Ramsey REP8000 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Ramsey REP8000
Rating:
Product Information
MSRP: $400.00
Average Price: $265.25
Manufacturer: Ramsey
Recommended?
Yes: 24 / No: 0
8000-lb permanent magnet motor with planetary gears
None
Page 1 of 2 1 2 > Last
Eric1080
Eric1080's Reviews
11-22-2014, 01:19 PM
Price: $100.00
Pros: works when I need it
Cons: cable attachment a little loose
Recommended? Yes
Comments: has never let me down even pulling a heavy truck out of the mud or up a rock wall. Ramsey #1
Jwhughes3
Jwhughes3's Reviews
10-23-2014, 05:44 PM
Price: $300.00
Pros: Long track record
Cons: None yet.
Recommended? Yes
Comments: Bought mine well used - still shows good power - went ahead and replaced solenoids for long life. May replace cable to synthetic in the future. Added a cable stop bumper.
Saul32
Saul32's Reviews
02-25-2014, 12:35 AM
Price: $40.00
Pros: Pulling my buds xj out every time he is stuck
Cons: Getting calls to pull my buds XJ
Recommended? Yes
Comments: Bailed my bud and myself out several times already. It came with my truck when I bought it. I recommend RAMSEY winches after the performances its provided for me in times of desperation.
ggarland
ggarland's Reviews
02-19-2013, 07:40 AM
Price: $0.01
Pros: Had this for so many years I don't know exactly how long. At least 20 or more. Still going strong.
Cons: None at this time.
Recommended? Yes
Comments: I first purchased this winch to go on an 81 CJ5 from Leon Rosser in Bessemer, Alabama. I used it on that Jeep until the Jeep motor blew up. It set in a shed then for several years. I just recently installed it on our "new" Wrangler and the only thing I had to do to it was replace the female plug because the conductors had corroded. This is a great and dependable product. It is particularly useful for pulling Ford trucks out of skidder holes.
60perry
60perry's Reviews
12-07-2012, 05:08 PM
Price: $200.00
Pros: Low profile
Cons: n/a
Recommended? Yes
Comments: The Ramsey Pro 8k has done very well. We have used it countless times for recovery of Jeeps and H2's. It has held up to all the abuse and never let us down.
debri81
debri81's Reviews
06-18-2011, 11:06 PM
Price: $400.00
Pros: You can wheel by yourself knowing you most likely can get yourself home again.
Cons: None
Recommended? Yes
Comments: Know how much a tree skidder costs to get your butt out of the woods? I do.
SavannahJeep
SavannahJeep's Reviews
03-10-2010, 03:46 PM
Price: $300.00
Pros: Remote use
Cons: None
Recommended? Yes
Comments: Got it used for $300 with a plate to mount on my factory bumper. Remote works great for safe useage from the cab of the Jeep. It hauls line and pull trucks out. Hasn't failed yet.
mccgsm
mccgsm's Reviews
08-08-2009, 04:15 PM
Price: $400.00
Pros: Strong, reliable winch; divorced solenoid facilitates creative mounting/better airflow. Very good value for cost.
Cons: Well, it did die, eventually. Solenoid is not sealed, housing cracked once.
Recommended? Yes
Comments: Bought 1990, used on 2 XJs, 1 Explorer, 1 Expedition, 1 Suburban, until its demise on my TJ. Bagged three elk with it; only totalled one jeep.
Fragged the main gear unit (nearest drum) while winching danger tree away from my vacation trailer. 20 years heavy use, but still disappointing; I suspect it would still be running if I hadn't shock loaded it periodically over the years. Carrier cracked, gears went cattywumpus, stripped two planetary gears and about 20% of gear housing teeth were stripped. Jammed solid; fortunately I was able to throw it in reverse and flip the tree the right way. Strong winch, but not as strong as my old Belleview 6K winch that outpulled any 8K I ever saw.
It was adequate single line on the XJs, but snatch block was frequently used on the other rigs and necessity with the Suburban--very nearly left that in the woods, but for (ahem) having two snatch blocks that day (and ever since). Slow, but implacable when triple lined.
I strongly suggest a teardown every 5 years to check gears for wear, clean and regrease. Had I done that (and refrained from jerking it a few times too many) likely would have had it another couple decades.
Many worry about the permanent magnet motor; mine was still going strong after 20 years.
jeepbub08
jeepbub08's Reviews
05-26-2009, 09:34 AM
Price: $450.00
Pros: Tough, simple, durable.
Cons: slow line speed
Recommended? Yes
Comments: I used this winch a few times, and I love it. Line speed is a little slow but It does the job and does it well. Its a durable winch and simple to use.
Cyrix
Cyrix's Reviews
05-11-2009, 08:23 AM
Price: $300.00
Pros:
Cons: None
Recommended? Yes
Comments: Very good winch, no problems yet.
R1RN04
Guest
R1RN04's Reviews
04-02-2009, 01:43 PM
Ramsey REP8000
Price: $400.00
Recommended? Yes
Comments: It works, Not the best not the worst. functions well, very noisy. -------------------------------------------------------------
JohnB97XJ
JohnB97XJ's Reviews
12-13-2008, 10:18 PM
Ramsey REP8000
Price: $240.00
Recommended? Yes
Comments: Good so far. Limited use. Bought it used three years ago.
Doitsouthstyle
Doitsouthstyle's Reviews
12-11-2008, 08:35 PM
Ramsey REP8000
Price: $400.00
Recommended? Yes
Comments: It is exactly a Quick Mount 8000 lbs. But is perfect for removal and keeping out of un-needed weather. And never could not get me or any of my friends out of a hole.
acrijos
acrijos's Reviews
11-14-2008, 02:52 PM
Ramsey REP8000
Recommended? Yes
Comments: I have had this winch for 8 years and it has never failed me. I have not had a reason to replace it yet.
ghost183
ghost183's Reviews
09-04-2008, 08:35 AM
Ramsey REP8000
Price: $300.00
Recommended? Yes
Comments: good for the price
jeepron
jeepron's Reviews
08-17-2008, 12:52 PM
Ramsey REP8000
Price: $100.00
Recommended? Yes
Comments: haven't used it yet i drive a jeep
bamakrw
bamakrw's Reviews
08-06-2008, 11:42 PM
Ramsey REP8000
Price: $250.00
Recommended? Yes
Comments: For your avg joe and for avg uses, it works great.
For competition stuff, probably not your pick.
stuff2c
stuff2c's Reviews
08-04-2008, 03:52 PM
Ramsey REP8000
Price: $150.00
Recommended? Yes
Comments: it's an old one...bought it on craigslist took it apart and cleaned it up and lubed it.
but a good one!
Bill M.
Bill M.'s Reviews
07-19-2008, 06:02 AM
Ramsey REP8000
Price: $400.00
Recommended? Yes
Comments: Well built and strong winch. I picked this up used but it is still good as new. It has gotten me out of a few binds!
Jeepinty
Jeepinty's Reviews
05-21-2008, 01:37 PM
Ramsey REP8000
Price: $400.00
Recommended? Yes
Comments: Fantastic winch for the money. Came with another jeep I sold and has gotten me and others out of many jams.
ThreadForumRepliesLast Post
Ramsey REP 8.5e Winches 6 12-19-2014 02:03 PM
Ramsey rep6000 Winches 2 05-23-2012 09:40 PM
Ramsey REP 9.5 E Winches 2 05-13-2009 11:27 AM
Ramsey REP 9000 Winches 2 04-06-2009 09:11 PM
ramsey qm5000 Winch Cable and Hooks 1 12-22-2008 07:05 PM
