wire too large? - JeepForum.com
post #1 of 5 Old 09-15-2009, 09:28 PM Thread Starter
Anonymous6915
2009 JK Wrangler
wire too large?
in gauge...
i bought two of these
im in the process on installing them but just for ****s and gigles, i connected them straight to my power source to see how bright they were....no go...i used 12ga. wire...is it overkill or am i just doing something wrong? im not 100% on my ground so i will see if thats the problem tomorrow,
jus wondering about the wire...
Anonymous6915 is offline
post #2 of 5 Old 09-15-2009, 11:29 PM
Danbert
1983 FSJ Wagoneer
12awg wire is not too big for those lights. They should work although you should verify with the manufacturer what the proper size to run is.
For the most part you cant get in trouble using too big of a wire.
But even if the wire were too small, it should still pass enough to light the bulb even a little. Definitely check your ground.
Danbert is offline
post #3 of 5 Old 09-16-2009, 07:09 AM
SirGCal
RIP
SirGCal's Avatar
In this situation; basically you can never be too large. It is overkill perhaps but not by much. I actually wire almost all aftermarket lights with 12 AWG wire.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #4 of 5 Old 09-16-2009, 07:17 AM
SirGCal
RIP
SirGCal's Avatar
As for them not lighting up, my bet is you didn't have something connected very securely making a poor contact. Also the bulb might be broken (it happens sometimes during shipping though rare) or some lights require internal grounding during installation, but if so those instructions should have come with the lights. That may actually be the case here though because I see that far more often on cheap imitation type lights which these are. (not that it's bad, but...)
SirGCal is offline
post #5 of 5 Old 09-16-2009, 03:35 PM
Engine_HP
12awg is fine, as what SirGCal "said you can never be too large."
Jeep Grand Cherokee 2000
SONY XPLOD CDX-GT420U,
Power Acoustic BAMF 5500/1 Amplifier,
2 Type R 15 Dual 4ohms,
Ported 7.07'cu Tuned 34hz
Big 3 1/0 Gauge wire.
Engine_HP is offline
42RE park/neutral switch, 3 wire vs. 5 wire sportcoupe Engines & Drivetrain 0 01-09-2010 07:34 AM
BEST way to balance a large tire Imped Tires & Wheels 13 04-28-2009 07:22 PM
Large Gas Can? Scuter83 General Jeep & Off-Road Equipment 14 02-15-2007 10:16 AM
Large Tyres tonyfaiers Street Jeep Forum 5 08-02-2006 07:05 PM
how large? Rockwall Tires & Wheels 3 11-18-2001 04:09 PM
