1964 CJ6 long term restomod - Page 11 - JeepForum.com
 49Likes
post #151 of 254 Old 10-25-2017, 01:36 PM Thread Starter
y2k-fxst
1964 CJ6
Got the gouges from cutting off the spring mount filled and ground. And, the spring mount welded in it's new home. Can't go any further till I get springs. Was going to finish the last body mount for the Jeep but, broke my band saw blade yesterday and don't have any more spares.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #152 of 254 Old 10-29-2017, 06:41 PM Thread Starter
y2k-fxst
1964 CJ6
Hopefully the last modification to the frame. Body mount hole is too far back and the bushing wouldn't go in. Only really needed 1" but, all I had was some 1.5" so that's what I used.
All cleaned up and ready to put the body back on and see if my measurements were good!
y2k-fxst is offline
post #153 of 254 Old 11-11-2017, 07:41 PM Thread Starter
y2k-fxst
1964 CJ6
Messing around out in the shop tonight, not really doing anything. Was looking at the OME YJ springs that arrived Thursday for my CJ.
Figured out why a lot of people complain about caster angle when doing the YJ on a CJ spring swap. The top plates where the axle rests are angle shims. Most people end up running 4 rear springs when they do the conversion, since the rear springs are heavier than the front springs. With those shims it would help to point the pinion up to compensate some for the lift.
But on the front it would still raise the pinion angle also, causing the caster to be less. If they are used with a stock CJ axle I'd either reverse the shims to get more caster or even get some flat plates made depending on how it does at the alignment shop. But, since I'm building my own axle and have already decided to do the cut and turn to correct the caster. I'll leave the plates where they are and just enjoy better pinion angle.
y2k-fxst is offline
post #154 of 254 Old 11-12-2017, 06:18 PM Thread Starter
y2k-fxst
1964 CJ6
Got the OME springs under the CJ. Sat the front axle in place to see if I had the spring mounts in the right place. Fit like a glove! Just need the U-bolts to finish the install.
Dug the 9" Ford axle for the rear out and tore it apart. Found 2 gaskets and silicone between the hog's head and the housing. While I was turning it trying to find the stampings on it to figure out the gear ratio. I noticed there was burrs on the outside of the ring gear. And, I noticed a lot of back lash so I played with it some more. Then found side play in the carrier instead of bearing preload. Threw my dial gauge on it, 0.044" side to side play! Was going to try to install the new Detroit Locker and gears myself, have never done a rear end myself. But, since I haven't found specs on the actual preload I was going to play with it some before I tore it apart. So, I'll probably take it somewhere and let someone that actually knows what they are doing build it. Figure it must be a feel thing like torquing head bolts on a iron head Harley.
Threw the hog's head back in until I can get the new axle shafts, spiring mounts, and U-bolts.
y2k-fxst is offline
post #155 of 254 Old 11-25-2017, 03:07 PM Thread Starter
y2k-fxst
1964 CJ6
Ready to start welding my U-bolt skid plates.
Got 3 out of 4 of them ready to drill, then ran out of welding wire. Wouldn't be so bad but, I just drove past Praxair yesterday when I picked up steel!
y2k-fxst is offline
post #156 of 254 Old 11-27-2017, 05:27 PM Thread Starter
y2k-fxst
1964 CJ6
Been looking for a reasonably price NV4500 for the Jeep for the last 3 years. Rebuilt without a core they are going for around $2,500. Picked this one that was rebuilt 20,000 miles ago up off Craigslist today with a bunch of accessories that don't come with the rebuild that are out there. After adding up the accessories that came with it I'm into the transmission around $175, will have another $500-$600 in parts and labor turning it into a 4wd transmission.
scramboleer likes this.
y2k-fxst is offline
post #157 of 254 Old 11-28-2017, 01:20 PM
AZdEvilYJ
AZdEvilYJ's Avatar
Score!! They’re hard to come by
Sent from my iPhone using Tapatalk
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is online now
post #158 of 254 Old 11-29-2017, 08:04 PM Thread Starter
y2k-fxst
1964 CJ6
Hence the 3 year search, Just wish it had been a 1998 or newer. The square top shifter boss does have a smoother shifter action.
y2k-fxst is offline
post #159 of 254 Old 12-15-2017, 04:45 PM Thread Starter
y2k-fxst
1964 CJ6
So picked up up a 3/4" to 1/2" impact socket to use to make my 3/4" drive 29 spline socket. The 5th gear nut on a NV4500 is torqued to 300 ft/lbs. A lot of people will just engage the 3rd and 4th gear syncros to jamb the transmission to torque the nut, some just wrap a rag around the input shaft to hold it in 1st gear to tighten it. I'm not a fan of either as that 300 ft/lbs is transmitted to the output bearing as a side load, synchros, gears, etc. With the correct socket there is only about 1/2" between the end of the socket and the actual 5th gear nut.
