JeepForum.com (https://www.jeepforum.com/forum/)
-   Audio, CB & Ham Radios, GPS, & Electrical (https://www.jeepforum.com/forum/f20/)
-   -   What CB radio seems to hold up the best? (https://www.jeepforum.com/forum/f20/what-cb-radio-seems-hold-up-best-4418301/)
Harriedtwo 12-12-2020 04:48 PM
RapidRob, I received a Cobra CB for my birthday to replace my old CB since it was fading away. Everything is in the handheld part and the other part will reside somewhere under the dash. The Las Cruces 4x4 club is starting to switch to a different radio system for the Chile Challenge since distance is not such an issue. I've used some of the FMR units when hiking but they are not as reliable as I thought they would be.
Best wishes on your install and while out riding. I'm staying at home these days since I haven't installed the new trackbar and I don't want the darn COVID since both my wife and I are in the High Risk category.
Vietnam was so long ago, but the memories from that time never go away. (Army 67-70; 412th Trans Co, 2nd LOG)
Rapidrob 12-12-2020 05:10 PM
What radio system are they going to?
Ozzy379 12-23-2020 04:00 AM
I I had a Uniden 520 and it was a screamer right out if the box. It had a good set of ears too. I do not use my squelch at all. Which is why I went with the 520. It has adjustable RF gain. Stock microphone works best with it. I experimented with a noise canceling mic. They can't get the radio modulated. If you or someone else decides to go with that radio later one. You won't be disappointed.
downs 12-23-2020 11:47 AM
I just checked their bylaws and it still says CB in there. But if they are following the general trend it'll be to GMRS/FRS. Jeep Jamborees will be requiring GMRS/FRS vs CB starting 2021. Smaller equipment and antennas easier to tune usually comes already tuned. FM vs AM sound quality. Repeater access.
CB is kind of losing steam with a lot of groups. It's still out there for sure but not near as much as it used to be. I think with this new solar cycle coming in CB may "wake up" again for those still using it. I run HAM, GMRS/FRS, and CB right now. It's pretty much the only way to effectively "cover the bases" when it comes to the fractured comms landscape of the off road community.
Rapidrob 12-23-2020 12:19 PM
I bought a Wison FLEX antenna for the rear mount of my ZJ. The antenna SWR is so high it is not safe to transmit.
I had to buy a roof top magnetic mount to see if I can get the SWR down to normal readings.
The FCC HAM exam is next month and I hope to get one of the two licenses.
I use Family Band radios now for the shooting club I run and they are pretty poor.111p
Rapidrob 12-24-2020 04:39 PM
The magnetic mount showed up today and the SWR is now very low. I could reach a trucker at 6 miles.
More than what I need.
Harriedtwo 12-26-2020 01:36 AM
Rapidrob, I don't know. The group has been very quiet for the past few months so I'll try to get in touch with them to find out. If they are switching, it will be primarily for the club as it operates the various trail rides. We've had issues in the past regarding a lot of vehicles spread out over a lot of trail. I know of several trails where we had to have someone in the center of the group aid in relaying messages and information regarding issues like stuck vehicles, breakdowns, etc.
Rapidrob 12-26-2020 07:42 AM
OK, just let me know as I'm getting my HAM license ( Tech) in January. If the club is going to be on a FCC General Band I'll need to get busy with my studies for that license and radio purchase.
CJ7-Tim 12-26-2020 09:12 AM
I do not care for the Wilson FLEX antenna with the little wire tail on it. I have much better results tuning for a low SWR with the FireStik FS that have the tuning tip. The longer the antenna length, the easier it is to tune, and it will have a wider bandwidth of channel coverage with a good SWR.
cranbiz 01-04-2021 12:32 PM
I seriously doubt that they will be using HF for trail comms, which would require a General ticket. The radio's are larger, the antenna's are larger and everything is more expensive.They will use either 2M or 70CM thru a repeater if they need distance. The cheap Chicom radios work in these bands ($30 Baofeng HT or a 4 channel QYT mobile for $80) A decent dual band mobile by one of the big 3 (Kenwood, Yaesu or Icom) come in around $300
downs 01-05-2021 05:31 PM
+1 the tech level license is going to probably do everything you want to do in a Jeep unless you get into really long distance stuff.
Rapidrob 01-05-2021 10:43 PM
I have the option to also take the General exam at the same time as the Tech exam. I'm reading everything I can get my hands on for the exam. It would be nice to open up more band width and frequencies.
cranbiz 01-06-2021 07:44 AM
Absolutely, as long as you pass an element, the session can continue for the next level exam for your one exam fee. So, if you pass both the Tech and the General exams, you can also take the Extra. Even if you are not ready for the next level exam, take it. If you pass, great, if not, then what you get is a look at the exam for the next time.
I have seen examinee's come in for a Tech and leave with an Extra. Granted, that's rare. Our last session we had one Tech candidate leave with his General.
Good luck.
Rapidrob 01-06-2021 09:35 AM
I live on the side of a mountain at 8,000 feet ASL and never really thought about becoming a HAM operator. While any antenna I could legally put up won't clear the summit of the mountain, I can clearly transmit South,West,and North with no issues. Sandia Mountain is only 14 miles away due West of my home with tons of repeaters and the like all over its summit.
Even a mobile unit here should do well if properly set up.
Rapidrob 01-16-2021 05:35 PM
I got my Tech license today and missed the General by two questions. I'll take the General exam again next month.
The left has now imposed a fee of 35 dollars to get your license which was free for me today. I'll have to pay for the General License if I pass the exam next month unless they hold off passing the Fee requirement.
The time now is 06:45 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
