Wiring stock fog lights - JeepForum.com
post #1 of 4 Old 10-28-2007, 04:39 PM Thread Starter
BUSAFREAK
Guest
I got some windshield brackets for lights and I have an extra set of stock fog lights that i wanted to mount on there. Can I use this same diagram to wire them up?
Or would I have to use a relay for each light?
The reason I ask is because on the factory wiring diagram for the factory fogs, it uses 2 relays (Fog lamp relay one and Fog lamp relay 2).. But then they also hook up to other things that I won't be hooking up to. Just an on/off switch.
BUSAFREAK is offline
post #2 of 4 Old 10-28-2007, 04:47 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I like this KC schematic better: http://www.kchilites.com/faq/instruc...layDiagram.pdf
Cut and dry. The plan you have runs constant hot power to the switch Bad idea. You would need a switch rated for whatever you are fusing your lights with. Not a good idea. With the KC plan, you can wire up two lights very easily and run a low amp switch to the dash, fused of course. 3 amps is plenty. Then run your power to the relay with a 25Amp fuse.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 4 Old 10-28-2007, 05:55 PM Thread Starter
BUSAFREAK
Guest
That is great info. Thank you so much for your help.. I will do it as described in that diagram..
post #4 of 4 Old 10-28-2007, 06:20 PM
rustywrangler
Glad to help
white lights for TJ? With stock fog lights? muddn1t Audio, CB & Ham Radios, GPS, & Electrical 0 10-29-2009 01:52 PM
'89 stock radio lights up when lights are on. Won't turn on :( TheGrimJeeper Audio, CB & Ham Radios, GPS, & Electrical 0 05-12-2009 08:26 PM
Wiring Off-road Lights to Stock Fog Light Switch rocketman121 Audio, CB & Ham Radios, GPS, & Electrical 0 05-06-2007 03:15 PM
Problems wiring KC lights to stock fog light switch? ATL TJ Audio, CB & Ham Radios, GPS, & Electrical 3 06-22-2005 10:54 AM
wiring lights Glass Audio, CB & Ham Radios, GPS, & Electrical 2 06-11-2005 04:27 PM