Cut the 1/2" drive stub off and ground everything smooth. Hit the top edge with the grinder to remove oxide coating where my weld will go. Ready for the freezer to help shrink it a little. The chrome version of this adapter is a slip fit but, didn't want to mess with chrome messing with my welds.
Started with a cold 3/4" adapter and a warmed 29 spline coupler. Got it 3/4 of the way with a 2.5# press. But had to finish with my 8# press. Enough of a interference fit I can see where the splines inside the coupler gouged into the 3/4" adapter!
All finished, my cost was 1/3 of a commercially made socket. And the commercially made sockets only engage about 1/2 the length of the splines one the output shaft, this one engages 100% of the splines. Might even put this in the blaster and then hit it with some flat black paint to make it look factory made!
y2k-fxst is offline
post #160 of 254 Old 12-22-2017, 06:50 PM Thread Starter
y2k-fxst
1964 CJ6
Got my U-bolt skid plates drilled last weekend. Then finished up the "machining" today and welded off. While I was "machining" them with a die grinder and angle grinder I was wishing I had a CNC mill. Later on I decided I would be happy with an analog one!
Ran out of carb cleaner cleaning the oil off the skid plates from drilling, so I finished up with brake clean, and yes I know you are not suppose to use brake clean because of the danger of making phosgene gas. I blew them off good and tried to make sure they were dry before welding, plus stood a couple of feet inside an open overhead door where if I passed out there was a possibility I'd fall into fresh air. Took this picture just to prove I lived!
Got the first front one done and had to try it.
Even the second one fit. Almost as though I measured it or something! Really hope the springs settle some when I get the power train in it. Right now with the axle set at the height it will be with 33" tires, I'm at 30" to the top of the frame!
Rear ones waiting for me to get my axle cut down.
y2k-fxst is offline
post #161 of 254 Old 12-23-2017, 09:21 AM
Jim1611
Jim1611's Avatar
Nice work and excellent buy on the 4500!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #162 of 254 Old 12-25-2017, 05:45 PM Thread Starter
y2k-fxst
1964 CJ6
Got my 9" rear end completely bare naked today. Little more cleaning and degreasing it will be ready to be cut down as soon as my new axles show up.
y2k-fxst is offline
post #163 of 254 Old 01-08-2018, 01:32 PM Thread Starter
y2k-fxst
1964 CJ6
Yukon axle shafts, bearings, studs, and retainers showed up today for my rear axle. Don't think the post office was really impressed with the weight of the box! So next time I've got a few days off I can start cutting down the axle housing. Just need to order Torino style retainers since the axles are meant for the old style large bearing 9" that's the retainers that came with them. Getting closer to have my 9" service stand done, that's it sitting above the axles.
y2k-fxst is offline
post #164 of 254 Old 01-11-2018, 05:54 PM Thread Starter
y2k-fxst
1964 CJ6
With only 1 day off, didn't feel like starting any big project. So I finished up the repair stand for the Ford 9". Normally would have probably not spent so much time on one. But, since I'm running one in the CJ and my oldest son is running one in his dirt car figure it will be used more than once.
y2k-fxst is offline
post #165 of 254 Old 01-19-2018, 01:39 PM Thread Starter
y2k-fxst
1964 CJ6
Finally got the 9" cut down and placed under the back. Once the power train is in and the suspension in loaded I can set the pinion angle and weld on the spring mounts and the bearing housings. Hoping the springs droop a little when I get it loaded down. right now the way it sits, it will be 36" to the bottom of the door opening with 33" tires!
Draining the oil out of the next piece of this puzzle. Need to hit it with some degreaser and run it to the car wash Sunday. Then start tearing it apart to make it into a 4wd transmission.
y2k-fxst is offline
