the ASD being wired improperly. I feel like I wired it right the first time so let’s hope that isn’t it. Was an amazing feeling though when the engine fired for the very first time!
Here's a tip for people who have worried about getting the transmission mount in place since it obviously wouldnt reach the stock mounting location, IF you place the AA mounts in the recommended location and you're using a manual transmission. People talk about needing to beat in the firewall, and all sorts of stuff; barely being able to get the transmission mount holes to line up, or having to fab up a trans mount out of 2 different mounts. I just bought the Barnes 4WD skidplate, which has a ton of front-to-back adjustment for where you're transmission mounts can be placed. This made mounting the transmission EXTREMELY easy. Just a quick tip. Here is a link to the skidplate.
https://www.barnes4wd.com/Jeep-TJ-Bo...ate_p_867.html
07wurubi and Jeepfreco like this.
2000 Wrangler TJ - 5.2 Magnum Swap
2003 Volkswagen Jetta TDI - 250k Mile Daily
wytetrash is offline
post #47 of 89 Old 10-28-2019, 06:30 PM
Jeepfreco
Jeepfreco's Avatar
That's awesome! Great progress so far, sounds good even for running for only 2 seconds. Hopefully you figure out what the cause is that is keeping it from running for more than 2 seconds!
Jeepfreco is offline
post #48 of 89 Old 10-29-2019, 07:47 AM Thread Starter
wytetrash
wytetrash's Avatar
Thanks! This is a common problem when people do this swap, I'm pretty sure it's more than likely the SKIM system inside the ZJ ecu.
post #49 of 89 Old 11-04-2019, 06:10 AM Thread Starter
wytetrash
wytetrash's Avatar
Its alive! Tested it with a verified non-skim ecu from a buddies Jeep and it fired up and ran great! Such a good feeling knowing that I did the wiring correctly, etc. Now for all the other items: radiator/cooling system, driveshafts, and exhaust and it will be driving on the road! Also have to do something with my shifter but I have a pretty good idea of what I'm going to do, based on what I saw another member on here do in his build thread. Stay tuned!
post #50 of 89 Old 11-11-2019, 06:39 AM Thread Starter
wytetrash
wytetrash's Avatar
Its starting to look like a Jeep again, installed the radiator, ZJ clutch fan, and 4.0 fan shroud, which all worked out perfectly.
post #51 of 89 Old 11-11-2019, 04:08 PM
Jo3Gee
Jo3Gee's Avatar
Here’s the flex radiator hose i used. I also got silicone adapters to attach it with t-bar clamps. But you can probably find rubber hose adapters even cheaper.
http://www.siliconeintakes.com/elect...RoCULQQAvD_BwE
wytetrash likes this.
Jo3Gee is offline
post #52 of 89 Old 11-12-2019, 08:18 AM Thread Starter
wytetrash
wytetrash's Avatar
Cool thanks for the link!
post #53 of 89 Old 11-15-2019, 08:18 PM
wildman4x4nut
wildman4x4nut's Avatar
Great job so far and love seeing these V-8 swaps into the TJ's. I have a 5.2 in mine right now but am building a 5.9 for it that I have a stroker kit for so it will make it a 6.7 (408) when done. I'm running a 46RE tranny with a STaK's 3 speed transfer case.
I must have missed it but what radiator did you use? Are you using a mechanical fan or electric? I'm sure you are getting super excited about getting this done and can't wait to drive it again. If you are looking for any performance parts I have some I have bought that I can't use for my new engine.
Jo3Gee likes this.
WILDMAN
Cle Elum, WA
wildman4x4nut is offline
post #54 of 89 Old 11-17-2019, 06:52 PM
kerryike1223
Please detail what you do with your shifter. (I assume it's a manual). I have modifications to do to mine after putting in a Chevy 5.3 for the same reasons you do, but the bending and adding length to the shifter will probably have to be pretty drastic.
kerryike1223 is offline
post #55 of 89 Old 11-18-2019, 05:46 AM Thread Starter
wytetrash
wytetrash's Avatar
I just used an OEM radiator. There are several of these swaps (that were kept stock) that used the OEM radiator and they cooled fine. If I have any issues, ill upgrade it to an aluminum one, but it seems like more times than not, even the big name brand ones seem to leak at the welds. And for the fan, I just used a ZJ mechanical clutch fan and a 4.0 fan shroud.
post #56 of 89 Old 11-18-2019, 05:47 AM Thread Starter
wytetrash
wytetrash's Avatar
I certainly will. I am pretty sure what I am going to do is cut the shifter at the bottom, add a small 2.5" plate to move the shaft back and weld it together. I got the idea from another member on one of the forums, and it worked well for him.
post #57 of 89 Old 11-18-2019, 02:43 PM
wildman4x4nut
So just so I understand correctly you are using the stock ZJ radiator? Did it just bolt up to the TJ?
Yes I agree many aftermarket radiators leave a lot to be desired. I have had two different ones in my TJ so far and the aluminum one is a piece of junk that COST way more than I should have spent.
Due to my engine placement I have to run a electric fan but sure would like to try a mechanical fan. Might have to look at what I can do with that.
WILDMAN
Cle Elum, WA
post #58 of 89 Old 11-18-2019, 06:07 PM
Bmann412
Bmann412's Avatar
1930
I would suggest bracing that plate. Helped stiffen up my shifter. I can get a picture if needed.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #59 of 89 Old 11-19-2019, 06:12 AM Thread Starter
wytetrash
wytetrash's Avatar
No I am using the TJ radiator. ZJ radiator wouldn't fit. I trust a brand new OEM radiator more than an aluminum one. Even the "higher up" brands have been known to leak. If one day down the road I have an issue, I can always change it easily.
post #60 of 89 Old 11-19-2019, 06:13 AM Thread Starter
wytetrash
wytetrash's Avatar
YES! That would be great if you could show me a picture of what you are talking about!!! I really appreciate it.
